Is anyone familiar with the Alexa Media Player Integration? I am trying to trigger a routine via visual scripting and failing. I’m struggling to see what I’m missing.
Please post your script and explain what is happening.
I have attempted to run a routine from dev tools, but when I hit “call service” I’m getting no reaction and sometimes getting errors (I’ve attempted to run this multiple ways to no avail). It looks to me the same as what’s in the docs, but I barely understand what I’m doing here. I am in need of enlightenment
Below is the service section of a script I use daily.
service: media_player.play_media
media_content_id: AS turn off A's lamp
media_content_type: routine
entity_id: media_player.bedroom_dot
Your example is missing a “target” heading… you can’t use entity_id alone. To test it in the Dev Tools>Service menu you may need to click the “Go To YAML Mode” button in the lower left, and then enter it manually.
The media_content_id must match the name of the routine in the Alexa app exactly. Capitalization, spacing, and punctuation must match.
You don’t use the hyphen when using the Services tool… “service”, “data”, and “target” should all be as far to the left as possible.
You’ve selected the media_pause service ?
The service should be Media Player: Play media
Same error ? I’ve just tested and works fine. Do you need the device_id ? Mine works without it
You definitely have a routine in your Alexa app called test ?
Very odd
Can you try without target as in the docs ?
entity_id: media_player.aaron_s_echo_dot
media_content_id: test
same result, no response. Call service button goes from blue to green but no action on alexa
I’m grasping at straws here… what actions does your test routine do?
it just triggers a “happy birthday” message. I set this up only to test that I can trigger a routine via the media player. I do see some odd things in my log file:
2021-11-03 20:22:24 WARNING (MainThread) [alexapy.alexalogin] No access token found; falling back to credential login instead of oauth.
2021-11-04 08:44:07 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from mobile-166-205-087-010.mycingular.net (*my external ip*). (HomeAssistant/Android 2021.10.0-761)
2021-11-04 10:15:44 ERROR (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data['media_content_id']
2021-11-04 22:40:27 ERROR (MainThread) [custom_components.alexa_media] Unexpected error fetching alexa_media data: argument of type 'NoneType' is not iterable
It looks like alexapy is a dependency for the media player and is having some sort of error, although the app has my creds so idk why this would break things. The last two errors make no sense to me
Can you try to run this script ?:
alias: Alexa speak
sequence:
- service: notify.alexa_media
message: happy birthday
type: tts
target: media_player.yourdevice
mode: single
icon: mdi:clipboard-text-play-outline
or try also this service call:
type: tts
message: Hello
