I updated last night. The integration communicates with the console and reports temperatures correctly. I can control zones as well.
However, the AC units are reported as “Off” and do not reflect the state of the AC. I have not touched those settings, and so far the zone temperatures are still reporting.
@smitcoracing It’s busted on console version 1.2.0.
I’ll have a poke around when I have some time, if you can please ask airtouch what they’ve changed and let me know so I can fix it.
These are the errors I was getting related to the AC units:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:283
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 8:51:00 AM (1 occurrences)
Last logged: 8:51:00 AM
[140273793315696] Fan mode is not valid. Valid fan modes are: low, high, auto
Note that these are indeed the fan speeds I have configured in my Airtouch console.
Bad news, after a reboot of the main Airtouch module in the ceiling, the integration will no longer load at all. Log below:
Source: config_entries.py:594
First occurred: 9:12:02 AM (1 occurrences)
Last logged: 9:12:02 AM
Error setting up entry 192.168.0.87 for airtouch5
File "/usr/local/lib/python3.12/asyncio/tasks.py", line 520, in wait_for
return await fut
File "/usr/local/lib/python3.12/site-packages/airtouch5py/airtouch5_simple_client.py", line 142, in _read_packets_until_match
packet = await self._client.packets_received.get()
File "/usr/local/lib/python3.12/asyncio/queues.py", line 158, in get
await getter
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/airtouch5/__init__.py", line 25, in async_setup_entry
await client.connect_and_stay_connected()
File "/usr/local/lib/python3.12/site-packages/airtouch5py/airtouch5_simple_client.py", line 129, in connect_and_stay_connected
for ac in (await self._wait_for_packet_or_throw(AcStatusData)).ac_status
File "/usr/local/lib/python3.12/site-packages/airtouch5py/airtouch5_simple_client.py", line 150, in _wait_for_packet_or_throw
return await asyncio.wait_for(_read_packets_until_match(), 5)
File "/usr/local/lib/python3.12/asyncio/tasks.py", line 519, in wait_for
async with timeouts.timeout(timeout):
File "/usr/local/lib/python3.12/asyncio/timeouts.py", line 115, in __aexit__
raise TimeoutError from exc_val
TimeoutError
I have a Wireshark PCAP of the reload attempt if so desired. TCP connection to the console is succeeding, and I see some data about the zone names in the data returned from the console, so it’s not something low level. It has to be related to something related to the API.
The length of one of the packets has changed, I can work around it (it would be good to know what the new bytes mean though).
Will push some test code in ~2hrs hopefully, gotta head out.
New commit pushed here, but haven’t done a release yet GitHub - danzel/airtouch5py: Python client for the airtouch 5
To unblock everyone, here is a copy of the component with my current fix in:
Grab airtouch5-0.2.9.zip and extract it in to custom_components/, so you end up with custom_components/airtouch5/manifest.json.
Then restart HA.
(Or you can do what jadedfk posted above)
This will get it running again with 1.2.0
From the protocol docs I need to remove a few of the length checks, I’ll hopefully do that and submit this upstream to HA sometime this weekend.
