Seeing the same error.
Hi Danema,
I just use this code in the card:
gridrows: auto
grid-template-columns: 100%
This works for me
hope it helps
It would be nice to have there sankey chart also available for esp32 displays (3.5 inch) would be enough
Has anyone seen something similar for small displays?
I’m having trouble using the “convert_units_to” feature to show the electricity costs of all entities.
What I have right now is this (Upper is kWh, lower shall become €):
- title: Elektrizitätskoten (dieses Jahr)
type: custom:sankey-chart
monetary_unit: EUR
electricity_price: 0.3
convert_units_to: monetary
unit_prefix: k
I get it to change the kWh units to €, but it does not do the multiplication with 0,3 (30 Cents/kWh) to get to the correct cost value.
In the Readme on Github there is no example unfortunately that shows how to use this feature.
Looking at the code, this might happen if your devices don’t have unit_of_measurement=kWh . This would be a bug. You can submit a bug report here in Github
I used (utility meter) helper to read the energy value of my sensors and separate them into years, month and days by periodically resetting.
I’d gladly help tracking this bug.
What informations (sources) do you all need?
I’m new to HASS and not firm in what data and code snippets to gather.
the whole code of the sankey is this:
title: Stromkosten (dieses Jahr)
monetary_unit: EUR
electricity_price: 0.31
height: 300
unit_prefix: k
round: 2
min_box_height: 1
min_box_distance: 30
show_states: true
show_units: true
sort_by: state
sort_dir: desc
show_names: true
min_state: 0
show_icons: false
wide: true
static_scale: 0
sections:
- entities:
- entity_id: sensor.energieverbrauch_gesamt_jahrlich
color: red
children:
- sensor.energie_elektroherd_jahrlich
- sensor.energie_kuhlschrank_jahrlich
- sensor.energie_pc_jahrlich
- sensor.energie_server_jahrlich
- sensor.energie_waschmaschine_jahrlich
- sensor.energie_waschetrockner_jahrlich
- sensor.energie_tv_jahrlich
remaining:
name: für sonstige Verbraucher
- entities:
- type: entity
children: []
entity_id: sensor.energie_elektroherd_jahrlich
name: für Elektroherd
color: red
- type: entity
children: []
entity_id: sensor.energie_kuhlschrank_jahrlich
name: für Kühlschrank
color: red
- type: entity
children: []
entity_id: sensor.energie_pc_jahrlich
name: für PC Arbeitsplatz
color: red
- type: entity
children: []
entity_id: sensor.energie_server_jahrlich
name: für Serverschrank
color: red
- type: entity
children: []
entity_id: sensor.energie_waschmaschine_jahrlich
name: für Waschmaschine
color: red
- type: entity
children: []
entity_id: sensor.energie_waschetrockner_jahrlich
name: für Wäschetrockner
color: red
- type: entity
children: []
entity_id: sensor.energie_tv_jahrlich
color: red
Hi everyone,
Loving this chart. But I’m wondering if there’s an option to align the data of the children to the mother entity?
So the picture on the left is what is automatically generated from my HA data. I used some very bad paint skills to show what I want to achieve in the picture on the right.
→ Is this possible or would this be a feature request?
There is a similar feature request already
@PieterVandenBerge
Another solution could be to ‘repeat’ the ones you can (eg the ‘1kWh injected to grid’ and the ‘5kWh battery charging’) and create another block for whatever remains out of the 9kWh house consumption after you deduct the dryer, washer, garage and climatecontrol to e.g. an ‘other’ bucket of 5.89kWh, on the right.
(so basically all three ‘vertical’ levels’ have the same total)
Household energy flow is almost working stable. My biggest problem has been coping with having a greater discharge than charge in any time frame, as that messes up the sankey code (can’t have a child bigger than the parent).
I’ll add code in comment.
I have now updated to version 2.0.0 and with the configuration I used before without problems on version 1.21.1 I am given a circular reference.
I can’t figure out what the problem is, this is my current configuration:
Configuration
monetary_unit: EUR
electricity_price: 0.24
min_state: 0.00001
show_names: true
wide: true
energy_date_selection: true
height: 550
unit_prefix: k
round: 2
min_box_height: 3
min_box_distance: 10
show_states: true
show_units: true
show_icons: true
throttle: 5000
sections:
- entities:
- type: entity
remaining:
name: Notte (non monitorato)
children:
- sensor.shellyem_055fbd_channel_2_energy
- sensor.potenza_istantanea_varie_utenze_energy
entity_id: sensor.shellyem_055fbd_channel_1_energy
- entities:
- type: entity
color: purple
children:
- sensor.caldaia_energy
entity_id: sensor.shellyem_055fbd_channel_2_energy
remaining:
- type: entity
color: green
children:
- virtuale_luci
- virtuale_network&IoT
- virtuale_tv
- sensor.macchina_caffe_energy
entity_id: sensor.potenza_istantanea_varie_utenze_energy
remaining:
sort_by: state
sort_group_by_parent: true
- entities:
- type: remaining_child_state
color: yellow
entity_id: virtuale_luci
children:
- sensor.luce_soggiorno_energy
- virtuale_luci_cucina
- virtuale_luci_bagno
- sensor.interruttori_e_switch_iot_energy
- virtuale_luci_camera_alfa
- virtuale_luci_balconi
- virtuale_luci_lavanderia
- virtuale_luci_salotto
name: Rete e dispositivi IoT
color: RGB(255, 153, 80)
entity_id: virtuale_network&IoT
children:
- sensor.nas_synology_ds920_energy
- sensor.access_point_deco_zona_alfa_energy
- sensor.access_point_deco_zona_beta_energy
- sensor.router_huawei_4g_energy
- sensor.echo_dot_camera_energy
- sensor.echo_dot_cucina_energy
- sensor.echo_dot_soggiorno_energy
color: RGB(255, 130, 200)
entity_id: virtuale_tv
children:
- sensor.tv_salotto_energy
- sensor.amplificatore_salotto_energy
- sensor.apple_tv_energy
sort_by: state
- entities:
color: yellow
entity_id: virtuale_luci_bagno
children:
- sensor.faretti_bagno_alfa_energy
- sensor.bagno_alfa_energy
color: yellow
entity_id: virtuale_luci_cucina
children:
- sensor.tavolo_cucina_energy
- sensor.faretti_cucina_energy
name: Luci camera Alfa
color: yellow
entity_id: virtuale_luci_camera_alfa
children:
- sensor.luce_camera_destra_energy
- sensor.camera_ingresso_energy
- sensor.camera_pianoforte_energy
- sensor.luce_camera_sinistra_energy
color: yellow
entity_id: virtuale_luci_balconi
children:
- sensor.balcone_salotto_energy
- sensor.balcone_soggiorno_energy
- sensor.balcone_cucina_energy
- sensor.balcone_camera_energy
name: Luci lavanderia
color: yellow
entity_id: virtuale_luci_lavanderia
children:
- sensor.lavanderia_ripostiglio_energy
- sensor.lavanderia_striscia_led_energy
color: yellow
entity_id: virtuale_luci_salotto
children:
- sensor.divano_destro_energy
- sensor.divano_sinistro_energy
- sensor.scrivania_energy
sort_by: state
- entities:
- entity_id: sensor.macchina_caffe_energy
color: brown
icon: mdi:coffee
- entity_id: sensor.caldaia_energy
color: red
icon: mdi:water
sort_by: state
I hope someone can give me some tips to identify the problem.
Had the same issue, I created a powercalc group for the entities as a workaround.
Bug. I think I fixed it in v2.0.1
Thanks for the very quick response @MindFreeze, I updated to the new version, now the error message no longer appears but the graph is not seen correctly.
Example before:
Example now:
I tried changing browsers but nothing changes.
Thanks for the feedback. Working on it. You can track the progress here Maximum call stack · Issue #171 · MindFreeze/ha-sankey-chart · GitHub
Great, thanks.
Does anyone know how to get back to an old version via HACS? When I try to select an old version it automatically repositions me on the last available one and therefore I cannot install 1.21.1.
Just released v2.0.2 . Hopefully that fixes your connections
Now everything seems to be working properly, thanks
