ApexCharts card - A highly customizable graph card
I have a problem with the stacked: true option.
When I don’t use the option I get this picture:
Schermafdruk van 2023-10-03 14-37-08
It looks correct but the bars should be broader and should lay in each other length.
But when I use the stacked option I get this picture:
Schermafdruk van 2023-10-03 14-40-38
This picture look nice but the second “dimmed” line is not correct.
How could I get that second line correct with the stacked option?
Is there a way to use service return value in a chart? I currently have a chart that plots hourly forecast temperature using the forcast attribute of a weather entity. With the new model of weather entities that uses service return values I can’t figure out how to get the hourly forecast data into apex.
This is what my chart currently looks like using the old attribute based model - 24h history on the left side and 24h forecast on the right.
apex_config:
  legend:
    showForZeroSeries: false
If you want to hide things less than a specifc value transform the value to be zero.
Struggling to find an answer to this.
Would like to move the title and value up with less space between them, cab anyone advise?
I am looking to draw a donut based on hoe long time a sensor have been in each of its 5 states. I have a input_select.ventilation that has 5 states. It switches between the states based on its power consumption:
Off
Level 1
Level 2
Level 3
Level 4
I would like to graph for what portion of the day so far it has been in each state. For instance
Off - 0%
Level 1 - 10%
Level 2 - 50%
Level 3 - 30%
Level 4 - 10%
And then draw this in a donut. How can this be done?
Hi @vingerha
is this sensor still working?
Yep, with me it is
Good evening
I’m desperately looking for a setting to change the size of a donut graphic.
Here is my configuration:
type: horizontal-stack
cards:
  - type: custom:apexcharts-card
    chart_type: donut
    header:
      show: true
      title: Generation Jour
      show_states: true
      colorize_states: true
    apex_config:
      chart:
        toolbar:
          show: false
          zoom:
            enabled: true
          tools:
            zoom: true
            zoomin: true
            zoomout: true
            pan: true
            reset: true
      stroke:
        width: 1
        curve: smooth
      legend:
        show: false
      responsive:
        - breakpoint: 800
          options:
            chart:
              height: 360px
        - breakpoint: 1300
          options:
            chart:
              height: 360px
        - breakpoint: 10000
          options:
            chart:
              height: 375px
    series:
      - entity: sensor.totale_pv_production_day
        color: rgb(255, 155, 48)
      - entity: sensor.decharge_batterie_daily
        color: rgb(151, 90, 182)
      - entity: sensor.shellyem_consommation_grid_positif_daily
        color: rgb(84, 144, 194)
    chart_type: donut
    header:
      show: true
      title: Origine Generation
      show_states: true
    apex_config:
      chart:
        toolbar:
          show: false
          autoSelected: zoom
      stroke:
        width: 1
        curve: smooth
      legend:
        show: false
      responsive:
        - breakpoint: 800
          options:
            chart:
              height: 360px
        - breakpoint: 1300
          options:
            chart:
              height: 360px
        - breakpoint: 10000
          options:
            chart:
              height: 355px
    series:
      - entity: sensor.consommation_electrique_maison_daily
      - entity: sensor.charge_batterie_jour
view_layout:
  grid-area: right2
and what it gives:
Thanks for your help
Hi all,
How do you hide the lines?
I suspect not, but is it possible to access the HA states object to get the value of another entity in an EVAL function?
Hello. Won’t you share the code?)
How do I get apexcharts to display the entity name for each bar in my bar graph? I do not want time on the bottom axis.
Code to show last 24hrs temp and next 24hrs forecast temp on one graph. Also colors the line according to temperature.
    graph_span: 48h
    update_interval: 60s
    now:
      show: true
    span:
      offset: +24h
    apex_config:
      chart:
        height: 220px
      grid:
        show: false
      legend:
        show: false
      xaxis:
        axisBorder:
          show: false
        axisTicks:
          show: false
        spanGaps: false
    experimental:
      color_threshold: true
    header:
      show: true
      floating: false
      show_states: true
    series:
      # Ecowiit temperature sensor
      - entity: sensor.gw1100b_v2_2_0_outdoor_temperature
        color: black
        opacity: 1
        stroke_width: 1
        extend_to: now
        type: line
        show:
          in_chart: true
          header_color_threshold: true
          extremas: true
        yaxis_id: Temperature
        color_threshold:
          - value: 0
            color: rgb(224,123,222)
          - value: 20
            color: rgb(187, 116, 212)
          - value: 30
            color: rgb(116, 92, 219)
          - value: 40
            color: rgb(23, 210, 227)
          - value: 50
            color: rgb(0,215,144)
          - value: 60
            color: rgb(94,210,48)
          - value: 70
            color: rgb(255,255,101)
          - value: 80
            color: rgb(250,130,46)
          - value: 90
            color: rgb(180,35,17)
          - value: 100
            color: rgb(175,0,0)
     # US National weather service forecast temps
      - entity: weather.rrrc1_hourly
        color: black
        data_generator: |
          return entity.attributes.forecast.map((fcst, index) => {
            return [fcst.datetime,fcst.temperature];
        opacity: 0.7
        stroke_width: 1
        type: line
        show:
          in_chart: true
          in_header: false
          extremas: true
        color_threshold:
          - value: 0
          - value: 20
          - value: 30
          - value: 40
          - value: 50
          - value: 60
          - value: 70
          - value: 80
          - value: 90
          - value: 100
            color: rgb(175,0,0)
      - entity: sensor.gw1100b_v2_2_0_humidity
        color: white
        yaxis_id: Humidity
        show:
          in_chart: false
          in_header: true
          extremas: false
    yaxis:
      - id: Temperature
        opposite: true
        show: true
        align_to: 5
        decimals: 0
        apex_config:
          tickAmount: 5
      - id: Humidity
        show: false
Fantastic. You solved a problem I’ve been trying to find a hack for.
I need to create a file with an apex chart.
It will be displayed in an openhasp panel, so the card itself cannot be used.
Any ideas on how to accomplish that?
It seems like the basis for apex charts, apex chart.js, has the possibility to output to a file, but the ha card apparently doesn’t support that.
If you know other ha cards that can do it, that would be helpful too!
I use this to control size:
    apex_config:
      chart:
        height: 405px
Please help me to sort out the error.
apexcharts-card version 2.0.4 /// value.series[1] is not a ChartCardSeriesExternalConfig value.series[1].yaxis_id is not a string value.series[1].yaxis is extraneous value.series[1].yaxis is extraneous
Code
graph_span: 48h
now:
  show: true
span:
  offset: +24h
apex_config:
  chart:
    height: 220px
  grid:
    show: false
  legend:
    show: false
  xaxis:
    axisBorder:
      show: false
    axisTicks:
      show: false
    spanGaps: false
experimental:
header:
  show: true
  floating: false
  show_states: true
series:
  - entity: sensor.datchik_temperatury_na_pervom_etazhe_temperature
    color: black
    opacity: 1
    stroke_width: 1
    extend_to: now
    name: Климат на первом этаже
    type: line
    show:
      in_chart: true
      extremas: true
    color_threshold:
      - value: -10
      - value: -5
      - value: 0
      - value: 5
      - value: 10
      - value: 15
      - value: 20
      - value: 25
      - value: 30
      - value: 35
        color: rgb(175,0,0)
  - entity: sensor.datchik_temperatury_na_pervom_etazhe_humidity
    color: white
    yaxis_id:
      show:
        in_chart: false
        in_header: true
        extremas: false
    yaxis:
      - id: Temperature
        opposite: true
        show: true
        align_to: 5
        decimals: 0
        apex_config:
          tickAmount: 5
      - id: Humidity
        show: false
You’ve missed Humidity after this ?
yaxis_id: Humidity
and yaxis definition needs to be tabbed back
    color: white
    yaxis_id: Humidity
      show:
        in_chart: false
        in_header: true
        extremas: false
yaxis:
  - id: Temperature
    opposite: true
    show: true
    align_to: 5
    decimals: 0
    apex_config:
      tickAmount: 5
  - id: Humidity
    show: false
Another error appears. I think the problem is the gaps.
bad indentation of a mapping entry (64:11)
 61 |         color: rgb(175,0,0)
 62 |
 63 |   - entity: sensor.datchik_temperatury_na ...
 64 |      color: white
 65 |       name: Влажность
 66 |   yaxis_id: Humidity
After correcting the spaces, an error appears.
/// apexcharts-card version 2.0.4 /// value.series[1] is not a ChartCardSeriesExternalConfig value.series[1].show is not a ChartCardSeriesShowConfigExt; value.series[1].show is not an object value.series[1].in_chart is extraneous value.series[1].in_header is extraneous value.series[1].in_chart is extraneous value.series[1].in_header is extraneous
Can you post the whole code so I can see the indents ?
