Am I Setting Partial Parameters Correctly?
Hi all,
I am in the process of setting up a new Inovelli lightstrip (LZW45), but I seem to be having some trouble properly setting configuration paramers to utilize the custom effects.
I’ve used this super handy page to determine what the proper values should be set to in each of the 4 parameters.
For example, just using what Inovelli has in their KB on the subject of custom effects, I’m using:
Parameter 22: 8802
Parameter 23: 25443
Parameter 24: 257
Parameter 30: 255
Now, with the Zwave JS integration, I’ve read that the proper way to set these parameters thru HA is to utilize the ZWAVE_JS.BULK_SET_PARTIAL_CONFIG_PARAMETERS service.
I’ve built a super simple script that should be applying the values above with the bulk change service:
alias: Bulk Light Strip Test
sequence:
  - service: zwave_js.bulk_set_partial_config_parameters
      entity_id: light.light_strip
      value: 8802
      parameter: '22'
      value: 25443
      parameter: '23'
      value: 257
      parameter: '24'
      value: 255
      parameter: '30'
mode: single
Now, this script right now does nothing to my lights. supposedly, they should be flashing like a police car or something.
Here are some logs I have collected when attempting to run the script above.
Home Assistant Zwave JS Logs (set to the “Silly” log level):
Subscribed to Z-Wave JS Log Messages…
2021-10-25T01:34:44.094Z SERIAL » 0x010d00130e06700416022262254fa3                                    (15 bytes)
2021-10-25T01:34:44.095Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ transmit options: 0x25
                                  │ callback id:      79
                                  └─[ConfigurationCCSet]
                                      parameter #:      22
                                      reset to default: false
                                      value size:       2
                                      value format:     SignedInteger
                                      value:            8802
2021-10-25T01:34:44.096Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:44.103Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:44.103Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.104Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:44.117Z SERIAL « 0x010700134f000001a5                                                 (9 bytes)
2021-10-25T01:34:44.117Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.118Z DRIVER « [REQ] [SendData]
                                    callback id:     79
                                    transmit status: OK
2021-10-25T01:34:44.128Z SERIAL » 0x010d00130e067004170263632550fd                                    (15 bytes)
2021-10-25T01:34:44.129Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      80
                                      parameter #:      23
                                      value size:       2
                                      value:            25443
2021-10-25T01:34:44.132Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:44.138Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:44.138Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.139Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:44.152Z SERIAL « 0x0107001350000002b9                                                 (9 bytes)
2021-10-25T01:34:44.152Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.153Z DRIVER « [REQ] [SendData]
                                    callback id:     80
                                    transmit status: OK
2021-10-25T01:34:44.165Z SERIAL » 0x010d00130e067004180201012551f3                                    (15 bytes)
2021-10-25T01:34:44.166Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      81
                                      parameter #:      24
                                      value size:       2
                                      value:            257
2021-10-25T01:34:44.168Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:44.174Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:44.175Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.176Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:44.188Z SERIAL « 0x0107001351000002b8                                                 (9 bytes)
2021-10-25T01:34:44.189Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.189Z DRIVER « [REQ] [SendData]
                                    callback id:     81
                                    transmit status: OK
2021-10-25T01:34:44.200Z SERIAL » 0x010d00130e0670041e0200ff255209                                    (15 bytes)
2021-10-25T01:34:44.201Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      82
                                      parameter #:      30
                                      value size:       2
                                      value:            255
2021-10-25T01:34:44.203Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:44.210Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:44.210Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.211Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:44.224Z SERIAL « 0x0107001352000002bb                                                 (9 bytes)
2021-10-25T01:34:44.224Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:44.225Z DRIVER « [REQ] [SendData]
                                    callback id:     82
                                    transmit status: OK
2021-10-25T01:34:45.125Z SERIAL » 0x010a00130e037005162553fe                                          (12 bytes)
2021-10-25T01:34:45.125Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      83
                                  └─[ConfigurationCCGet]
                                      parameter #: 22
2021-10-25T01:34:45.127Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:45.133Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:45.134Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.135Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:45.147Z SERIAL « 0x0107001353000001b9                                                 (9 bytes)
2021-10-25T01:34:45.148Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.148Z DRIVER « [REQ] [SendData]
                                    callback id:     83
                                    transmit status: OK
2021-10-25T01:34:45.160Z SERIAL « 0x010e0004000e08700616040000000097                                  (16 bytes)
2021-10-25T01:34:45.162Z CNTRLR   [Node 014] [~] [Configuration] 22[7]: 0 => 0
2021-10-25T01:34:45.163Z CNTRLR   [Node 014] [~] [Configuration] 22[248]: 0 => 0
2021-10-25T01:34:45.165Z CNTRLR   [Node 014] [~] [Configuration] 22[1792]: 0 => 0
2021-10-25T01:34:45.166Z CNTRLR   [Node 014] [~] [Configuration] 22[63488]: 0 => 0
2021-10-25T01:34:45.167Z CNTRLR   [Node 014] [~] [Configuration] 22[458752]: 0 => 0
2021-10-25T01:34:45.168Z CNTRLR   [Node 014] [~] [Configuration] 22[16252928]: 0 => 0
2021-10-25T01:34:45.169Z CNTRLR   [Node 014] [~] [Configuration] 22[117440512]: 0 => 0
2021-10-25T01:34:45.170Z CNTRLR   [Node 014] [~] [Configuration] 22[4160749568]: 0 => 0
2021-10-25T01:34:45.172Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.172Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                  └─[ConfigurationCCReport]
                                      parameter #: 22
                                      value size:  4
                                      value:       0
2021-10-25T01:34:45.177Z SERIAL » 0x010a00130e037005172554f8                                          (12 bytes)
2021-10-25T01:34:45.177Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      84
                                      parameter #: 23
2021-10-25T01:34:45.180Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:45.186Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:45.186Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.187Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:45.200Z SERIAL « 0x0107001354000002bd                                                 (9 bytes)
2021-10-25T01:34:45.200Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.201Z DRIVER « [REQ] [SendData]
                                    callback id:     84
                                    transmit status: OK
2021-10-25T01:34:45.211Z SERIAL « 0x010e0004000e08700617040000000096                                  (16 bytes)
2021-10-25T01:34:45.213Z CNTRLR   [Node 014] [~] [Configuration] 23[127]: 0 => 0
2021-10-25T01:34:45.215Z CNTRLR   [Node 014] [~] [Configuration] 23[32512]: 0 => 0
2021-10-25T01:34:45.216Z CNTRLR   [Node 014] [~] [Configuration] 23[8323072]: 0 => 0
2021-10-25T01:34:45.218Z CNTRLR   [Node 014] [~] [Configuration] 23[2130706432]: 0 => 0
2021-10-25T01:34:45.219Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.220Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      parameter #: 23
                                      value size:  4
                                      value:       0
2021-10-25T01:34:45.224Z SERIAL » 0x010a00130e037005182555f6                                          (12 bytes)
2021-10-25T01:34:45.225Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      85
                                      parameter #: 24
2021-10-25T01:34:45.228Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:45.233Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:45.234Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.234Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:45.247Z SERIAL « 0x0107001355000001bf                                                 (9 bytes)
2021-10-25T01:34:45.247Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.247Z DRIVER « [REQ] [SendData]
                                    callback id:     85
                                    transmit status: OK
2021-10-25T01:34:45.259Z SERIAL « 0x010e0004000e08700618040000000099                                  (16 bytes)
2021-10-25T01:34:45.260Z CNTRLR   [Node 014] [~] [Configuration] 24[63]: 0 => 0
2021-10-25T01:34:45.261Z CNTRLR   [Node 014] [~] [Configuration] 24[16128]: 0 => 0
2021-10-25T01:34:45.262Z CNTRLR   [Node 014] [~] [Configuration] 24[4128768]: 0 => 0
2021-10-25T01:34:45.263Z CNTRLR   [Node 014] [~] [Configuration] 24[1056964608]: 0 => 0
2021-10-25T01:34:45.264Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.265Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      parameter #: 24
                                      value size:  4
                                      value:       0
2021-10-25T01:34:45.268Z SERIAL » 0x010a00130e0370051e2556f3                                          (12 bytes)
2021-10-25T01:34:45.269Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      86
                                      parameter #: 30
2021-10-25T01:34:45.271Z SERIAL « [ACK]        (0x06)
2021-10-25T01:34:45.277Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T01:34:45.277Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.278Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T01:34:45.291Z SERIAL « 0x0107001356000002bf                                                 (9 bytes)
2021-10-25T01:34:45.291Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.292Z DRIVER « [REQ] [SendData]
                                    callback id:     86
                                    transmit status: OK
2021-10-25T01:34:45.304Z SERIAL « 0x010e0004000e0870061e04000000009f                                  (16 bytes)
2021-10-25T01:34:45.305Z CNTRLR   [Node 014] [~] [Configuration] 30[255]: 0 => 0
2021-10-25T01:34:45.306Z CNTRLR   [Node 014] [~] [Configuration] 30[65280]: 0 => 0
2021-10-25T01:34:45.306Z CNTRLR   [Node 014] [~] [Configuration] 30[16711680]: 0 => 0
2021-10-25T01:34:45.307Z SERIAL » [ACK]        (0x06)
2021-10-25T01:34:45.307Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      parameter #: 30
                                      value size:  4
                                      value:       0
From the ZWave JS Debug Window (I think this is set to just debug):
2021-10-24 20:34:41.497 INFO ZWAVE-SERVER: Stopping logging event forwarder
2021-10-24 20:34:42.169 INFO ZWAVE-SERVER: Starting logging event forwarder at silly level
2021-10-24 20:34:45.163 INFO ZWAVE: Node 14: value updated: 112-0-22-7 0 => 0
2021-10-24 20:34:45.164 INFO ZWAVE: Node 14: value updated: 112-0-22-248 0 => 0
2021-10-24 20:34:45.165 INFO ZWAVE: Node 14: value updated: 112-0-22-1792 0 => 0
2021-10-24 20:34:45.166 INFO ZWAVE: Node 14: value updated: 112-0-22-63488 0 => 0
2021-10-24 20:34:45.167 INFO ZWAVE: Node 14: value updated: 112-0-22-458752 0 => 0
2021-10-24 20:34:45.169 INFO ZWAVE: Node 14: value updated: 112-0-22-16252928 0 => 0
2021-10-24 20:34:45.170 INFO ZWAVE: Node 14: value updated: 112-0-22-117440512 0 => 0
2021-10-24 20:34:45.171 INFO ZWAVE: Node 14: value updated: 112-0-22-4160749568 0 => 0
2021-10-24 20:34:45.214 INFO ZWAVE: Node 14: value updated: 112-0-23-127 0 => 0
2021-10-24 20:34:45.216 INFO ZWAVE: Node 14: value updated: 112-0-23-32512 0 => 0
2021-10-24 20:34:45.217 INFO ZWAVE: Node 14: value updated: 112-0-23-8323072 0 => 0
2021-10-24 20:34:45.218 INFO ZWAVE: Node 14: value updated: 112-0-23-2130706432 0 => 0
2021-10-24 20:34:45.261 INFO ZWAVE: Node 14: value updated: 112-0-24-63 0 => 0
2021-10-24 20:34:45.262 INFO ZWAVE: Node 14: value updated: 112-0-24-16128 0 => 0
2021-10-24 20:34:45.263 INFO ZWAVE: Node 14: value updated: 112-0-24-4128768 0 => 0
2021-10-24 20:34:45.264 INFO ZWAVE: Node 14: value updated: 112-0-24-1056964608 0 => 0
2021-10-24 20:34:45.305 INFO ZWAVE: Node 14: value updated: 112-0-30-255 0 => 0
2021-10-24 20:34:45.306 INFO ZWAVE: Node 14: value updated: 112-0-30-65280 0 => 0
2021-10-24 20:34:45.307 INFO ZWAVE: Node 14: value updated: 112-0-30-16711680 0 => 0
To me, it looks like there are no parameters actually being set, but I’m not exactly 100% sure what I’m looking at. Is anyone able to offer any insight here? am I doing something wrong? or maybe I found an issue with Zwave JS/HA?
Anyways, first post here so let me know if I can add/change anything to make this easier for folks to take a look into.
Here’s my setup - both zwave js and home assistant in docker containers:
Home Assistant: core-2021.10.6
zwavejs2mqtt*: 5.9.0
zwave-js: 8.5.0.
*I’m not using mqtt between ha and zwjs, but I have the Home Assistant “WS Server” checked in the zwave js settings to allow for the integration to work.
The only thing that looks suspicious to me is that the Set commands use a size of 2-bytes, while the Report sizes are 4-bytes. The partials you are setting are defined for the device as 4-byte values. I think many (most?) devices only accept commands with the expected size.
Do all the partial parameters show up in the Device configuration page?
I see all of the partial configuration parameters, and also single values that look like they’ve been added to the bottom of the list (example below).
Here is an isolated example of what you’re mentioning:
                                  │ callback id:      79
                                      parameter #:      22
                                      value size:       2
                                      value:            8802
Is this an expected behavior, or should there be logic in ZWAVE_JS.BULK_SET_PARTIAL_CONFIG_PARAMETERS that handles dealing with the 2 extra bytes that are needed? I am going to set each value individually for each bitmask to see if that changes the behavior.
OK, here is the new script I tested with. I manually set each partial parameter for each bitmask, leaving nothing blank:
alias: Bulk Strip With Partial Params
sequence:
      value:
        '7': 2
        '248': 4
        '1792': 2
        '63488': 12
        '458752': 0
        '16252928': 0
        '117440512': 0
        '4160749568': 0
      parameter: '22'
      value:
        '127': 99
        '32512': 99
        '8323072': 0
        '2130706432': 0
      parameter: '23'
      value:
        '63': 5
        '16128': 5
        '4128768': 0
        '1056964608': 0
      parameter: '24'
      value:
        '255': 255
        '65280': 0
        '16711680': 0
      parameter: '30'
mode: single
though it looks to have given me identical results in the logs, and definitely no difference in the lightstrip effect.
zwavejs:
2021-10-25 10:13:19.391 INFO ZWAVE: Node 14: value updated: 112-0-22-7 0 => 0
2021-10-25 10:13:19.392 INFO ZWAVE: Node 14: value updated: 112-0-22-248 0 => 0
2021-10-25 10:13:19.393 INFO ZWAVE: Node 14: value updated: 112-0-22-1792 0 => 0
2021-10-25 10:13:19.394 INFO ZWAVE: Node 14: value updated: 112-0-22-63488 0 => 0
2021-10-25 10:13:19.395 INFO ZWAVE: Node 14: value updated: 112-0-22-458752 0 => 0
2021-10-25 10:13:19.398 INFO ZWAVE: Node 14: value updated: 112-0-22-16252928 0 => 0
2021-10-25 10:13:19.399 INFO ZWAVE: Node 14: value updated: 112-0-22-117440512 0 => 0
2021-10-25 10:13:19.400 INFO ZWAVE: Node 14: value updated: 112-0-22-4160749568 0 => 0
2021-10-25 10:13:19.443 INFO ZWAVE: Node 14: value updated: 112-0-23-127 0 => 0
2021-10-25 10:13:19.444 INFO ZWAVE: Node 14: value updated: 112-0-23-32512 0 => 0
2021-10-25 10:13:19.445 INFO ZWAVE: Node 14: value updated: 112-0-23-8323072 0 => 0
2021-10-25 10:13:19.446 INFO ZWAVE: Node 14: value updated: 112-0-23-2130706432 0 => 0
2021-10-25 10:13:19.489 INFO ZWAVE: Node 14: value updated: 112-0-24-63 0 => 0
2021-10-25 10:13:19.490 INFO ZWAVE: Node 14: value updated: 112-0-24-16128 0 => 0
2021-10-25 10:13:19.490 INFO ZWAVE: Node 14: value updated: 112-0-24-4128768 0 => 0
2021-10-25 10:13:19.490 INFO ZWAVE: Node 14: value updated: 112-0-24-1056964608 0 => 0
2021-10-25 10:13:19.529 INFO ZWAVE: Node 14: value updated: 112-0-30-255 0 => 0
2021-10-25 10:13:19.530 INFO ZWAVE: Node 14: value updated: 112-0-30-65280 0 => 0
2021-10-25 10:13:19.531 INFO ZWAVE: Node 14: value updated: 112-0-30-16711680 0 => 0
Home Assistant:
2021-10-25T15:13:18.322Z SERIAL » 0x010d00130e06700416026222257894                                    (15 bytes)
2021-10-25T15:13:18.323Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      120
                                      parameter #:      22
                                      value size:       2
                                      value:            25122
2021-10-25T15:13:18.325Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:18.331Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:18.332Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.332Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:18.346Z SERIAL « 0x010700137800000291                                                 (9 bytes)
2021-10-25T15:13:18.346Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.347Z DRIVER « [REQ] [SendData]
                                    callback id:     120
                                    transmit status: OK
2021-10-25T15:13:18.355Z SERIAL » 0x010d00130e067004170263632579d4                                    (15 bytes)
2021-10-25T15:13:18.356Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      121
                                      parameter #:      23
                                      value size:       2
                                      value:            25443
2021-10-25T15:13:18.358Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:18.364Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:18.364Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.365Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:18.378Z SERIAL « 0x010700137900000290                                                 (9 bytes)
2021-10-25T15:13:18.379Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.379Z DRIVER « [REQ] [SendData]
                                    callback id:     121
                                    transmit status: OK
2021-10-25T15:13:18.388Z SERIAL » 0x010d00130e06700418020505257ad8                                    (15 bytes)
2021-10-25T15:13:18.389Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      122
                                      parameter #:      24
                                      value size:       2
                                      value:            1285
2021-10-25T15:13:18.390Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:18.397Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:18.397Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.398Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:18.411Z SERIAL « 0x010700137a00000293                                                 (9 bytes)
2021-10-25T15:13:18.411Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.412Z DRIVER « [REQ] [SendData]
                                    callback id:     122
                                    transmit status: OK
2021-10-25T15:13:18.420Z SERIAL » 0x010d00130e0670041e0200ff257b20                                    (15 bytes)
2021-10-25T15:13:18.420Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      123
                                      parameter #:      30
                                      value size:       2
                                      value:            255
2021-10-25T15:13:18.422Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:18.429Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:18.429Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.429Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:18.442Z SERIAL « 0x010700137b00000292                                                 (9 bytes)
2021-10-25T15:13:18.443Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:18.443Z DRIVER « [REQ] [SendData]
                                    callback id:     123
                                    transmit status: OK
2021-10-25T15:13:19.355Z SERIAL » 0x010a00130e03700516257cd1                                          (12 bytes)
2021-10-25T15:13:19.355Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      124
                                      parameter #: 22
2021-10-25T15:13:19.357Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:19.364Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:19.365Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.366Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:19.378Z SERIAL « 0x010700137c00000295                                                 (9 bytes)
2021-10-25T15:13:19.378Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.379Z DRIVER « [REQ] [SendData]
                                    callback id:     124
                                    transmit status: OK
2021-10-25T15:13:19.389Z SERIAL « 0x010e0004000e08700616040000000097                                  (16 bytes)
2021-10-25T15:13:19.390Z CNTRLR   [Node 014] [~] [Configuration] 22[7]: 0 => 0
2021-10-25T15:13:19.392Z CNTRLR   [Node 014] [~] [Configuration] 22[248]: 0 => 0
2021-10-25T15:13:19.393Z CNTRLR   [Node 014] [~] [Configuration] 22[1792]: 0 => 0
2021-10-25T15:13:19.394Z CNTRLR   [Node 014] [~] [Configuration] 22[63488]: 0 => 0
2021-10-25T15:13:19.395Z CNTRLR   [Node 014] [~] [Configuration] 22[458752]: 0 => 0
2021-10-25T15:13:19.396Z CNTRLR   [Node 014] [~] [Configuration] 22[16252928]: 0 => 0
2021-10-25T15:13:19.399Z CNTRLR   [Node 014] [~] [Configuration] 22[117440512]: 0 => 0
2021-10-25T15:13:19.400Z CNTRLR   [Node 014] [~] [Configuration] 22[4160749568]: 0 => 0
2021-10-25T15:13:19.401Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.402Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      parameter #: 22
                                      value size:  4
                                      value:       0
2021-10-25T15:13:19.406Z SERIAL » 0x010a00130e03700517257dd1                                          (12 bytes)
2021-10-25T15:13:19.407Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      125
                                      parameter #: 23
2021-10-25T15:13:19.409Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:19.417Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:19.418Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.418Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:19.429Z SERIAL « 0x010700137d00000294                                                 (9 bytes)
2021-10-25T15:13:19.429Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.430Z DRIVER « [REQ] [SendData]
                                    callback id:     125
                                    transmit status: OK
2021-10-25T15:13:19.441Z SERIAL « 0x010e0004000e08700617040000000096                                  (16 bytes)
2021-10-25T15:13:19.443Z CNTRLR   [Node 014] [~] [Configuration] 23[127]: 0 => 0
2021-10-25T15:13:19.444Z CNTRLR   [Node 014] [~] [Configuration] 23[32512]: 0 => 0
2021-10-25T15:13:19.445Z CNTRLR   [Node 014] [~] [Configuration] 23[8323072]: 0 => 0
2021-10-25T15:13:19.446Z CNTRLR   [Node 014] [~] [Configuration] 23[2130706432]: 0 => 0
2021-10-25T15:13:19.447Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.449Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      parameter #: 23
                                      value size:  4
                                      value:       0
2021-10-25T15:13:19.454Z SERIAL » 0x010a00130e03700518257edd                                          (12 bytes)
2021-10-25T15:13:19.455Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      126
                                      parameter #: 24
2021-10-25T15:13:19.457Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:19.463Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:19.463Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.464Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:19.477Z SERIAL « 0x010700137e00000297                                                 (9 bytes)
2021-10-25T15:13:19.478Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.478Z DRIVER « [REQ] [SendData]
                                    callback id:     126
                                    transmit status: OK
2021-10-25T15:13:19.488Z SERIAL « 0x010e0004000e08700618040000000099                                  (16 bytes)
2021-10-25T15:13:19.489Z CNTRLR   [Node 014] [~] [Configuration] 24[63]: 0 => 0
2021-10-25T15:13:19.490Z CNTRLR   [Node 014] [~] [Configuration] 24[16128]: 0 => 0
2021-10-25T15:13:19.490Z CNTRLR   [Node 014] [~] [Configuration] 24[4128768]: 0 => 0
2021-10-25T15:13:19.490Z CNTRLR   [Node 014] [~] [Configuration] 24[1056964608]: 0 => 0
2021-10-25T15:13:19.491Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.491Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      parameter #: 24
                                      value size:  4
                                      value:       0
2021-10-25T15:13:19.492Z SERIAL » 0x010a00130e0370051e257fda                                          (12 bytes)
2021-10-25T15:13:19.492Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      127
                                      parameter #: 30
2021-10-25T15:13:19.494Z SERIAL « [ACK]        (0x06)
2021-10-25T15:13:19.500Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2021-10-25T15:13:19.501Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.501Z DRIVER « [RES] [SendData]
                                    was sent: true
2021-10-25T15:13:19.515Z SERIAL « 0x010700137f00000296                                                 (9 bytes)
2021-10-25T15:13:19.515Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.516Z DRIVER « [REQ] [SendData]
                                    callback id:     127
                                    transmit status: OK
2021-10-25T15:13:19.527Z SERIAL « 0x010e0004000e0870061e04000000009f                                  (16 bytes)
2021-10-25T15:13:19.528Z CNTRLR   [Node 014] [~] [Configuration] 30[255]: 0 => 0
2021-10-25T15:13:19.530Z CNTRLR   [Node 014] [~] [Configuration] 30[65280]: 0 => 0
2021-10-25T15:13:19.531Z CNTRLR   [Node 014] [~] [Configuration] 30[16711680]: 0 => 0
2021-10-25T15:13:19.532Z SERIAL » [ACK]        (0x06)
2021-10-25T15:13:19.534Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      parameter #: 30
                                      value size:  4
                                      value:       0
Just use the scripts I wrote. Make sure to use the Zwave JS ones, not the others. The service is the same.
EDIT: The custom one seems out of date. The 2 above should still work. This one below may work, but might need updates.
EDIT2: It should work, just pass zwave_js.bulk_set_partial_config_parameters as the service.
What happens if you use the control panel to set one of the partial values to something non-zero?
These partial parameters cannot be set individually. They need to be set all at once. If the device see’s an invalid full parameter, it does not update the config param. This makes it seem like setting them is not working.
Ok, I recall that being a problem. Then are the values from the Inovelli KB article invalid?
:man_shrugging:
I reverse engineered the whole thing over a weekend back in may with out the knowledge base and that resulted in these scripts. I use them currently, so they work and it’s much easier than using partial service call.
These scripts use the partial param service, but they set the whole byte.
OP is trying to set the custom effects. I use that too but there are a TON of bugs in it, device side.
If I recall correctly, transitioning between white and color does not work for some effects, it works for solid. Produces Green with the other effects.
A real quick test shows that the “Quick Effects” are able to be set in parameter 31 successfully:
      value: 12821
      parameter: '31'
I have not had a chance to use the scripts @petro provided, but it looks like I am using the same calls, so it seems like the custom effects may be broken at the device as was suggested. I’m thinking taking this over to the Inovelli community to see what they have to say.
Thanks @petro & @freshcoast for the sanity check.
It’s not broken, I use them all the time. They have odd effects with specific patterns. But you must set all of the partials at once. Once the last parameter is set, it will start the effect.
You’re welcome to take it over to those forums, you’ll just be talking to me again…
