That did the trick … completed missed it…
Has anyone been able to get the autoconfigure to work?
My Energy Distribution has a fair start, so I thought it would work well with autoconfigure.
However, when I try the code from the Sankey Chart Card github page;
- type: custom:sankey-chart
# ...any other options
autoconfig:
print_yaml: true # optional
# any additional autoconfig options (listed below)
All that I get is;
Here is what it looks like in edit mode;
I’m looking to take advantage of the print_yaml
that “Prints the auto generated configuration after the card so you can use it as a starting point for customization.”
Does anyone have this working, and if so, where am I messing up?
i did the same thing and used the printed yaml. worked fine. let me try a new one.
Edit.
It worked fine again.
new card, sankey, enable print yaml, save. that’s it
I don’t have a battery or low carbon FYI
I’m trying to show how consumption splits into the categories of Transportation (EV charging) and Home (residence), the latter of which splits into Space Heating, Kitchen, and later others once I get some of it working.
So far, the entities are showing up, though no lines are visible.
title: Realtime Energy
show_names: true
min_box_height: 8
height: 500
energy_date_selection: true
sections:
- entities:
- entity_id: sensor.grid_import
color: ‘#4F00C0C’
children:
- entity_id: sensor.load_consumed_energy
- entity_id: sensor.solaroutneg_wh
color: '#e0b400'
children:
- entity_id: sensor.grid_export
- entity_id: whatever321
type: remaining_parent_state
- entities:
name: Total Load Consumption
children:
- entity_id: sensor.transportation_consumption
- entity_id: sensor.home
remaining:
- entity_id: Other-Consumption
- entities:
children:
- entity_id: sensor.120v_ev_charger_total_daily_energy
- entity_id: sensor.juicebox_energy_added
children:
- entity_id: sensor.kitchen_load
- entity_id: IntermediateUnmonitored
name: Intermediate Unmonitored
- entities:
children:
- entity_id: sensor.refrigerator_total_daily_energy
- entity_id: sensor.dishwasher_total_daily_energy
- entity_id: UnmonitoredEnergy
- entities:
- entity_id: RemainingEnergy
Any mistakes jump out at anyone?
And I have tried multiple approaches to getting passthrough
working;
Default (no explicit entry)
Adding passthrough entries in the column they are to ‘passthrough’
Labeling them as passthrough in the final ‘leaf’ column (didn’t expect this to work but tried it anyway.
Currently the most recent code for the Sankey chart (below) that follows #2 approach above has the following error (though the juicebox sensor exists, is populated, ahd has been showing up);
Error: Invalid entity config {“type”:“passthrough”,“children”:[{“entity_id”:“sensor.juicebox_energy_added”}],“entity_id”:“sensor.juicebox_energy_added”}
title: Energy Categories
show_names: true
min_box_height: 8
height: 500
sections:
- entities:
color: ‘#4F00C0C’
children:
color: '#e0b400'
children:
- entities:
children:
remaining:
- entities:
children:
children:
- entity_id: sensor.space_heating
- entities:
type: passthrough
children:
type: passthrough
children:
children:
- entities:
name: Level 2 Charger
name: Level 1 Charger
- entity_id: sensor.heat_pump_kwh
- entity_id: sensor.furnace_kwh
Please tell me what am I missing?
Update to above, determined and resolved the issue. See Update 2 for further issues.
I had incorrectly listed children entities starting with “entity_id:” which is incorrect. My chart now on this mostly rainy/cloudy/snowy day with the woodstove going;
Associated code;
show_names: true
min_box_height: 8
height: 500
sections:
- entities:
color: purple
children:
- sensor.load_consumed_energy
color: '#e0b400'
children:
- sensor.grid_export
- entities:
children:
- sensor.transportation_consumption
- sensor.home_load
- entities:
children:
- sensor.120v_ev_charger_total_daily_energy
- sensor.juicebox_energy_added
- entity_id: sensor.home_load
children:
- sensor.kitchen_load
- sensor.space_heating
- entities:
type: passthrough
children:
type: passthrough
children:
children:
- sensor.refrigerator_total_daily_energy
- sensor.dishwasher_total_daily_energy
children:
- sensor.heat_pump_kwh
- sensor.furnace_kwh
- entities:
Now I can proceed adding all the other appliances and circuits I am (and will be) tracking, as well as figuring out the right was to use remaining_parent_state
Update 2: Alas, the inability to create daily-resetting energy entities seems to be messing up the daily values in the chart. And changing a template from kWh to Wh to get all the algorithm components in the same measurement unit doesn’t seem to actually change the range, it just messes up the value. For example, Transportation_Consumption should be 22Wh instead of 22,000 Wh, which the History shows, which is not reflected in the value in the chart.
So I will likely have to start from scratch if I ever find a way to create daily-resetting energy entities, and advise anyone looking at my chart code above to avoid relying on it for hints and clues.
is there a way to combine 2 separate parts?
my dryer for example, is 240v so uses both lines. it would be great for it to show half from Line1 half from Line 2
You can have it as a child of both but it won’t be split in half. It will be mostly random.
You can create 2 templates in HA “Dryer half 1” & “Dryer half 2” and have “Dryer” as a child of those but that would add new layer where the halves are combined.
Once #8 is done you would be able to do this without an extra layer but you would still need the template entities to say how much comes from each line.
yeah, the visual there, where its selected as a child for each, isnt clear. it makes Other1 small, and leaves the Other2 big (instead of equal out of both) so i ended up creating 2 new entities for each in iotawatt (same idea as the template sensor).
so now i have Line 1, Line 2, BothLines 240v. and then now that subtract works, i subtracted the half of each from both of the Others, and uses the full entity under BothLines
i think you are right about #8 but for now my solution seems to look and feel fine. thanks for the reply. wasnt sure if there was some better way to do it.
Success! After a number of trial and error attempts, I noticed the card I had tried the Autoconfig with now showed a good bit of data (no longer simply failing);
Upon examination of the yaml code, I picked up a number of very helpful hints. While the grid import and export did not show up correctly, I figured out how to adjust those. One template calculation I added is
sensor.total_energy_consumed
And instead of arranging my loads by area, I arranged them by function;
height: 450
show_names: true
unit_prefix: k
round: 1
min_box_height: 3
min_box_distance: 5
show_states: true
show_units: true
sections:
- entities:
type: entity
name: Solar Generation
color: var(--warning-color)
children:
- sensor.total_energy_consumed
- sensor.export_wh
type: entity
color: maroon
children:
- entities:
- entity_id: sensor.export_wh
type: entity
color: purple
children: []
- entity_id: sensor.total_energy_consumed
name: Total Consumption
color: darkblue
children:
- transportation
- space_heating
- water_supply
- kitchen
- offices
- studio
- lighting
- laundry
- entertainment
- unknown
- entities:
- entity_id: transportation
type: remaining_child_state
color: blue
children:
- entity_id: space_heating
color: green
children:
- sensor.heatpump_wh
- sensor.furnace_wh
- sensor.air_filter_energy
- entity_id: water_supply
color: green
children:
- sensor.test3_wh
- entity_id: kitchen
color: green
children:
- sensor.kitchen_ceiling_dimmer_2_energy
- sensor.refrigerator_energy
- entity_id: offices
color: green
children:
- sensor.annoffice_wh
- sensor.work_office_total_daily_energy
- sensor.study_electronics_total_daily_energy
- entity_id: studio
color: green
children:
- sensor.studioplugs_wh
- sensor.studio_musician_lights_energy_2
- entity_id: lighting
color: green
children:
- sensor.front_porch_lights_energy
- sensor.back_porch_light_energy
- sensor.master_bath_light_energy
- sensor.studio_landing_light_energy
- sensor.side_porch_light_energy
- entity_id: laundry
color: green
children:
- sensor.clothes_dryer_energy
- entity_id: entertainment
color: green
children:
- sensor.family_room_tv_energy_2
- entity_id: unknown
color: gray
name: Not Yet Monitored
children: []
- entities:
type: entity
color: blue
children: []
type: entity
color: blue
children: []
- entity_id: sensor.heatpump_wh
type: entity
color: green
- entity_id: sensor.furnace_wh
type: entity
color: green
- entity_id: sensor.air_filter_energy
type: entity
color: green
- entity_id: sensor.test3_wh
type: entity
color: green
- entity_id: sensor.kitchen_ceiling_dimmer_2_energy
type: entity
color: green
type: entity
color: green
- entity_id: sensor.refrigerator_energy
type: entity
color: green
- entity_id: sensor.annoffice_wh
type: entity
name: Work Office 1
color: green
- entity_id: sensor.work_office_total_daily_energy
type: entity
name: Work Office 2
color: green
- entity_id: sensor.study_electronics_total_daily_energy
type: entity
color: green
- entity_id: sensor.studioplugs_wh
type: entity
color: green
- entity_id: sensor.studio_musician_lights_energy_2
type: entity
color: green
children: []
- entity_id: sensor.front_porch_lights_energy
type: entity
color: green
children: []
- entity_id: sensor.back_porch_light_energy
type: entity
color: green
children: []
- entity_id: sensor.master_bath_light_energy
type: entity
color: green
children: []
- entity_id: sensor.studio_landing_light_energy
type: entity
color: green
children: []
- entity_id: sensor.side_porch_light_energy
type: entity
color: green
children: []
- entity_id: sensor.clothes_dryer_energy
type: entity
color: green
- entity_id: sensor.family_room_tv_energy_2
type: entity
name: Family Room TV
color: green
min_state: 0
I’ll be adding more sensors to chase down other yet-unmonitored consumption. And I will see if I can add another layer for Home
for a clean classification to provide the Home
and Transportation
categories
The monthly view checks out well;
I very much appreciate the efforts that @MindFreeze has undertaken to provide this capability!
I’ve updated the chart to cleanly delineate what is Transportation
and what is Home
energy consumption, to see how close I am to residential net-zero (or beyond). Still have some circuits/outlets to meter/monitor and may still find some phantom loads (or ones requiring better oversight). This is a very helpful tool to keep track of electrical energy consumption, can’t say enough nice things about what @MindFreeze has done with this specialty chart!
We had been painted indoors that day, so the Heat Recovery Ventilator was on high for about 48 hours, otherwise just comes on low about an hour every day.
Card works ok when using energy, no matter if 3 of 5 sections.
But when using power the connections get lost quite often.
I’m not yet sure if that’s a result that the card isn’t catching up state changes in time or something like that. I doubt this being the case since the machine idles more or less means it’s surely not related to an extensice load. Any chance one could force the card checking values? Sort of an update_interval as known from ESPhome sensors?
Values are always updated but the client browser can get overloaded with frequent updates and stutter. Try using the throttle option to limit updates.
ups … that was an easy one, it solved the issue straight.
May I ask another thing.Would you mind updating the readme on github? I recently stumbled across a “remaining:” which I wasn’t aware of simply because not being documented. The one to be placed right below the chidrens.
I do fear I likely missed all the 99 dead cool options which are undocumented aswell
Remaining is deprecated and will be removed in a future version. Only works for backwards compatibility. type: remaining_parent_state is the correct way of doing the same thing.
Love this card and this thread has been very helpful to getting this far. One frustrating issue I cannot seem to overcome is color blending and how to make sure the final entities carry the correct color from the parent. No matter what I do, I can’t seem to alter the final blue color and this results in some harsh lines which you can see most clearly in the ‘Second Floor Load’ branch. Anyone have this issue or know what might be causing it? Thank you in advance!
show_names: true
height: 600
unit_prefix: k
round: 2
wide: true
sections:
- entities:
- entity_id: sensor.totalpower
name: Grid Consumption
color: '#e45e65'
remaining:
children:
- sensor.totalac
- sensor.secondfl_load
- sensor.firstfl_load
- sensor.basement_load
- sensor.apt_load
- entities:
- entity_id: sensor.totalac
name: Air Conditioner Load
color: '#e4a15e'
children:
- sensor.ac_1
- sensor.air_handler_1
- sensor.ac_2
- sensor.air_handler_2
- entities:
- entity_id: sensor.secondfl_load
name: Second Floor Load
color: '#e4a15e'
remaining:
children:
- sensor.second_floor
- sensor.sub_pool_floorheat
- entities:
- entity_id: sensor.firstfl_load
name: First Floor Load
color: '#ff2bf8'
children:
- sensor.laundry_primary
- sensor.kitchen_w_livingroom
- sensor.kitchen_apps_dining
- sensor.kitchendw_dinette
- entities:
- entity_id: sensor.kitchen_w_livingroom
name: First Floor West
color: '#ff2bf8'
remaining:
children:
- sensor.living_room_media_plug_power
- entities:
- entity_id: sensor.basement_load
color: '#a6bfbb'
children:
- sensor.navien
- entities:
- entity_id: sensor.apt_load
color: '#54b1f7'
children:
- sensor.apartment
- entities:
- sensor.apartment
- sensor.ac_1
- sensor.ac_2
- sensor.navien
You just have to specify color
for all relevant entities. So use the long form with entity_id:
and color:
instead of just listing the entity id.
Also everyone please stop using remaning:
. It is deprecated. Use type: remaining_parent_state
instead. There are examples in the README.
Since you re-newed the information about remaining: (I removed it straight after your recently given explanation) 2 times within 1 week , may I suggest you mention this on your github, best bet using RED BOLD text saying deprecated or something like that?
Poeple like me tend to a) read the options but also b) look in here for example YAML to get started.
Thank you, appreciate the reply! Incredible work on this. I grabbed ‘remaining’ from earlier messages in this thread without checking the docs on it so thanks for that too.
Updated chart looks much better.
show_names: true
height: 600
unit_prefix: k
round: 2
wide: true
sections:
- entities:
color: '#e45e65'
children:
- sensor.totalac
- sensor.apt_load
- sensor.balance
- entities:
color: '#e4a15e'
children:
- sensor.ac_1
- sensor.ac_2
color: '#e4a15e'
children:
color: '#ff2bf8'
children:
color: '#a6bfbb'
children:
- sensor.navien
color: '#54b1f7'
children:
- sensor.apartment
- entities:
color: '#ff2bf8'
children:
- entities:
- entity_id: sensor.apartment
color: '#54b1f7'
- entity_id: sensor.ac_1
color: '#e4a15e'
- entity_id: sensor.air_handler_1
color: '#e4a15e'
- entity_id: sensor.ac_2
color: '#e4a15e'
- entity_id: sensor.air_handler_2
color: '#e4a15e'
- entity_id: sensor.second_floor
color: '#e4a15e'
- entity_id: sensor.sub_pool_floorheat
color: '#e4a15e'
- entity_id: sensor.laundry_primary
color: '#ff2bf8'
- entity_id: sensor.living_room_media_plug_power
color: '#ff2bf8'
- entity_id: sensor.kitchen_apps_dining
color: '#ff2bf8'
- entity_id: sensor.kitchendw_dinette
color: '#ff2bf8'
- entity_id: sensor.navien
color: '#a6bfbb'
- entity_id: sensor.balance
color: '#e45e65'
