Again…204v1 precedes 204 and your screenshot does not show in any way the documentation citing to add ‘change’…so where did you find this…link please
EDIT: it may be that he is maintaining his own dev branch but that is not visible. 204 and master donot have ‘change’’ as type
Got it, thanks but he has not created a release out of that…normally I would copy this into the www/community folder but here it seems to require some compilation
Yep…
So utility meter helpers are my workaround for the problem right now.
I’m now using nordpool. But swapped my old ipad for a newer Android model. So don’t have the issue anymore.
thanks !! im going to try this… available via hacs ?
yes sir it is.
Hi everyone,
Can someone help me out with this small problem? I have for example a input_number with the value of 0.02345
But the chart is displaying ‘0’ . How can I correctly change the number of decimals?
type: custom:apexcharts-card
header:
show: true
show_states: true
colorize_states: true
chart_type: radialBar
series:
- entity: input_number.smallnumber
yaxis_id: a_small_number
yaxis:
- id: a_small_number
decimals: 10
Can you try
header:
show: true
show_states: true
series:
float_precision: 5 # Add this for number of decimals behind the 0,
yaxis:
min: 0
max: 1 # or whatever the maximum will be
@MrGlad8 I m doing something similar, maybe this helps:
apex_config:
legend:
show: false
chart:
stacked: true
dataLabels:
background:
borderWidth: 0
opacity: 0
foreColor: '#03A9F4'
plotOptions:
bar:
borderRadius: 5
dataLabels:
position: center
graph_span: 7d
span:
end: day
show:
last_updated: true
header:
show: true
show_states: true
title: Stromherkunft
series:
- entity: sensor.home_selfuse_energy_daily
color: orangered
show:
datalabels: true
header_color_threshold: false
extremas: false
type: column
group_by:
func: last
duration: 1d
- entity: sensor.grid_consumption_energy_daily
color: pink
show:
extremas: false
header_color_threshold: true
datalabels: true
type: column
name: aus dem Netz
group_by:
func: last
duration: 1d
- entity: sensor.home_consumption_energy_daily
color: '#03A9F4'
show:
datalabels: true
type: area
group_by:
func: last
duration: 1d
opacity: 0
stroke_width: 0
I’m struggling with getting nice division of the yaxis. This graph looks nice, but if you look closely, the y axis lables are not correct and the grid lines are off. For example, the cyan line is just zero (the value is zero), the grid line indicated as zero isn’t.
Here’s the code:
header:
title: Strømpris, i dag og i morgen
show: true
graph_span: 2d
span:
start: day
apex_config:
dataLabels:
enabled: false
stroke:
width: 2
dashArray:
- 0
- 1
- 1
- 0
- 0
grid:
xaxis:
lines:
show: true
now:
show: true
label: Nå
series:
- entity: sensor.strompris_hjemme
type: line
curve: stepline
color: red
float_precision: 3
extend_to: false
show:
extremas: true
legend_value: false
data_generator: |
return entity.attributes.raw_strompris.map((entry) => {
return [new Date(entry.start), entry.value];
- entity: sensor.strompris_uten_stotte_hjemme
name: Strømpris uten støtte
type: line
curve: stepline
color: rgb(256, 0, 256)
float_precision: 3
extend_to: false
show:
extremas: true
legend_value: false
data_generator: |
- entity: sensor.stromstotte_hjemme
type: line
curve: stepline
color: rgb(0, 256, 256)
float_precision: 3
extend_to: false
show:
extremas: true
legend_value: false
data_generator: |
return entity.attributes.raw_stromstotte.map((entry) => {
- entity: sensor.nordpool_kwh_oslo_nok_4_10_025
type: line
curve: stepline
color: green
float_precision: 3
extend_to: false
show:
extremas: true
legend_value: false
data_generator: |
let today = entity.attributes.raw_today.map((entry) => {
return [new Date(entry.start), (entry.value)];
let tomorrow = entity.attributes.raw_tomorrow.map((entry) => {
if(tomorrow[0])
return today.concat(tomorrow);
return today;
- entity: sensor.nettleie_forbruksledd
type: line
curve: stepline
color: blue
float_precision: 3
extend_to: false
show:
legend_value: false
data_generator: |
let nett_today = entity.attributes.raw_today.map((entry) => {
let nett_tomorrow = entity.attributes.raw_tomorrow.map((entry) => {
if(nett_tomorrow[0])
return nett_today.concat(nett_tomorrow);
return nett_today;
Under apex_config
I’ve tried several variations. For example forceNiceScale
, which does not change the graph.
apex_config:
yaxis:
forceNiceScale: true
I’ve also tried this:
apex_config:
yaxis:
decimalsInFloat: 3
which adds decimals and seems to move the grid lines to sensible positions, but it’s not nice:
I had hoped that the forceNiceScale
option would have expanded the y axis until the grid lines and lables were nice; for example 5 grid lines, the lowest at -0.2 and then 0, 0.2, 0.4, 0.6 (since the data are between -0.072 and 0.452.
It is perhaps a tall order, but tall orders have been served before in this forum, so my hopes are up.
I have my chart working like a charm for my dynamic energy prices. But it doesn’t quite look like how I want it to look, can anyone help me out?
This is the code I have right now:
graph_span: 24h
span:
start: day
now:
show: true
label: Nu
header:
show: true
show_states: true
title: Stroomprijs vandaag
experimental:
series:
- entity: sensor.anwb_average_electricity_price_today
stroke_width: 2
float_precision: 3
type: column
opacity: 1
color_threshold:
- value: -0.1
color: '#179647'
- value: 0
color: '#8FB900'
- value: 0.1
color: '#F2E701'
- value: 0.2
color: '#F9B200'
- value: 0.3
color: '#F37D01'
- value: 0.5
color: '#EC4811'
- value: 1
color: '#DC000A'
data_generator: |
return entity.attributes.prices.map((record, index) => {
return [record.time, record.price];
yaxis:
- id: Prijs
decimals: 2
As you can see in the image above (left side), I have two boxes that tell me the date and time, I want to remove the bottom one (I’m not sure where it came from, I don’t think I had it yesterday).
At the top it shows the average daily price, would it be possible to show the current price?
And at last, the colored dot before the name (prijs) is the standard orange color, I’d love it to represent the color of the column. Any help is greatly appreciated
right now the center value is calculated.
but i do have an entity for this total value - i just want users to tab on this number to show the statistics/graphs.
I’ve built a graph that shows my refrigerator temperature from inside it, and power consumption from a smart plug. I want to additionally show door open/close events from a door contact sensor. I haven’t seem to found a way to do it. Is there something obvious I’m missing? Thanks!
Does anyone have thoughts on how I might hide legend items if their value is 0W or maybe even < 5W?
I have 2 series on a chart. I wan’t to set min/max values for axis Y based on only one of the series ignoring the other one.
One of them will get cut off on the chart, that’s OK.
Is there a way to set:
min: series1.min
max: series1.max
Found a solution:
EVAL:(seriesName, opts) => { return opts.w.globals.series[0].reduce((a, b) => Math.max(a, b), -Infinity) }
will return min/max
but
yaxis:
- id: left
min:
max:
does not accept EVAL
/// apexcharts-card version 2.0.4 /// Bad yaxis min/max format: EVAL:(seriesName, opts) => { return Math.round((opts.w.globals.series[2].reduce((a, b) => Math.max(a, b), -Infinity) + 0.1) * 10) / 10 }
and accoring to documentation
apex_config:
does not accept min/max
Any solutions?
Browser freezes by adding graph.
Hey all, I’ve added a graph to a clean dashboard for a test setup. I’ve noticed the tab lagging. I soon found out after adding this graph the memory of this tab was 65Gb. Needless to say, copy/pasting the graph 4 times MacOs gave me a popup saying I need to close “something” or OS might stop functioning
This is my small test:
update_interval: 30min
graph_span: 1day
span:
start: day
offset: '-6d'
series:
- entity: sensor.100_total_system_power
Now, is this a bug, or am I using the card wrong? What I intent to do is get a weekly overview. Yes the span is currently one day. But this is where the problem started with,
Is it crashing on the amount of data? What can I do to get a smooth working graph?
I think it is the mass of data, I had similar with a tempsensor providing data updates very 2s … try to add this to the series and play around a bit
group_by:
duration: 5min
func: avg
Thanks, that’s a good pointer! It does work a lot faster now. I might also consider capping the modbus sensor readout. I think I don’t need to record every second
