fl-hol
(Fl Hol)
June 7, 2025, 2:04pm
4489
i am a beginner with coding and home assistant and i have a question about an apexcharts data generator.
i would like a line chart where the following is calculated.
sensor.electricity_meter_energy_consumption - sensor.electricity_meter_energy_production
can someone help me with this? i have this.
[type: custom:apexcharts-card
apex_config:
chart:
stacked: true
graph_span: 28day
span:
end: day
show:
last_updated: true
header:
show: true
show_states: true
colorize_states: true
title: Energieverbruik per dag
series:
- entity: sensor.electricity_meter_energieverbruik
type: line
unit: ' kWh'
color: darkviolet
group_by:
func: avg
duration: 1d
- entity: sensor.electricity_meter_energieproductie
type: column
unit: ' kWh'
color: slateblue
invert: true
group_by:
func: max
duration: 1d
- entity: sensor.netto_verbruik
data_generator: |
[[sensor.electricity_meter_energieverbruik - sensor.electricity_meter_energieproductie]]
type: line
show: in_header: true
Easiest is via a template sensor. The only other thing I know of is using statistics via the websocket api. Sadly this is not well documented as I would expect there would also be a solution for the states.
With below you can add a similar set for entity2 and subtract that in ‘let stat =…’
The benefit of using statistics is that they are all on the same time so you donot have to (possibly) align the datetime-stamps of both sensors…the downside is that statistics are on a much lower frequency
data_generator: |
const stat_entity1 = 'sensor.yoursensor1';
var statistics1 = await hass.callWS({type: 'recorder/statistics_during_period',
start_time: new Date(start).toISOString(), end_time: new Date(end).toISOString(),
statistic_ids: [stat_entity1], period: 'hour'});
var stats1 = statistics1[stat_entity1];
var result = [];
var len = stats1.length;
for (let i = 0; i < len; i++) {let stat = stats1[i].state;
result.push([(new Date(stats1[i].start).getTime()),stat]);}
return result;
tilz0R
(Tilen)
June 7, 2025, 6:22pm
4491
How does the statistics and group_by work together?
My LTS statistics is a monotonically growing sensor that increases each time an event occurs. I would like to track number of events per month for past 12 months.
graph_span: 12month
span:
start: month
offset: "-11month"
header:
show: true
title: Monthly use of washing machine
show_states: true
series:
- entity: sensor.washing_machine_cycles_total
type: column
statistics:
type: state
period: month
Produces the correct values, grouped by month, but not number of times per month .
If I add the group_by part:
statistics:
type: state
period: month
group_by:
duration: 1month
func: diff
The chart disappears and I don’t see any issue in the JS console log.
What am I doing wrong?
NateJG
(Nate)
June 14, 2025, 8:25pm
4493
I’m getting odd behaviour when using color threshold.
I accept that this is experimental (and I’m happy raise it as a bug if necessary) but I’ve got a fairly simple graph setup:
graph_span: 14d
experimental:
color_threshold: true
header:
show: true
standard_format: true
show_states: true
series:
- entity: sensor.front_bedroom_thermometer_pressure
show:
extremas: true
header_color_threshold: true
color_threshold:
- value: 995
color: blue
opacity: 1
- value: 1000
color: cyan
opacity: 1
- value: 1005
color: green
opacity: 1
- value: 1010
color: yellow
opacity: 1
- value: 1015
color: orange
opacity: 1
- value: 1020
color: red
opacity: 1
However on any dashboard I get a graph that looks like this:
Is it my settings or something else as I’d expect the colors to align with the Y axis?
TIA
Possibly gaps in the data, try to add fill_raw: last to the series
josemsubcn
(josemsubcn)
June 16, 2025, 9:38pm
4496
Annotations, point yaxis to entity value:
I have a apexchart card and inside apex_config I have two annotations to draw a limit tolerance, but I want to point second limit (24.8) not a fixed value, I need to be equal to a entity value:
apex_config:
annotations:
position: back
yaxis:
- "y": 26.2
strokeDashArray: 1
borderColor: "#f80808"
borderWidth: 3
- "y": 24.8
strokeDashArray: 1
borderWidth: 3
with a template solution is not working well, for example the following code do not work:
apex_config:
annotations:
position: back
yaxis:
- "y": 26.2
strokeDashArray: 1
borderWidth: 3
- "y": {{ states('input_number.lim_confort_suite') | float }}
strokeDashArray: 1
borderWidth: 3
There is any solution?
Embed the card in card-templater, this question pops up many (!) times up in this thread…
Hi! Sorry for the late bump on the message. Did you find a solution for this? Thanks
As I just looked at the same thing, I went for config-template-card to accomplish this, with limitations. The issue with annotations, as far as I could see: they are fixed because they aren’t loaded dynamically when the graph is re-drawn/appended. So if that dynamic value changes, there is nothing there that would notify the annotation to redraw.
With config-template-card you can accomplish this but be aware that each refresh of that input will cause a full redraw of the graph. No other way to update the annotation. So make sure it’s not a sensor that updates often!
Here my code for the relevant parts:
type: custom:config-template-card
entities:
- sensor.solcast_pv_forecast_power_now
variables:
forecast_kw: states['sensor.solcast_pv_forecast_power_now'].state / 1000
card:
graph_span: 15m
update_interval: 2s
apex_config:
chart:
animations:
enabled: false
tooltip:
shared: true
legend:
show: false
annotations:
yaxis:
- "y": 20.59
borderColor: "#FF0000"
strokeDashArray: 3
label:
text: Inverter Limit
position: left
offsetX: 60
style:
color: "#FF0000"
fontSize: 8px
- "y": ${forecast_kw}
borderColor: "#A9A9A9"
strokeDashArray: 3
label:
text: Forecast Power
position: left
offsetX: 60
style:
color: "#A9A9A9"
fontSize: 8px
Chykan
(Hunter)
June 23, 2025, 9:48am
4500
@sturgeo Finally got it working, this is adjusted to fit within section few. Card jumps around a bit when editing and changing view port size.
FULL CARD CODE (4 Wide Sections) (JUST ADD 3 SENSORS)
header:
show: true
title: Whoop
floating: true
show_states: true
experimental:
chart_type: radialBar
apex_config:
chart:
offsetX: 0
offsetY: 0
grid:
padding:
left: 0
right: 0
bottom: -20
top: 70
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 100
background: transparent
dataLabels:
name:
show: true
value:
show: true
legend:
show: true
floating: true
fontSize: 10vw
position: left
offsetX: 80
offsetY: 73
labels:
useSeriesColors: true
markers:
series:
- entity: sensor.whoop_andrew_sleep_performance
fill_raw: last
color_threshold:
- value: 0
color: " #7BA1BB"
show:
legend_value: true
- entity: sensor.whoop_andrew_recovery_score
fill_raw: last
color_threshold:
- value: 0
color: "#FF0026"
- value: 34
color: "#FFDE00"
- value: 67
color: "#16EC06"
show:
legend_value: true
- entity: sensor.whoop_andrew_day_strain
fill_raw: last
color_threshold:
- value: 0
color: "#0093E7"
show:
legend_value: true
offset for chart
apex_config:
chart:
offsetX: -30
offsetY: 0
offset for legend
apex_config:
legend:
show: true
floating: true
fontSize: 12px
position: left
offsetX: 95
offsetY: 78
Chykan
(Hunter)
June 24, 2025, 7:30am
4501
Radial Bar Chart Layouts
To change the the layout of a Radial Bar Chart you need to play with the below settings
- type: custom:apexcharts-card
apex_config:
chart: # Moves the Radial Bars themselves around
offsetX: 0
offsetY: 20
grid: # Adjust this when you move the chart with the above offsets
padding:
left: 0
right: 0
bottom: 0
top: 0
legend: # Moves the legend around, change the font size and you will have to change the offset.
show: true
floating: true
fontSize: 15px
position: top
offsetX: -20
offsetY: 5
Only Legend displayed at top
Works on mobile or large screen (There is a mid size screen where the legend does not quite resize properly
Whoop Mobile Legend
header:
show: true
title: Whoop Mobile Legend
floating: true
show_states: false
experimental:
apex_config:
chart:
offsetX: 0
offsetY: 20
grid:
padding:
left: 0
right: 0
bottom: 0
top: 0
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 100
dataLabels:
name:
show: true
value:
show: true
legend:
show: true
floating: true
fontSize: 15px
position: top
offsetX: -20
offsetY: 5
labels:
markers:
series:
fill_raw: last
color_threshold:
- value: 0
color: ' #7BA1BB'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#FF0026'
- value: 34
color: '#FFDE00'
- value: 67
color: '#16EC06'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#0093E7'
show:
legend_value: true
Legend and States Displayed
Best for Mobile (Optimized position for mobile)
Whoop Mobile States
header:
show: true
title: Whoop Mobile States
floating: true
show_states: true
experimental:
apex_config:
chart:
offsetX: 0
offsetY: 10
grid:
padding:
left: 0
right: 0
bottom: 0
top: 70
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 100
dataLabels:
name:
show: true
value:
show: true
legend:
show: true
floating: true
fontSize: 10px
position: left
offsetX: 40
offsetY: 50
labels:
markers:
series:
fill_raw: last
color_threshold:
- value: 0
color: ' #7BA1BB'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#FF0026'
- value: 34
color: '#FFDE00'
- value: 67
color: '#16EC06'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#0093E7'
show:
legend_value: true
Shows only Legend
Mobile(Optimized position for mobile)
Whoop Mobile Legend
header:
show: true
floating: true
show_states: false
experimental:
apex_config:
chart:
offsetX: 0
offsetY: 0
grid:
padding:
left: 0
right: 0
bottom: 0
top: 0
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 100
dataLabels:
name:
show: true
value:
show: true
legend:
show: true
floating: true
position: left
offsetX: 20
offsetY: 5
labels:
markers:
series:
fill_raw: last
color_threshold:
- value: 0
color: ' #7BA1BB'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#FF0026'
- value: 34
color: '#FFDE00'
- value: 67
color: '#16EC06'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#0093E7'
show:
legend_value: true
Shows States and Legend
Optimized positioning for larger screens
Whoop Desktop States
header:
show: true
title: Whoop Desktop States
floating: true
show_states: true
experimental:
apex_config:
chart:
offsetX: 0
offsetY: 60
grid:
padding:
left: 0
right: 0
bottom: 40
top: 0
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 100
dataLabels:
name:
show: true
value:
show: true
legend:
show: true
floating: true
position: left
fontSize: 15
offsetX: 65
offsetY: 10
labels:
markers:
series:
fill_raw: last
color_threshold:
- value: 0
color: ' #7BA1BB'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#FF0026'
- value: 34
color: '#FFDE00'
- value: 67
color: '#16EC06'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#0093E7'
show:
legend_value: true
Shows Legend
Whoop Desktop Legend
header:
show: true
title: Whoop Desktop Legend
floating: true
show_states: false
experimental:
apex_config:
chart:
offsetX: 0
offsetY: 0
grid:
padding:
left: 0
right: 0
bottom: 0
top: 0
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 100
dataLabels:
name:
show: true
value:
show: true
legend:
show: true
floating: true
position: left
fontSize: 15
offsetX: 65
offsetY: 25
labels:
markers:
series:
fill_raw: last
color_threshold:
- value: 0
color: ' #7BA1BB'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#FF0026'
- value: 34
color: '#FFDE00'
- value: 67
color: '#16EC06'
show:
legend_value: true
fill_raw: last
color_threshold:
- value: 0
color: '#0093E7'
show:
legend_value: true
Ideefiks
(Ideefiks)
June 25, 2025, 1:52pm
4503
This is a nifty piece of code and it works great but is not compatible with custom:config-template-card, a case of you-can’t-have-it-all or is there a way to make both compatible?
If you search this thread you will find quite a few of working examples, so no clue how you came to this conclusion. There is also card-templater
Ideefiks
(Ideefiks)
June 25, 2025, 2:44pm
4505
I couldn’t make it work first, but after noticing both use this syntax ${} I removed all config_template stuff and your tooltip code worked
I might be wrong that ${} is the reason I couldn’t make both work at the same time, but that is what made me try removing config_template
Ideefiks
(Ideefiks)
June 25, 2025, 3:01pm
4506
I did the same and left the update interval at 30s. Also, not all the entities you use in the variables need to be defined in the entities section, I only added the ones I want triggering an update. You can also use this to dynamically change the chart title, series names, axis ranges etc
Ideefiks
(Ideefiks)
June 25, 2025, 3:13pm
4507
When using datetime the labels switch based on the span shown in the graph, so it automatically switches to hours because it considers there are not sufficient days to stick with days. I ended up using annotations to get the exact labels I wanted
Chykan
(Hunter)
June 26, 2025, 12:52am
4508
barLabels: not legend: like in the above post .
This example is using barLabels:
offsetX: and offsetY: settings have no affect under the barLables: options (must be a bug).
The position of the barLabels: seems to be calculated on CSS device-width in px: and is also obscured by the margin of the track:
I found playing with the track margin unobscured the ‘barLabels:’
Depending on your screen width, change the track: margin: and barLabels: fontSize: under apex_config: plotOptions:
This means if you want to display the card on different devices you will have to setup a different config for the card for each device screen width. Use ‘@media-queries ’ screen sizes to conditionally show each card.
FULL CARD CODE (Behaviour shown below using the same code on different device screen screen widths)
header:
show: true
title: Whoop Scores
floating: true
show_states: true
experimental:
apex_config:
chart:
offsetX: 0
offsetY: 0
grid:
padding:
left: 0
right: 0
bottom: 0
top: 20
plotOptions:
radialBar:
offsetY: 60
startAngle: 0
endAngle: 270
hollow:
margin: 100
dataLabels:
name:
show: true
value:
show: true
barLabels:
enabled: true
offsetX: 0
offsetY: 0
fontSize: 15
track:
show: true
margin: 7
legend:
show: false
floating: true
fontSize: 10px
position: bottom
offsetX: -15
offsetY: 0
labels:
markers:
series:
fill_raw: last
color_threshold:
- value: 0
color: " #7BA1BB"
show:
legend_value: false
fill_raw: last
color_threshold:
- value: 0
color: "#FF0026"
- value: 34
color: "#FFDE00"
- value: 67
color: "#16EC06"
show:
legend_value: false
fill_raw: last
min: 0
max: 20
color_threshold:
- value: 0
color: "#0093E7"
show:
legend_value: false
device-width in px: 360px
device-width in px: 1280px
device-width in px: >2000px
Below is a good tool to test your screens.
could anyone please check if they see this too:
opened 01:03PM - 29 Jun 25 UTC
### Checklist
- [x] I have updated to the latest available Home Assistant versi… on.
- [x] I have cleared the cache of my browser.
- [x] I have tried a different browser to see if it is related to my browser.
- [ ] I have tried reproducing the issue in [safe mode](https://www.home-assistant.io/blog/2023/11/01/release-202311/#restarting-into-safe-mode) to rule out problems with unsupported custom resources.
### Describe the issue you are experiencing
user theme
<img width="301" alt="Image" src="https://github.com/user-attachments/assets/afbc92b3-fd4d-4a48-b0bd-ee0bef432ddc" />
HA default theme
<img width="340" alt="Image" src="https://github.com/user-attachments/assets/07f5ae91-cb33-4880-9003-b946baf4082e" />
### Describe the behavior you expected
not shining through
### Steps to reproduce the issue
1. use apexchartscard in view and scroll, or edit UI
2.
3.
### What version of Home Assistant Core has the issue?
2025.7.0b4
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue?
Safari Mac
### Which operating system are you using to run this browser?
macOS Sequoia 15.5
### State of relevant entities
```txt
### Problem-relevant frontend configuration
```yaml
### JavaScript errors shown in your browser console/inspector
```txt
### Additional information
As I have never seen this, and havent updated Apexcharts card in a long time (it's on the latest release of course), I figured it would be a HA issue introduced during beta 2025.7
all of a sudden I notice those controls shining through the menu,
If its new to HA (running 2025.7 beta myself) it would be a HA issue.
if you all see it too, running non 2025.7 beta, it probably is an unnoticed apexcharts-card issue…apexcharts-toolbar z-index too high, shining through HA menu and menubar · Issue #927 · RomRider/apexcharts-card · GitHub
still deciding
