did you manage it to hide the zero values ? on an easy way ?
Edit : transform: “return x == 0 ? null : x;”
- type: custom:apexcharts-card
span:
start: day
offset: -1min
experimental:
color_threshold: true
brush: true
header:
show: false
# title: Energie
show_states: true
colorize_states: true
apex_config:
legend:
show: true
position: top
grid:
strokeDashArray: 0
borderColor: rgb(52,52,52)
xaxis:
axisBorder:
show: false
color: rgb(52,52,52)
tickAmount: 1
axisTicks:
show: false
labels:
style:
colors: rgb(128,128,128)
yaxis:
decimalsInFloat: 0
labels:
style:
all_series_config:
type: area
curve: smooth
stroke_width: 1
group_by:
func: avg
duration: 10min
color_threshold:
- value: 0
opacity: 0.2
- value: 1000
opacity: 0.7
- value: -1000
opacity: 0.7
series:
- entity: sensor.p1_meter_5c2faf04a1f2_active_power
transform: "return x >= 0 ? x : 0 ;"
color: rgb(66,73,241)
float_precision: 2
extend_to: now
transform: "return x <= 0 ? x : 0 ;"
color: rgb(11,252,3)
float_precision: 2
extend_to: now
this is what I have now… the second chart is in testing mode (I am not sure it will give me a negative chart)
Hi all,
bit of a strange one. i’m trying to replicate a smaller version of the energy dashboard. So far so good apart from the face that my Battery power (%) doesn’t match the secondary axis set to 100.
can anyone advise?
header:
show: true
title: Home Energy
show_states: true
graph_span: 1day
yaxis:
- id: watts
max: 15
apex_config:
tickAmount: 4
- id: percent
opposite: true
decimals: 0
align_to: 1
apex_config:
tickAmount: 4
stacked: true
series:
- entity: sensor.grid_export_power
type: column
yaxis_id: watts
transform: return x / 1000;
unit: kWh
group_by:
func: avg
duration: 30m
- entity: sensor.consumption_power
type: column
yaxis_id: watts
unit: kW
group_by:
func: avg
duration: 30m
- entity: sensor.battery_power
type: column
yaxis_id: watts
unit: kW
group_by:
func: avg
duration: 30m
- entity: sensor.pv_power
type: line
yaxis_id: watts
unit: kW
group_by:
func: avg
duration: 30m
- entity: sensor.battery_charge
type: line
yaxis_id: percent
group_by:
func: avg
duration: 30m
Is it possible to hide a negative value ?
Probably with transform, I donot have data to check but you have to define what else to do as you still have the time component
- entity: your_entity
transform: "return x > 0 ? x : 0 ;"
alternative might be to use datagenerator and just get out only positive numbers
the bar chart is negative on purpose, this is energy exported and imported fromthe grid.
The yellow line is my PV Battery charge level in %, but it looks like its starting on the left hand Y axis, and not the Right which is the axis is assigned to…
series:
float_precision: 2
extend_to: now
float_precision: 0
extend_to: now
Now you can see that 0 is a green line. Can I remove that zero line ?
Nice color fading
What settings did you use to get that? Gradient or color_threshold?
Willing to share the code?
You can see it in a post from 2 days ago…
Hello folks!
I’m trying to graph the wind, and I can’t figure out how to have non-numeric values as the Y axis. I’ve made another thread about it here - if anybody has any insight into how to either graph “weather cardinal” values (n, s, e, w, nnw, ese, wsw, etc) or convert the numeric value (wind direction represented in 360 degrees) into a dot/plot chart like in my thread, I would be very grateful!
Is it possible to combine two entities in a series?
For example in a line graph showing one entity for my PS4 usage, but then one line showing two different TV usages shown as one value, not a separate line for both.
At the moment I have it as a bar graph that has been stacked, which does add them together, but I’d prefer it as a line.
what If I don’t want the 0 value to be seen ?
I use null to remove any graph
transform: "return x >= 0 ? x : null ;"
I am trying to visualize what you want but … if you have a x with timeseries on regular distance and filter out the negative/zero value than you graph will probably show gaps …
I have a chart in gradient blue. When it goes below zero I want the chart in gradient green…
It was told that you cannot change color when you want it in gradient.
So I made 2 charts. 1 with values above 0, 1 with values below zero. But it doesnt look nice to have 0 zero value, so I want it removed…
that is what I want ! Top. Thanks
I have red a few questions here about wind plots of some kind, I can’t answers these questions but if you are looking for a way to plot wind speed and direction I have had good luck with this card.
Is it possible to show multiple entities at once in the tooltip when using the line graph?
In the apexchart documentation there is the “shared” keyword für the tooltip. I tried it but no success. I am either doing it wrongly or it is not implemented. I seen to remember seeing it done though.
