ApexCharts card - A highly customizable graph card
Anyone know how to use xaxis annotations? I cannot get it to work.
I want to draw a vertical line at certain point in the xaxis. I tried ‘20:00’ and ‘20:00:00’, both don’t work.
That looks like a total from feeding a newborn. Do you have an integration behind these sensors? if so, which is it?
As you might have seen a few posts above, I am also struggling with xaxis annotations.
I used a timestamp for the x-value, though. Didn’t work.
Maybe it’s a bug?
I don’t know, but @markcocker was able to create xaxis annotations in the past, see his post below. Probably it must use “template” and use function call to get the correct X timestamp? I tried many different values, no luck.
ApexCharts card - A highly customizable graph card - Share your Projects! / Dashboards & Frontend - Home Assistant Community (home-assistant.io)
Thanks for this sample.
Tried to do the same. But to no avail. :frowning:
My vertical annotation example. I will paste the code on Saterday. Time for a late dinner !!
apexcharts_annotations
type: custom:config-template-card
variables:
  mytime: new Date().getTime()
entities:
  - sensor.time
card:
  type: custom:apexcharts-card
  graph_span: 4h
  cache: true
  span:
    end: hour
  show:
    last_updated: false
    loading: false
  yaxis:
    - show: false
      min: ~0
      max: ~1
      decimals: 0
      apex_config:
        tickAmount: 6
  series:
    - entity: sensor.energy_consumption_hourly_total
      float_precision: 3
      type: column
      fill_raw: zero
      group_by:
        fill: last
        duration: 1h
        func: last
      color: '#90EE90'
      show:
        legend_value: true
        in_header: true
        name_in_header: true
        header_color_threshold: false
        in_chart: true
        datalabels: true
        hidden_by_default: false
        extremas: false
  apex_config:
    annotations:
      position: front
      yaxis:
        - 'y': 0.51
          y2: 0.52
          strokeDashArray: 0
          borderColor: '#0000bb'
          fillColor: '#0000bb'
          opacity: 0
          label:
            borderColor: '#8B4000'
            borderWidth: 2
            text: My vertical annotation example - Current time >
            position: right
            offsetX: 0
            offsetY: -35
            style:
              background: '#0000bb'
              color: '#ffffff'
              fontSize: 16px
      xaxis:
        - x: ${{ mytime }}
          strokeDashArray: 0
          opacity: 0.9
          offsetX: 0
          offsetY: 10
          label:
            borderWidth: 1
            text: ${{states['sensor.time'].state}}
            position: top
            orientation: vertical
            textAnchor: middle
            style:
              color: '#ffffff'
              fontSize: 16px
    chart:
      height: 250
      type: bar
    plotOptions:
      bar:
        borderRadius: 5
        dataLabels:
          position: top
    dataLabels:
      enabled: false
      zoom:
        enabled: false
      toolbar:
        show: false
        tools:
          download: true
          zoom: true
          zoomin: false
          zoomout: false
          pan: false
          reset: true
    tooltip:
      enabled: false
      theme: light
      style:
        fontsize: 6px
      onDatasetHover:
        highlightDataSeries: true
      x:
        show: true
        format: ddd dd MMM yyyy HH:mm
      marker:
        show: true
      fixed:
        enabled: true
        position: topRight
        offsetX: -10
        offsetY: 0
    grid:
      show: true
      strokeDashArray: '0'
      borderColor: '#666666'
      xaxis:
        lines:
          show: false
      yaxis:
        lines:
          show: true
    xaxis:
      labels:
        show: true
        rotate: 10
        rotateAlways: true
        style:
          colors: '#ffffff'
          fontSize: 14px
        format: HH:mm
        offsetX: 0
        offsetY: 5
      position: bottom
      showDuplicates: false
      axisBorder:
        show: true
        color: yellow
        height: 1
        width: 100%
        offsetX: 0
        offsetY: 5
      axisTicks:
        show: true
        color: yellow
        height: 6
        offsetX: 0
        offsetY: 0
      title:
        text: ${{'ApexCharts X & Y Annotation Example'}}
        style:
          fontSize: 20px
          color: '#fff000'
    legend:
      show: true
      showForSingleSeries: false
      position: top
      horizontalAlign: center
      fontSize: 30px
      offsetX: 0
      offsetY: 0
      labels:
        useSeriesColors: true
      onItemClick:
        toggleDataSeries: false
      onItemHover:
        highlightDataSeries: false
Thank you sooo much, @Kertz1954 !
The issue is: x-Axis annotations don’t work, if you have now enabled.
As soon, as I set
  now:
    show: false
    label: Now
all the other vertical annotations became visible!!
I have a wired issue with some of the old data in one series not loading until I edit the dashboard. So when loaded normally some time (most of the times) older data is not loaded (or at least shown as 0), but when I then click edit dashboard I see how the chart is refreshing data and the old missing data point show up. Click done and it goes blank again.
In the video you can see what I mean, look at the left part of the graph where the grey area comes and goes.
This is the whole data used to configure the graphs.
type: custom:vertical-stack-in-card
cards:
  - type: custom:mini-graph-card
    align_state: center
    decimals: 1
    entities:
      - entity: sensor.electricity_price_total
    show:
      icon: false
      graph: false
  - type: custom:apexcharts-card
    now:
      show: true
      color: red
    graph_span: 3d
    hours_12: false
    span:
      start: day
      offset: '-1d'
    all_series_config:
      type: area
      extend_to: false
    yaxis:
      - id: SEK
        min: 0
        apex_config:
          tickAmount: 5
      - id: Heater
        min: 0
        max: 1
        show: false
        apex_config:
          tickAmount: 5
      - id: kWh
        min: 0
        max: 10
        show: false
        apex_config:
          tickAmount: 5
    apex_config:
      chart:
        type: area
      height: 300
      legend:
        show: false
      tooltip:
        x:
          format: dddd HH:00
      xaxis:
        type: datetime
        labels:
          datetimeFormatter:
            month: ddd
            day: ddd
        tooltip:
          enabled: false
      fill:
        type: solid
        opacity: 0.2
    series:
      - entity: sensor.run_heater_when
        yaxis_id: Heater
        color: '#777'
        stroke_width: 0
        curve: stepline
        data_generator: |
          return entity.attributes.heater.map((p) => {
            let when = new Date(p.startsAt);
            when.setHours(when.getHours());
            return [when, p.value];
        yaxis_id: Heater
        name: Heater Yesterday
        color: '#777'
        stroke_width: 0
        curve: stepline
        group_by:
          func: max
          duration: 60min
        transform: 'return x == "on" ? 1 : 0;'
      - entity: sensor.last_meter_consumption_osthammar
        yaxis_id: kWh
        type: column
        color: '#932bd9'
        float_precision: 1
        stroke_width: 2
        offset: '-1h'
        group_by:
          func: delta
          duration: 1hour
        yaxis_id: SEK
        curve: stepline
        color: '#2b76d9'
        stroke_width: 2
        float_precision: 2
        group_by:
          func: avg
          duration: 1hour
      - entity: sensor.tibber_prices
        yaxis_id: SEK
        stroke_width: 2
        curve: stepline
        color: '#2b76d9'
        float_precision: 2
        data_generator: >
          var items = [];
          var gridFees =
          parseFloat(hass.states['input_number.electricity_grid_fees'].state);
          var now = new Date();
          now.setHours(now.getHours() - 1);
          entity.attributes.today.forEach((p) => {
            items.push([new Date(p.startsAt), p.total+gridFees]);
          entity.attributes.tomorrow.forEach((p) => {
          return items.filter((item) => {
            return item[0] > now;
This is the series with missing data points in normal mode
        yaxis_id: Heater
        color: '#777'
        stroke_width: 0
        curve: stepline
        data_generator: |
Does anyone have any idea what could be causing this behaviour?
Thanks @Kertz1954 after playing around without your code, I realized the “x” must have that value from JavaScript getDate() function. So, obviously we cannot use text like ‘20:00’ :slight_smile:
To set x: to a specific time in xaxis, we can use “setHours(hour, [min], [sec], [ms])
What I don’t get from your sample:
Why are you using double curly braces ${{ x }} ?
Isn’t the syntax just ${ x } ?
Just a habit of mine. I write and test a lot in the template editor which requires 2 curly braces.
ApexCharts will accept 1 or 2 curly braces. :slightly_smiling_face:
We use the BabyBuddy add-on and integration, then I do some additional API calls through Node-RED to get additional stats. You can DM me for more info if you’d like. Highly recommend.
As far as the card, I may just add current stats for the day via stack-in-card so at least it’s all together.
Hi, has anyone an idea why the tooltip is only showing 1 series (or the blue or the orange) and not both together?
Code is the same for this graph where it nicely shows both series …
Ohh… so then is there no way to change the values that are displayed in the header?
I have a graph that shows the total energy consumption per device type for the last day. I would like to display the sum for the entire day in the header rather than just the last value of the sensor.
I though this should be possible by writing a data_generator under the series.show.in_header option. Here is my apexcharts config, but I’ve struggled writing the javascript as it doesn’t seem like it’s possible to use the Studio Code Server?
header:
  show: true
  title: Device energy consumption
  show_states: true
  colorize_states: true
show:
  last_updated: false
stacked: true
graph_span: 24h
span:
  start: day
yaxis:
  - min: 0
series:
  - entity: sensor.total_mill_energy
    type: column
    group_by:
      func: diff
  - entity: sensor.total_hot_water_energy
    type: column
    group_by:
      func: diff
  - entity: sensor.total_tesla_charging
    type: column
    group_by:
      func: diff
@benm6 please share your code for this card?
I have the same problem. 2 charts, identical with the exception that one uses the statistics (LTS) option within the series, which does show all series in the tooltip correctly.
A thought occured that maybe the data had different time values when written to the DB. A quick test on the X: showing ddd dd MMM HH:mm s fff (in my case for 3 series) had all the same values, so it’s not a timing issue when the data is written to the DB.
That leaves just two other possibilities,
The current HA intergration may not be using latest version of ApexCharts which is is 3.36.0, dated Oct 23 2022), so if it was a bug, maybe it’s been fixed.
Or there is still an outstanding a bug. There are presently 231 open issues with ApexCharts. Unfortunatly, I do not have the time to read through them. ApexCharts issues
Thanks for the tip! I’ll look into it, though with newborn twins, I don’t know if I’ll have to configure something like this :joy:
Is there absolutely no way to summarize the amounts in the tooltip?
In this case I want to show “0,49 + 0,82 = 1,31
Another thing, the dotted line from the tooltip is never shown in the middle of the bar, can that be done?
Is there any way to change the font size of the texts in the header section?
As I have mentioned in previous posts, the Header is an HA add on and is not part of the original ApexCharts system. You need to jump over to the Card-mod - Add css styles to any lovelace card page where I am sure you will find what you are looking for. :slightly_smiling_face:
