Thank you. Everything just got 100 times easier
Here is what is shows when I click on the play button in the dashboard.
17-03-27 12:04:55 INFO (MainThread) [homeassistant.components.http] Serving /api/services/media_player/media_play to 192.168.2.26 (auth: True)
17-03-27 12:04:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service=media_play, service_data=entity_id=media_player.office_directv, service_call_id=1977783088-493, domain=media_player>
17-03-27 12:04:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1977783088-493>
Here is what it shows when I click on the power icon in the HA frountend
17-03-27 12:07:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state media_player.office_directv=playing; media_content_id=6920639, media_content_type=movie, friendly_name=Office_Directv, media_title=DIRECTV CINEMA The Screening Room, supported_features=21425, media_duration=86400, media_channel=CINE (201) @ 2017-03-27T12:07:13.718054-05:00>, entity_id=media_player.office_directv, old_state=<state media_player.office_directv=off; friendly_name=Office_Directv, supported_features=21425 @ 2017-03-26T11:51:12.924107-05:00>>
17-03-27 12:07:13 INFO (Thread-3) [homeassistant.components.device_tracker.nmap_tracker] Scanning...
17-03-27 12:07:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state media_player.directv_rid035642660811=playing; media_content_id=6920639, media_content_type=movie, friendly_name=DirecTV_RID-035642660811, media_title=DIRECTV CINEMA The Screening Room, supported_features=21425, media_duration=86400, media_channel=CINE (201) @ 2017-03-27T12:07:14.843835-05:00>, entity_id=media_player.directv_rid035642660811, old_state=<state media_player.directv_rid035642660811=off; friendly_name=DirecTV_RID-035642660811, supported_features=21425 @ 2017-03-26T11:52:09.636023-05:00>>
@ReneTode, How do you do the groups like this. Are they labels, or Iframes?
https://community.home-assistant.io/t/announcement-hadashboard-v2-beta-2/13610/339?u=turboc
I saw you posted the layout, but I donāt see where you defined the widgets?
There should be a call service and state change or error in both cases - I need more context in the log please.
Ok, so I figured it out:
I copied Jeremy.dash to test.dash and loaded it, which worked. I removed Jeremy.dash and copied test.dash to Jeremy.dash, and that worked. It mustāve been some file-level corruption from the old SD Card.
Since Iām using systemd to run my service, I had to add the dash_dir to my appdaemon.cfg file using a static path (/home/pi/appdaemon_dashboard/appdaemon/conf/dashboards) and then it worked. That took a little while to figure out using the systemd command via the CLI.
(edited to remove question, as I figured that out too!!!)
all my widgets are placed in seperate files with the name from the entity.
for labels i use filenames like: header.eetkamer.yaml
for navigate i use names like: dashboard.gang.yaml
those are quite simple widgetdefinitions. like:
widget_type: sensor
title: Temperatuur
units: ""
precision: 1
entity: sensor.huiskamer_box_4_1
widget_style: "border-bottom-left-radius: 30px;border-bottom-right-radius: 30px"
that file is called sensor.huiskamer_box_4_1.yaml
for grouping all the work is done in the dashboardfile. just some round corners are made on widget level.
edit: if you leave the round corners alone you can create groups by putting dashboards in iframes.
This is all I get when I push the play button from the HA log file. Nothing in the AD log, or returned to stdout or stderr either.
17-03-27 13:48:08 INFO (MainThread) [homeassistant.components.http] Serving /api/services/media_player/media_play to 192.168.2.26 (auth: True)
17-03-27 13:48:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service=media_play, service_data=entity_id=media_player.office_directv, service_call_id=1977783088-527, domain=media_player>
17-03-27 13:48:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1977783088-527>
If I try to change the volume while itās off, I get the following, but I didnāt expect it to work since there isnāt anything turned on listening to it.
17-03-27 13:51:01 INFO (MainThread) [homeassistant.components.http] Serving /api/services/media_player/volume_set to 192.168.2.26 (auth: True)
17-03-27 13:51:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service=volume_set, service_data=volume_level=NaN, entity_id=media_player.office_directv, service_call_id=1977783088-529, domain=media_player>
17-03-27 13:51:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1010, in _event_to_service_call
yield from service_handler.func(service_call)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/media_player/__init__.py", line 365, in async_service_handler
yield from getattr(player, method['method'])(**params)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/media_player/__init__.py", line 586, in set_volume_level
raise NotImplementedError()
NotImplementedError
zwave stuff works i have to make template sensorss to extract all data then
Looks like you got a spider on your cam, or someone broke it.
spider ā¦ thats all
stange behaviour with alarm:
canāt input the code ā¦
after update i got an error @aimc
2017-03-27 22:17:38.747198 WARNING ------------------------------------------------------------
2017-03-27 22:17:40.107985 INFO New dashboard connected: Main Panel
2017-03-27 22:17:48.402666 INFO New dashboard connected: Main Panel
2017-03-27 22:19:39.904518 INFO Loading custom skin 'lightgrey'
2017-03-27 22:19:39.968097 INFO Compiling dashboard 'dash_main_grouped_tablet'
2017-03-27 22:19:48.691715 WARNING Variable definition not found in CSS Skin variables: $sensor_text_style
2017-03-27 22:19:52.345139 WARNING ------------------------------------------------------------
2017-03-27 22:19:52.346480 WARNING Unexpected error in CSS file
2017-03-27 22:19:52.347830 WARNING ------------------------------------------------------------
2017-03-27 22:19:52.350922 WARNING Traceback (most recent call last):
File "/home/pi/appdaemon2/appdaemon/appdaemon/appdash.py", line 86, in load_dash
dash = dashboard.compile_dash(name, skin, skindir, request.rel_url.query)
File "/home/pi/appdaemon2/appdaemon/appdaemon/dashboard.py", line 26, in profiled_fn
dash = fn(*args, **kwargs)
File "/home/pi/appdaemon2/appdaemon/appdaemon/dashboard.py", line 44, in newfunc
result = func(*args, **kwargs)
File "/home/pi/appdaemon2/appdaemon/appdaemon/dashboard.py", line 512, in compile_dash
dash = get_dash(name, skin, skindir)
File "/home/pi/appdaemon2/appdaemon/appdaemon/dashboard.py", line 587, in get_dash
widgets = get_widgets()
File "/home/pi/appdaemon2/appdaemon/appdaemon/dashboard.py", line 691, in get_widgets
with open(jspath, 'r') as fd:
FileNotFoundError: [Errno 2] No such file or directory: '/home/pi/appdaemon2/appdaemon/appdaemon/widgets/slider/slider.js'
2017-03-27 22:19:52.352560 WARNING ------------------------------------------------------------
i deleted all compiled files.
i see you changed naming, but i dont know where this error comes from.
Sorry to be a pest, but Iām still not asking my question right. What I want to know is how to get the light blue border on the top and right of the group shown below?
that are 4 widgets.
the label on the top, the switch left, the inputboolean and then a small label at the right.
the top label has the upper corners rounded
the small label on the right has only the right bottom corner rounded.
I think it is because your are using the same custom_css dashboard.css file.
You should add all the new stuff to it from the default dashboard.css file. For the alarm it will be all the .modalDialog stuff.
It should only be (1x1) when you click it it will show what you are seeing right now.
Ahhhhh,
I see said the blind man. Iāve been beating my head against the wall trying to figure out what you were using to enclose the widgets in and then put a header on top of it. So do you put that group of 4 into itās own dash file and then just reference it in your layout for the larger dashboard?
Chip
you can find it in this part of my dash:
- header.radio(270x30),spacer(65x1),header.allesuit(120x30)
- empty: 8
- spacer(385x1),switch.hboog2(100x100),switch.hbank2(100x100)
- empty: 20
- input_boolean.swr32,input_slider.radio_volume2, header.empty(30x120),spacer(65x1),input_boolean.allesuit2(120x100)
header radio, input_boolean.swr32,input_slider.radio_volume2 and header.empty
@aimc i found out where my error came from.
the empty directories slider and display (in the widgets directory) were not deleted with the update.
that results in errors.
Were you by any chance using a widget with the āsliderā widget type instead of āinput_sliderā?
Those directories should have been deleted though ā¦
EDIT: I think git doesnāt automatically delete them when you do a new pull even though they are no longer in the repository, however that shouldnāt have been a problem unless you were trying to use one of the base widgets which I have been tying to avoid anyone doing by not even mentioning them (of course I just did now so we are hosed!!)
@aimc
I need a way to put formatted text into a field. Can we do one of the following?
- make the iframe url_list so it can pick up a local html file file:///localfile.htm
- make the label so it can hold formatted text (either html or print formatted (recognizes \n \t, etc)
- a new widget for displaying text blocks instead of just the larger label type text
I would prefer #1I think since it would be interpreted as html and could include links to other information as well.
Or if you are feeling really good about it today, how about a marquee where we could post various information to it like news, weather, household notices, etc.
they were not deleted because i had edited the css in there and for the update i had renamed the files to .bck
you know me, i am not Always playing by the rules, resulting in the unexpected
