I am sorry to seemingly keep beating a horse (he’s not quite dead yet), but I am seriously trying to figure this out. And perhaps because I know it works in both Vera and SmartThings I just cannot get it figured out in HA.
When I set up the MultiSensor 6 in HA, I noticed that when motion was detected, it would trigger what I wanted to trigger, however, instead of indicating motion, it simply had a value that changed for the Burglar/Motion. For motion, it would change from 0 to 8 and for tampering it would change from 0 to 3. If there was motion detected and then tampering was detected it would change from 8 to 3 and vice versa for tampering then motion.
With the help of another member here in a post I made, I was able to get an automation set up to used those numerical values. All was good until I moved the device around, simulating being tampered with. My automation was based on the value going from 0 to 8 then back to 0. For some reason, when the value goes from 0 to 8, the automation is triggered, but if the device is tampered with, changing the value from 8 to 3, and then when the timeout occurs, 3 to 0, it does not turn off switch I have set up to be triggered upon detecting motion.
So I did some testing today. I went into OZCP. There, I can see the sensor state change from off to on when motion is detected, even though it is not being reflected on the frontend of HA. So I triggered the motion sensor, thus changing the sensors state from off to on. Then I restarted HA. You can see that it picks up the change at least as noted by 001-T.
Then, I triggered the other motion sensor (002-T) just to show that it does not change the sensor state from off to on on the front end but does give the burglar indication:
So then I triggered the first sensor from the front end
As you can see, with the burglar value changing from 0 8 it triggers Switch 001-T to the on state and when it goes back to 0, as long as there is no tampering, it will turn the switch off.
I’m not sure what I need to do here. I had no issues with this in Vera or SmartThings and never had to go into any Zwave Control Panel to get it to indicate a sensor state change from off to on and back. I don’t mind doing so in HA, but I don’t understand why that indication is not showing up in HA or why it is not reporting when triggered.
I have scoured the manual for this device and even downloaded a more detailed configuration manual and there is absolutely nothing to be found about sensor state reporting. I know when I trigger the sensor in the OZWCP it changes stated from off to on instantly.
While I am at it, I am assuming that the Ultraviolet sensor does not work in HA? If not that is not a big deal either, just curious. I am more focused on getting the sensor state issue fixed.
