Perfect! Thank you. It looks like that config works with dark_sky too.
You can do some funny stuff like:
- type: custom:apexcharts-card
graph_span: 8d
span:
start: day
offset: -3d
header:
show: true
title: Temperature Forecast
show_states: true
now:
show: true
label: 'now'
apex_config:
legend:
show: false
series:
- entity: weather.openweathermap
unit: °C
attribute: temperature
fill_raw: last
extend_to_end: false
group_by:
func: avg
duration: 1h
type: line
unit: °C
show:
in_header: false
data_generator: |
return entity.attributes.forecast.map((entry) => {
return [new Date(entry.datetime).getTime(), entry.temperature];
Wow that is cool, I’m adding that!
Beautiful card, I use it for all my temperature. One question, is it possible to have the maximum and minimum values for each sensor in the header? I have 2 sensors for each card and in the header I have on the left the current temperature for sensor 1, on the right the current temperature for sensor 2. It is possible to have under the respective current temperatures, even the maximum and minimum temperature of each sensor ?
Thanks. I’ll try and get that inserted tonight.
I honestly think that ApexCharts is the most exciting that I have come across since I started with Home Assistant over a year go. Amazed by the possibilities and I think we are going to see some mind blowing results with this!
@RomRider, the work you put in this and the help you give in this thread here is so much appreciated! Do you have a PayPal account or similar, I would be happy to send you a Friday beer as a gratitude for all this and the help you give. If you have, please let me know and I’m sure others will folow too.
I assume I’m missing something, but what? I can get “tickAmount” to work as intended on yaxis, but not on xaxis. Setting it does not affect the graph. Perhaps not intended to work on a time axis…?
Simplified card with axis config only:
type: 'custom:apexcharts-card'
header:
show: false
series:
- entity: sensor.hue_temperatur_balkong
apex_config:
xaxis:
tickAmount: 3
yaxis:
tickAmount: 3
Ah, I see. I was wondering why opacity was not working. Wish I had read the buglist before I spent hours trying to get it to work. Thank you @RomRider for clarifying. Do you actually do anything else with your life other than answer hundreds of questions, queries, improvements and bugs?
Haha, yeah, I have a real job which is definitely not being a developer, you’d know if you had a look at the code
But I don’t sleep much, it’s cheating
There’s a feature request already for that, I didn’t make my min on how I’ll do it yet
I appreciate the words, thanks as I said a bit above, I do this for fun and my reward is you, users, using this card.
I’d rather you spend that money on charities instead
The ApexCharts doc says that it doesn’t work on datetime charts like you use for the x-axis:
Note: tickAmount doesn’t have any effect when xaxis.type = datetime
So I guess it’s not possible
What a Guy ! I’d second the offer to buy you a virtual beer if you PM a paypal addy. After all, you do seem to be doing this for charity and putting a huge amount of effort for tens maybe hundreds of forumites . Anyway upto you.
I guess I could extend the fill_raw
feature to support data_generator to fill the gaps. Would that work for you?
Or even simpler, you return 0 (or don’t return anything) instead of null when the data is null. I don’t know what null means for precipitation in your case: is it actually 0? Or is it really missing data and the integration doesn’t know what value it should be?
It’s not so complex in reality
Remove null entirely:
data_generator: |
return entity.attributes.forecast.flatMap((entry) => {
if (entry.precipitation === null) return [];
return [[new Date(entry.datetime).getTime(), entry.precipitation]];
Return 0 instead of null:
data_generator: |
return [new Date(entry.datetime).getTime(), entry.precipitation || 0];
Right Yeah I looked at those options at various points and they were a bit of a hassle. Anyway, very happy that you have cracked a comprehensive charting solution.
How would this work for selecting the sensor? I tried the below which doesn’t work…
graph_span: 24h
apex_config:
plotOptions:
pie:
donut:
total:
show: true
showAlways: true
formatter: sensor.daily_energy_house_total
span:
start: day
offset: '-1d'
header:
show: true
title: Power consumption daily
chart_type: donut
series:
- entity: sensor.daily_energy_boiler_total
- entity: sensor.daily_energy_dishwasher_total
@RomRider I tried to use are type of chart to draw my router throughput with fill and nice gradient, by I come to somehow strange, unexpected result:
As you can see direction of gradient in bottom and upper parts is the same (with colored part up and blackened down), while I’d expect colored part of gradient to be towards peaks of graph. Is this Apex bug or something controllable?
Here is teh code I use for this setup:
show:
loading: false
apex_config:
stroke:
width: 2
chart:
height: 250
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0.8
stops:
- 0
- 500
inverseColors: false
header:
show: false
graph_span: 5min
series:
- entity: sensor.internet_speed_in1
color: var(--light-magenta)
type: area
- entity: sensor.internet_speed_out1
color: var(--yellowish)
invert: true
type: area
BTW, for my use this is the most amazing card available for HA at the moment! My wish come to live! Thank you so much for AWESOME work you did bringing this to community!
Thx, fill_raw is the easy way as it will work “always”
did test your 2 scripts. first:
second:
second option works out…
thanks…
Hello all.
RomRider! those graphs are sick! Thank you very much for your work.
I have a question, maybe not exactly related to those graphs, but after ApexCharts appeared I came to idea of monitoring ISP quality pinging some selected hosts.
I figured out, that if several consecutive ping failures are registered into binary sensor, those are not counted. I suppose it is how it should work indeed, cause binary_sensor state is changing for the first registered failure, then does nothing until ping succeeds.
Two ideas came in my mind:
To count number of failures storing them into sensor then reset every hour (to get totals per hour). It has one cons, that counter are reset at data generation stage not on presentation layer.
Another idea is to reset state of binary sensor after every failed ping.
But maybe there better way? I’m asking before I jump into inventing the wheel.
this is a draft of what I’m goint to achieve. it works but obviously doesn’t count consecutive failures
Thank you in advance
If there’s no new state writen (it could be off and still have consecutive off state written in the history), there’s not much you’ll be able to do even with automation / other template sensors. I don’t know how the ping binary_sensor works under the hood so not sure I can help.
It’s always from bottom to top if you use shade. Not much I can do, as that’s how it’s supposed to work in Apexcharts.
Instead you can try opacityFrom and opacityTo which supports arrays (one array item per serie) and thus you could invert them for one of the 2 series
Understood. Thank you for answer.
Now I went the road down toward counting messages (failures) and resetting counter periodically. For test purposes I’m testing not existent IP. This way I’ve get 4 failed pings per 15 secs.
Now I have doubts how it works. Dev tools definitively shows the state is published to HA (I’ve added timestamp as attribute). So during a minute I have state reports, however with the same value.
But it strangely calculates sum
graph_span: 60m
series:
- entity: sensor.isp4_fail_counts
type: column
group_by:
func: sum
duration: 1min
It should show 16 per minute… but still shows 4
It’s even more strange when using ‘fill’ option:
graph_span: 60m
series:
type: column
group_by:
func: sum
duration: 1min
fill: 'zero'
This hight bar has value 87, which are 2 consecutive values: 83 and 4 recorded in history. Then following “fours” are recorded but somehow ignored by the graph
Other ‘random’ trials suggests that repeating values are treated as non-existing ones. But it’s my rough guess. Obviously I’m missing something.
Edit: I’ve checked HA history… indeed this “4” is recorded only once.
then how work with same values and missing ones?
