Alternative firmware for Arilux AL-LC03 for use with MQTT and Home Assistant (RGB light strip controller)
Hi all,
Flashed my units today (LC01 with a esp8285).
Pin-out has changed as mentioned in the repo.
For RGB use:
#define ARILUX_RED_PIN 5
#define ARILUX_GREEN_PIN 12
#define ARILUX_BLUE_PIN 13
No idea for RGBW/RGBWW.
Make sure you gnd gpio0 on the casing of the chip, not on the GND line. My units wouldn’t go into flash mode.
Otherwise works ok. No coil whine in my two units either.
Perhaps the chip is attempting to drive the wrong lines causing the whine???
