Con
(Con van Doornik)
January 24, 2023, 7:54pm
2254
Clearly, is it then possible to apply an “if then”, for example;
series:
if states(“sensor.dag_afname”, > 0):
entity: sensor.dag_afname
type: column
unit: ’ W’
color: darkviolet
group_by:
func: max
duration: 1d
else:
entity: sensor.dag_lever
type: column
unit: ’ W’
color: violet
group_by:
func: max
duration: 1d
endif:
entity: sensor.dag_zon
type: column
unit: ’ W’
color: green
group_by:
func: max
duration: 1d
entity: sensor.dag_gebruik
type: column
unit: ’ W’
color: red
group_by:
func: max
duration: 1d
pmgsrosa
(Pedro Rosa)
January 25, 2023, 8:13pm
2255
Great addition for Home Assistant
I’m using it for several charts. Some of them have have positive and negative values.I have two questions regarding those charts:
Is there a way to draw a line at x=0 (even with a different line thickness), so that the zero line is always visible?
Is there a way to have dashed line on precise values, that is on 100, 200, etc… and not saying that i want 4 or 5 dashed lines? (because that depends on the maximum and mimum values).
Thanks.
Pedro.
Do you mean x=0 or y=0?
Play around with this code and see if it helps.
apex_config:
annotations:
position: back
yaxis:
- 'y': 200
strokeDashArray: 5
borderColor: '#f7a6af'
borderWidth: 1
pmgsrosa
(Pedro Rosa)
January 25, 2023, 8:47pm
2257
Thanks, that’s it! … and yes it’s y=0.
annotations:
position: front
yaxis: back
- 'y': 0
strokeDashArray: 0
borderColor: '#FFFFFF'
borderWidth: 1.5
bodaw
(Bodaw)
January 26, 2023, 11:29am
2258
Hello, I like the data labels in my chart, however I would like to display them only in case that the value > 0
- entity: sensor.ote_sell_price
yaxis_id: first
type: column
unit: CZK
color: Green
show:
datalabels: true
group_by:
duration: 1hour
func: max
is there a way how to disable them based on value?
Kertz1954
(Kertz1954)
January 26, 2023, 12:17pm
2259
This should do it. Add code to the end of your chart.
apex_config:
dataLabels:
enabled: true
formatter: |
EVAL:function(value) {
if (value <= 0){
value = ''
return value;
ThomasM
(Thomas Mutzl)
January 26, 2023, 5:45pm
2260
Just found this amazing graph card the other day. Thanks for all the effort bringing this to HA!
Is it somehow possible, to dynamically change the span.offset dynamically based on a condition?
graph_span: 2d
span:
start: day
offset: +1d
The offset should be +1d or +0d depending of the current time.
Before 14:00 I want to show yesterday + today.
After 14:00 today + tomorrow.
Edit: at 14:00, new data for the next day is added. So I guess, I can easily solve that by changing it to
graph_span: 2d
span:
end: day
ThomasM
(Thomas Mutzl)
January 26, 2023, 9:13pm
2261
Can someone help me with annotations and labels. please?
apex_config:
annotations:
position: back
yaxis:
- 'y': 35
strokeDashArray: 5
borderColor: red
label:
text: EVN
xaxis:
- x: new Date('2023-01-27T06:00:00Z').getTime();
borderColor: blue
label:
text: target
The horizontal line works.
But the vertical doesn’t. I guess, I didn’t get the expression right.
Also I would like to know, how I can bring entities into the annotation.
Instead the constant “35” it should be an entity value.
Same of course for the Date in the x-axis annotation.
tango259
(Tango259)
January 27, 2023, 12:43am
2262
Is it possible to show the current state of an entity when grouping series by day? My chart ends with yesterday, assumably since today hasn’t finished. I’d like to show today at the end and have it dynamically change as the value increases. Am I missing something or is this just not possbile?
type: custom:apexcharts-card
graph_span: 5d
span:
end: minute
header:
show: true
title: Feeding Totals
series:
- entity: sensor.total_daily_feeding_amount
yaxis_id: amounts
extend_to: now
curve: smooth
name: Daily Feeding Amount
type: line
group_by:
duration: 1day
func: max
attribute: daily_bottles
yaxis_id: bottles
extend_to: now
type: column
unit: bottles
group_by:
func: max
duration: 1day
yaxis:
- id: amounts
decimals: 0
min: 340
max: 500
apex_config:
tickAmount: 3
- id: bottles
opposite: true
decimals: 0
max: 10
min: 6
apex_config:
tickAmount: 4
Trying to udnerstand this
This is how my code looks now:
yaxis:
- min: 0
max: ~3
apex_config:
forceNiceScale: true
Can I have the max: ~3
and still use your code?
HA_n00b
(HA n00b)
January 27, 2023, 8:46am
2264
Tbh, no idea. You can try though. If that fixes the issue. I’m not an expert
complex1
(Frank)
January 27, 2023, 10:43am
2265
For this, you need to install the (HACS) “config-template-card” card first and then something like:
Your question about xaxis I can not answer, because I do not use this, but I guess it’s almost the same as yaxis.
type: vertical-stack
cards:
- type: custom:config-template-card
entities: sensor.huidige_stroomprijs
variables:
average: states['sensor.huidige_stroomprijs'].attributes.average
card:
apex_config:
annotations:
position: back
yaxis:
- 'y': ${average}
strokeDashArray: 5
borderColor: var(--primary-color)
label:
text: ${average}
style:
background: var(--accent-color)
color: white
Goodday all,
I found a graph which I like, but no configuration available.
Who can help me creating this, or an example which shows the same?
I want to show 2 sensors in one bar, but they don’t need to be counted (if that is correct English).
This is what I’m looking for (but no config)
This is what I made, but this is not correct.
apex_config:
chart:
stacked: true
graph_span: 31d
span:
end: day
show:
last_updated: true
header:
show: true
show_states: true
colorize_states: true
title: Prijsplafond Januari
series:
- entity: sensor.monthly_net_consumption_streetadress_streetnumber
name: Deze maand verbruikt
type: column
unit: kWh
color: green
group_by:
func: max
duration: 1d
- entity: sensor.resterend_energieverbruik_mbt_prijsplafond
type: column
unit: kWh
color: red
group_by:
func: max
duration: 1d
I really would like to have the same as the 1st snapshot.
Where to find an example please, I tried to scroll through 2K posts here, but I guess this is way faster
Thank you
Kertz1954
(Kertz1954)
January 27, 2023, 11:12am
2268
Edit your post and include your code.
I found this picture, and have no code.
That is why I ask for help, I am looking for code which creates this example
Thanks @Kertz1954
ThomasM
(Thomas Mutzl)
January 27, 2023, 11:46am
2270
Unbelievable, that I missed the Config-Template-Card.
Thank you so much!
The xaxis is still not working, though.
I reduced the yaml a bit, so only the relevant parts remain:
variables:
CAP: 28
TARGET_TIME: new Date('2023-01-27T18:00:00Z').getTime()
entities:
- null
card:
graph_span: 1d
span:
end: day
now:
show: true
label: Now
show:
last_updated: true
series:
- entity: sensor.awattar_at
type: area
opacity: 0.3
curve: stepline
extend_to: false
color: rgb(3, 169, 244)
data_generator: |
var data = entity.attributes.Data;
var lastEntry = data[data.length - 1];
// add extra slot (=point) so last slot has a line for duration in chart
var extraEntry = { "Start": lastEntry.End, "End": lastEntry.End, "PriceCentPerKwh": lastEntry.PriceCentPerKwh };
data.push(extraEntry);
return data.map((entry, index) => [new Date(entry.Start).getTime(), entry.PriceCentPerKwh * 1.2]);
yaxis:
- id: price
min: 0
max: ~40
decimals: 0
apex_config:
tickAmount: 4
apex_config:
annotations:
position: back
yaxis:
- 'y': ${CAP}
strokeDashArray: 5
borderColor: rgb(224, 0, 27)
label:
text: ${TARGET_TIME}
xaxis:
- x: ${TARGET_TIME}
borderColor: blue
label:
text: Target
The label in the horizontal annotation is for debug only and shows that the TARGET_TIME
is calculated correctly.
OzGav
(Oz Gav)
January 27, 2023, 12:54pm
2271
You said you created something so please post that.
higgis
(Henrik Davidsson)
January 27, 2023, 2:38pm
2272
Trying to learn to program in the home assistant:-) have added an apex card with prices from the north pole have also made my own sensor where I can find out which 3 hours are the most expensive of the day.
I would like to be able to mark these three hours in the bar chart, but I cannot find or understand how to proceed.
Kertz1954
(Kertz1954)
January 27, 2023, 4:06pm
2273
Can you edit your post and add an image, plus your coding. Thanks.
Tyfoon
(@Tyfoon)
January 27, 2023, 4:18pm
2274
Good question. I now do it by adding that info on top of the chart. In my case these are 2 hour slots avail in 12/24 hours and the secondary is within 6 hours.
Code
type: custom:stack-in-card
cards:
- type: horizontal-stack
cards:
entity: sensor.avg_energy_price
secondary: >
{{ states('sensor.lowest_price') | round(1) }}/{{
states('sensor.highest_price') | round(1) }}
primary: |
{{ states('sensor.avg_energy_price_CNT') | round(2) }} €
icon: mdi:power-plug
icon_color: orange
tap_action:
action: more-info
entity: sensor.hours_low_coming
secondary: |
{{ states('sensor.hours_low_coming_short') | round(0) }} urgent
primary: >
{{ states('sensor.hours_low_coming') | round(0) }}/{{
states('sensor.hours_low_coming_far') | round(0) }} H
icon: mdi:clock-check
icon_color: orange
tap_action:
action: more-info
entity: sensor.zonneplan_current_gas_tarriff_fixed
secondary: |
Gas
primary: >
{{ states('sensor.zonneplan_current_gas_tarriff_fixed') | round(2) }}
icon: mdi:gas-burner
icon_color: orange
tap_action:
action: more-info
variables:
MOVINGAVERAGE: states['sensor.avg_energy_price_cnt']
entities:
- ${MOVINGAVERAGE.entity_id}
card:
apex_config:
chart:
height: 200px
fontFamily: Raleway,sans-serif
xaxis:
labels:
format: HH
legend:
show: false
stroke:
width: 2
plotOptions:
bar:
columnWidth: 100%
grid:
show: true
borderColor: '#00000030'
strokeDashArray: 4
position: back
dataLabels:
offsetY: -8
background:
opacity: 0.01
enabled: true
foreColor: '#CF7524'
padding: 2
borderRadius: 4
borderWidth: 0
style:
fontSize: 9px
color: rgb(200,200,200)
experimental:
color_threshold: true
graph_span: 30h
span:
start: day
offset: +4h
update_interval: +1h
header:
title: Zonneplan Forecast
show: false
now:
show: true
label: NOW
series:
- entity: sensor.zonneplan_current_electricity_tariff
color_threshold:
- value: ${MOVINGAVERAGE.state * .75}
color: '#228B22'
- value: ${MOVINGAVERAGE.state * 1}
color: '#d35400'
- value: ${MOVINGAVERAGE.state * 1.25}
color: '#c0392b'
show:
extremas: true
type: column
float_precision: 2
data_generator: |
return entity.attributes.forcast.map((entry) => {
return [new Date(entry.datetime).getTime(), entry.price /100000] ;
yaxis:
- id: '1'
decimals: 1
min: 10
apex_config:
tickAmount: 4
