Hi anyone else having issues with the Alexa Media Player integration?
this morning I noticed in my HA asking to Configure it, but when I clicked nothing hapened, so I tried to remove the integation and add it again and nothing is happening… so wondering if Amazon closed something or just me?
I’m back at having issues again
Tried to remove the integration and add again, and it just keep asking for the captcha, then the code sent by amazon and never gets out of there
So I’m gonna go with nothing is working unfortunately and no disrespect to the developers of the plugin, it has become unusable to me for quite some time now
I have the same problem with the configuration screen of the integration, I receive unknow error after enter my login information. It was since 2 or 3 days ago.
are you reentering the captcha? Every few days/weeks you have to enter this information if the authentication(Not sure if this is the correct word) is old. Check your notifications and enter the proper information to the captcha.
I struggled quite a while too. made it work by making sure that the Alexa-domain you logon to in Home Assistant is the same as the domain you see when logging in to alexa from a browser.
In my case I had alexa.com in HA and alexa.co.uk in browser.
Putting it to Alexa.co.uk in HA did the trick. Now it works.
I wasn’t sure what value those entities offered me and I couldn’t find a reason to use them, so the fact they weren’t available wasn’t something I worried about. Disabled them to clean the view up and still had access to push TTS message to the Alexa device etc.
Would be interested to hear if you have a use case for them, perhaps its something I should investigate (one day!)
I successfully did the 2FA authentication and it works but when i restart the Home Assistant the Alexa media players are not available. Then I need to uninstall it and then reinstall it. I don’t think that’s normal.
How could I do this without always having to reinstall it?
