Anyone else having issues with MYQ?
Can second what you said! I just deleted and re-added my garage hub, now shows up as an exclamation mark and unexpected error. I was about to tear through my configs and see what the hell I messed up. Thank you! Guess we wait…or is there a workaround?
I updated to 0.109.6 and the issue is resolved. You can find more info in the below thread.
Is the MyQ API slow for everyone else? I recently installed this garage door opener and in my limited testing it is taking anywhere from 30 seconds to 55 seconds before the state changes from open to closed or closed to open. There is an intermediate state of opening and closing that it never has time to change to. I have automation to flash all my hue lights whenever the garage is open or closed so I know if someone is coming in. This garage door opener is so quiet, that I really need this. Our sensitive dog doesn’t even bark at the garage opening or closing.
If I use the MyQ app to open then the garage generally starts opening within a second or two but it takes HA over 30 seconds before the state is changed from closed to open. If I close from the MyQ app then there is about a 10 second delay along with loud beeps before the garage door actually starts closing. It then takes over 30 seconds (over 40 seconds from button push) before the state is updated in HA and that is a good 20 seconds or more after the garage door is actually closed.
If I use HA to open/close the garage the state almost immediately goes from closed -> opening -> open and vice versa. I’ve set my automation to trigger on the states (opening, open, closing, closed) so at worst there is a 50 second delay. I’m wondering if others have noticed the same performance difference. I should note that using the garage door remote control I see slightly better results at around 25 seconds vs using the MyQ app.
MyQ has always done this for me. In fact I’m pretty sure there are times HA just didn’t pick up on the opening or closing states and in the history it just goes from open to closed or closed to open with no intermediate step. I believe the integration polls the MyQ API and it doesn’t get status updates except when it asks. I could be wrong though.
This has been my experience as well. Status updates from MyQ to HA have been relatively slow.
Mine constantly bounces between the actual state and unavailable in HA.
Screen Shot 2020-05-14 at 10.07.14 AM
I was about to post. Seems to be unreliable, it’s not ha devs fault though, it’s MyQ. Maybe I’ll just move to smart relays and contact sensors
It will probably start working again in a few days
It’s just a bad product overall. No official API as far as I am aware
Everything else about the garage opener is nice though but their API leaves a lot to be desired. The garage company took my previous z-wave garage door opener with its sensor and threw it away. I didn’t notice it was gone for 2 days and it was too late by the time I called. I need to find another solution now that isn’t another $80. I think it is polling because over the last few weeks of using I have noticed sometimes it is relatively quick.
I checked, and mine is not doing that. Your issue might be the internet connection between your home and the MyQ servers.
Its not currently doing this, just during those days when there were issues.
I’ve got dedicated 1GB fibre coming into the house and constantly check my home assistant with an uptime robot just in case it goes down. So these issues are probably more along the lines that MyQ was misbehaving during that period.
Anyone else having issues? Maybe we can come up with a “is it up/down” service?
Yep, worked when I got home, bit now it’s not. Grr…
The following is my captured log, it appears to be a login issue. I’m able to access the myQ site through the app. I haven’t changed my login information lately. ```
Logger: homeassistant.config_entries
Source: components/myq/init.py:36
First occurred: 7:35:29 PM (1 occurrences)
Last logged: 7:35:29 PM
Error setting up entry xxemail*@xxxxxxx.com for myq
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 217, in async_setup
hass, self
File “/usr/src/homeassistant/homeassistant/components/myq/init.py”, line 36, in async_setup_entry
myq = await pymyq.login(conf[CONF_USERNAME], conf[CONF_PASSWORD], websession)
File “/usr/local/lib/python3.7/site-packages/pymyq/api.py”, line 170, in login
await api.authenticate(username, password)
File “/usr/local/lib/python3.7/site-packages/pymyq/api.py”, line 119, in authenticate
self._security_token = auth_resp[“SecurityToken”]
TypeError: ‘NoneType’ object is not subscriptable
Mine also stopped working about 2 hours ago. I tried removing it and it will not allow me to re-add.
I’m sure they updated the api again. Just checked the app on my phone and it was updated yesterday feom the playstore.
MYQ not working again :frowning:
2020-06-04 23:23:39 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry <usderID> for myq
hass, self
I’m so tire of MYQ breaking all the time. Is there a local api integration available?
A fix for this recent issue has been identified, tested and submitted as a PR to the next version of HA to include. There’s no local API support that I know of.
This is no way to live…
unfortunately, this is how it is unless / until they have a public API that can be used.
Chamberlain is also getting hard-nosed about licensing its private API to further monetize it. Wink had to drop support for MyQ because of new licensing demand. Here’s the notice Wink sent out a few weeks ago…
Dear Wink Community,
Effective June 1st, 2020, Chamberlain will be terminating its partnership with Wink. Newly proposed terms from Chamberlain would have required Wink to generate tens of thousands of new MyQ users each year as well as pay hundreds of thousands of dollars in annual licensing fees.
Wink would have liked to continue its partnership with Chamberlain, but we are unable to meet these demands. Chamberlain was unwilling to agree to more reasonable terms, and they will continue with the termination of all existing Wink + MyQ integrations. Please plan accordingly, as users will no longer be able to control MyQ devices from the Wink platform after June 1st.
We will continue to explore our options with Chamberlain. For questions about this decision and how it affects your Chamberlain products, we encourage you to contact their customer service at: Support
