Here is a new version with worked position and verified on EspHome 2022.11.0
esphome:
platform: ESP32
board: esp-wrover-kit
on_boot:
- script.execute: main
- script.wait: main
wifi:
ssid: !secret wifi_ssid
logger:
level: INFO
api:
ota:
password: "XXXXXXXXX"
ble_client:
- mac_address: 02:7B:F1:3A:C6:63
on_connect:
- binary_sensor.template.publish:
state: ON
- logger.log:
format: "CONNECT LEFT"
level: INFO
on_disconnect:
state: OFF
- logger.log:
format: "DISCONNECT LEFT"
level: INFO
- mac_address: 02:BD:67:49:4B:0D
on_connect:
state: ON
- logger.log:
format: "CONNECT RIGHT"
level: INFO
on_disconnect:
state: OFF
- logger.log:
format: "DISCONNECT RIGHT"
level: INFO
binary_sensor:
device_class: connectivity
name: "Left connected"
name: "Right connected"
device_class: opening
- platform: uptime
# - platform: ble_client
# id: bedroom_left_blind_rssi
# type: rssi
# ble_client_id: bedroom_left_blind
# name: "Bedroom Left Blind RSSI"
# id: bedroom_right_blind_rssi
# type: rssi
# ble_client_id: bedroom_right_blind
# name: "Bedroom Right Blind RSSI"
- platform: ble_rssi
- platform: am43
illuminance:
name: "Bedroom Left Blind Light"
filters:
- filter_out: nan
battery_level:
name: "Bedroom Left Blind Battery"
filters:
- filter_out: nan
update_interval: 30sec
- platform: am43
illuminance:
name: "Bedroom Right Blind Light"
filters:
- filter_out: nan
battery_level:
name: "Bedroom Right Blind Battery"
filters:
- filter_out: nan
switch:
- platform: restart
name: "Bedroom Blind ESP Reboot"
name: "Bedroom Left Blind BLE"
name: "Bedroom Right Blind BLE"
cover:
- platform: am43
pin: 1234
internal: true
on_open:
state: ON
on_closed:
state: OFF
- platform: am43
pin: 1234
internal: true
on_open:
state: ON
on_closed:
state: OFF
has_position: true
lambda: |-
return (id(bedroom_left_blind_cover_internal).position + id(bedroom_right_blind_cover_internal).position) / 2;
open_action:
then:
- script.execute: open_action
close_action:
then:
- script.execute: close_action
stop_action:
then:
- script.execute: stop_action
position_action:
then:
- script.execute:
value: !lambda return pos;
script:
- id: open_action
mode: restart
then:
- script.stop: close_action
- script.stop: stop_action
- script.stop: position_action
- script.stop: update_sensors
- logger.log:
format: "Open ..."
level: INFO
- script.execute: enable_ble
- script.wait: enable_ble
- cover.open: bedroom_left_blind_cover_internal
- cover.open: bedroom_right_blind_cover_internal
- while:
not:
and:
- binary_sensor.is_on: left_open_status
- binary_sensor.is_on: right_open_status
then:
- logger.log:
format: "... opening ..."
level: INFO
- delay: 1sec
- logger.log:
format: "... opened"
level: INFO
- script.execute: update_sensors
- id: close_action
mode: restart
then:
- script.stop: open_action
- logger.log:
format: "Close ..."
level: INFO
- cover.close: bedroom_left_blind_cover_internal
- cover.close: bedroom_right_blind_cover_internal
- while:
not:
and:
- binary_sensor.is_off: left_open_status
- binary_sensor.is_off: right_open_status
then:
- logger.log:
format: "... closing ..."
level: INFO
- delay: 1sec
- logger.log:
format: "... closed"
level: INFO
- id: stop_action
mode: restart
then:
- logger.log:
format: "Stop ..."
level: INFO
- cover.stop: bedroom_left_blind_cover_internal
- cover.stop: bedroom_right_blind_cover_internal
- logger.log:
format: "... stoped"
level: INFO
- id: position_action
mode: restart
parameters:
value: float
then:
- logger.log:
format: "Set position %f ..."
level: INFO
args: [ value ]
- cover.control:
position: !lambda return value;
- cover.control:
- id: enable_ble
mode: restart
then:
- script.stop: disable_ble
- logger.log:
format: "Enabling BLE..."
level: INFO
- if:
- switch.is_off: bedroom_left_blind_ble
then:
- switch.turn_on: bedroom_left_blind_ble
- if:
- switch.is_off: bedroom_right_blind_ble
then:
- switch.turn_on: bedroom_right_blind_ble
- while:
not:
and:
- binary_sensor.is_on: left_connected
- binary_sensor.is_on: right_connected
then:
- logger.log:
format: "... waiting connection ..."
level: INFO
- delay: 1sec
- logger.log:
format: "...BLE enabled"
level: INFO
- id: disable_ble
then:
- logger.log:
format: "Disabling BLE ..."
level: INFO
- switch.turn_off: bedroom_left_blind_ble
- switch.turn_off: bedroom_right_blind_ble
- logger.log:
format: "... BLE disabled"
level: INFO
- id: update_sensors
then:
- logger.log:
format: "Updating sensor ..."
level: INFO
- delay: 1min
- while:
or:
- script.is_running: open_action
- script.is_running: close_action
- script.is_running: stop_action
- script.is_running: position_action
then:
- logger.log:
format: "... domething Still executing ..."
level: INFO
- delay: 10s
- script.execute: disable_ble
- script.wait: disable_ble
- logger.log:
format: "... sensors updated"
level: INFO
- id: main
then:
- while:
- lambda: "return true;"
then:
- script.wait: update_sensors
- delay: 60min
