I made progress by modifying the blueprint as follows:
blueprint:
description: Create automations for the AEON minimote.
domain: automation
input:
aeon_minimote:
description: AEON minimote.
selector:
device:
integration: zwave_js
manufacturer: AEON Labs
model: DSA03XXX-ZW
button_1:
name: Press Button One
description: Action to run on button press.
default: []
selector:
action: {}
button_2:
name: Press Button Two
default: []
selector:
action: {}
button_3:
name: Press Button Three
default: []
selector:
action: {}
button_4:
name: Press Button Four
default: []
selector:
action: {}
mode: single
max_exceeded: silent
platform: event
event_type: zwave_js_event
event_data:
command_class_name: Central Scene
device_id: !input aeon_minimote
- variables:
scene_id: "{{ trigger.event.data.property_key_name }}"
- choose:
- conditions: "{{ scene_id == '001' }}"
sequence: !input button_1
- conditions: "{{ scene_id == '002' }}"
sequence: !input button_2
- conditions: "{{ scene_id == '003' }}"
sequence: !input button_3
- conditions: "{{ scene_id == '004' }}"
sequence: !input button_4
Now I can create an automation:
Alas, nothing happens when I press the button. My guess is that this part of the blueprint is wrong:
I also guess that the right value is avaialble somewhere in the debug info:
"id": 3,
"deviceId": "134-3-1",
"manufacturer": "AEON Labs",
"manufacturerId": 134,
"productType": 1,
"productId": 3,
"name": "",
"loc": "",
"values": [
"id": "3-112-0-241",
"nodeId": 3,
"commandClass": 112,
"commandClassName": "Configuration",
"endpoint": 0,
"property": 241,
"propertyName": "Mode of Button 1 (upper left)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 1",
"label": "Mode of Button 1 (upper left)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"text": "Factory Default",
"value": 0
"text": "Scene Mode",
"value": 1
"text": "Add Mode",
"value": 2
"text": "Remove Mode",
"value": 3
"text": "Association Mode",
"value": 4
"text": "Learn Mode",
"value": 5
"lastUpdate": 1613193164053
"id": "3-112-0-242",
"nodeId": 3,
"endpoint": 0,
"property": 242,
"propertyName": "Mode of Button 2 (upper right)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 2",
"label": "Mode of Button 2 (upper right)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"value": 0
"value": 1
"text": "Add Mode",
"value": 2
"value": 3
"value": 4
"value": 5
"lastUpdate": 1613193164056
"id": "3-112-0-243",
"nodeId": 3,
"endpoint": 0,
"property": 243,
"propertyName": "Mode of Button 3 (lower left)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 3",
"label": "Mode of Button 3 (lower left)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"value": 0
"value": 1
"text": "Add Mode",
"value": 2
"value": 3
"value": 4
"value": 5
"lastUpdate": 1613193164058
"id": "3-112-0-244",
"nodeId": 3,
"endpoint": 0,
"property": 244,
"propertyName": "Mode of Button 4 (lower right)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 4",
"label": "Mode of Button 4 (lower right)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"value": 0
"value": 1
"text": "Add Mode",
"value": 2
"value": 3
"value": 4
"value": 5
"lastUpdate": 1613193164059
"id": "3-112-0-245",
"nodeId": 3,
"endpoint": 0,
"property": 245,
"propertyName": "Mode of Button 5 (Include)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 5",
"label": "Mode of Button 5 (Include)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"value": 0
"value": 1
"text": "Add Mode",
"value": 2
"value": 3
"value": 4
"value": 5
"lastUpdate": 1613193164061
"id": "3-112-0-246",
"nodeId": 3,
"endpoint": 0,
"property": 246,
"propertyName": "Mode of Button 6 (Exclude)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 6",
"label": "Mode of Button 6 (Exclude)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"value": 0
"value": 1
"text": "Add Mode",
"value": 2
"value": 3
"value": 4
"value": 5
"lastUpdate": 1613193164062
"id": "3-112-0-247",
"nodeId": 3,
"endpoint": 0,
"property": 247,
"propertyName": "Mode of Button 7 (Association)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 7",
"label": "Mode of Button 7 (Association)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"value": 0
"value": 1
"text": "Add Mode",
"value": 2
"value": 3
"value": 4
"value": 5
"lastUpdate": 1613193164064
"id": "3-112-0-248",
"nodeId": 3,
"endpoint": 0,
"property": 248,
"propertyName": "Mode of Button 8 (Learn)",
"type": "number",
"readable": false,
"writeable": true,
"description": "Defines the switching mode of Button 8",
"label": "Mode of Button 8 (Learn)",
"default": 0,
"stateless": false,
"min": 0,
"max": 5,
"list": true,
"states": [
"value": 0
"value": 1
"text": "Add Mode",
"value": 2
"value": 3
"value": 4
"value": 5
"lastUpdate": 1613193164065
"id": "3-112-0-250",
"nodeId": 3,
"endpoint": 0,
"property": 250,
"propertyName": "Secondary Controller Mode",
"type": "number",
"readable": false,
"writeable": true,
"description": "Selects Group Mode or Scene Mode",
"label": "Secondary Controller Mode",
"default": 0,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"text": "Group Mode",
"value": 0
"value": 1
"lastUpdate": 1613193164066
"id": "3-114-0-manufacturerId",
"nodeId": 3,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"endpoint": 0,
"property": "manufacturerId",
"propertyName": "manufacturerId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 134,
"lastUpdate": 1613193164067,
"newValue": 134
"id": "3-114-0-productType",
"nodeId": 3,
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 1,
"lastUpdate": 1613193164068,
"newValue": 1
"id": "3-114-0-productId",
"nodeId": 3,
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 3,
"lastUpdate": 1613193164069,
"newValue": 3
"id": "3-132-0-wakeUpInterval",
"nodeId": 3,
"commandClass": 132,
"commandClassName": "Wake Up",
"endpoint": 0,
"property": "wakeUpInterval",
"propertyName": "wakeUpInterval",
"type": "number",
"readable": true,
"writeable": true,
"label": "Wake Up interval",
"stateless": false,
"min": 0,
"max": 16777215,
"list": false,
"lastUpdate": 1613193164070
"id": "3-132-0-controllerNodeId",
"nodeId": 3,
"endpoint": 0,
"property": "controllerNodeId",
"propertyName": "controllerNodeId",
"type": "any",
"readable": true,
"writeable": false,
"label": "Node ID of the controller",
"stateless": false,
"list": false,
"lastUpdate": 1613193164071
"id": "3-134-0-libraryType",
"nodeId": 3,
"commandClass": 134,
"commandClassName": "Version",
"endpoint": 0,
"property": "libraryType",
"propertyName": "libraryType",
"type": "any",
"readable": true,
"writeable": false,
"label": "Library type",
"stateless": false,
"list": false,
"value": 2,
"lastUpdate": 1613193164072,
"newValue": 2
"id": "3-134-0-protocolVersion",
"nodeId": 3,
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"type": "any",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateless": false,
"list": false,
"value": "2.78",
"lastUpdate": 1613193164073,
"newValue": "2.78"
"id": "3-134-0-firmwareVersions",
"nodeId": 3,
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"type": "any",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateless": false,
"list": false,
"value": [
"1.19"
"newValue": [
"1.19"
"groups": [],
"neighbors": [],
"ready": true,
"available": false,
"hassDevices": {},
"failed": false,
"lastActive": 1613193164074,
"interviewCompleted": false,
"firmwareVersion": "1.19",
"isBeaming": true,
"isSecure": false,
"keepAwake": false,
"maxBaudRate": null,
"isRouting": false,
"isFrequentListening": false,
"isListening": false,
"status": "Asleep",
"interviewStage": "RestartFromCache",
"productLabel": "DSA03XXX-ZW",
"productDescription": "Minimote 4 button remote control",
"zwaveVersion": 3,
"deviceClass": {
"basic": 1,
"generic": 1,
"specific": 1
"hexId": "0x0086-0x0003-0x0001",
"_name": "NodeID_3"
Any suggestions?
