form me not working. only one value on tooltip.
Incredible! Works very well - thank you.
Another question on your code/implementation. It appears the Apex Charts omits some data compared to the standard history graph. See attached picture. The only thing I see tell visually is that the filled in areas below (when the HVAC action is ‘cooling’) appear thinner on the Apex Charts and maybe that’s why the shorter time-spans are getting cut out? Rounding error or something?
I don’t seem to be able to replicate that unfortunately. Try experimenting with the group_by: settings or remove that section altogether and see how you go.
Is there a way to only show the hours or minutes below the card? Also in the circle itself it shows % instead of hours, any way to change this? Thx
Hey guys, is there a way to overlay a single big number (Say current value of one of the series?). Would want to tinker with transparency etc.
I had a look through the thread but couldn’t spot anything? Ta.
A little question that should probably be simple but I can’t seem to figure it out – if I have a pie/donut chart with a single entity source using percentage (in this case a battery sensor), how do I get the chart to render so the pie/donut shape reflects that percentage value?
For example, below I have a battery sensor entity with 75%, and the 75% value is displayed correctly in some text places on the chart, but the pie itself always shows a complete 100% chart.
Thanks.
I haven’t gone in to how you would actually do this but a pie chart by design will show various values as a percentage of the total. If you only give it one value that value will always be 100% of the total no matter what the absolute reading is. I am assuming that you would have to provide two values eg, amount_full=75, amount_empty=25 or amount_empty=100 - amount_full.
Probably best to ask this on GitHub.
What do you mean? Are you suggesting I should raise a feature request?
I’ve skimmed the documentation a few times and can’t see anything that seems to match?
Dunno if there is a better way but this should work.
type: custom:apexcharts-card
header:
show: true
title: ApexCharts-Card
show_states: true
colorize_states: true
apex_config:
plotOptions:
pie:
donut:
total:
show: true
showAlways: true
chart_type: pie
series:
- entity: sensor.esp_humidity_bathroom
transform: "return 100 - x ;"
Anyone who knows if it’s possible to make the dashed “Now-line” wider? Have tried with stroke_width but obviously it’s not working.
Probably wouldn’t hurt.
So you can kind of fake it like this.
Can’t figure out how to send the big number to the background or set it’s transparency though.
graph_span: 48hr
apex_config:
chart:
height: 250px
legend:
show: false
grid:
show: false
dataLabels:
enabled: true
offsetX: -100
offsetY: 23
opacity: 0.5
style:
fontSize: 180px
colors:
- '#7a7a7a'
background:
enabled: false
yaxis:
- show: true
decimalsInFloat: 0
forceNiceScale: true
min: 0
series:
- entity: sensor.senseair_co2_value
color: white
curve: stepline
show:
datalabels: true
opacity: 0
group_by:
func: last
duration: 48hr
transform: return x ;
color: white
curve: stepline
show:
in_header: false
extremas: true
stroke_width: 1.5
opacity: 0.8
float_precision: 0
group_by:
func: median
duration: 30min
Nice! Thank you very much!
Here’s my full configuration, and a picture to prove it:
Although, I have found that it is finicky and not always reliable with all chart types. E.g. I still can’t get my bar chart to display a single tooltip for all values. The key to success seems to be having existing data points at the same timestamps, which in my case was achieved by the group_by function.
graph_span: 12h
header:
show: true
show_states: true
apex_config:
grid:
show: false
legend:
show: false
tooltip:
shared: true
chart:
height: 100px
yaxis:
- id: temperature
tickAmount: 2
max: EVAL:max => max
min: EVAL:min => min
labels:
formatter: |
EVAL:v => `${Math.round(v)}°C`
all_series_config:
stroke_width: 2
opacity: 0.8
group_by:
func: avg
duration: 1min
fill: last
series:
- entity: sensor.temperature_sensor_1_temperature
color: orange
- entity: sensor.temperature_sensor_2_temperature
color: dodgerblue
- entity: sensor.temperature_sensor_3_temperature
color: red
- entity: sensor.temperature_sensor_4_temperature
color: green
I have added ApexCharts Card templates using the Home Assistant ‘raw configuration editor’ and the ApexCharts Card picks them up fine. However, every time I restart Home Assistant, the templates are removed by some process and the card says the template is missing. If I manually add them back after this point it they are not removed again, until the next restart.
Does anyone else experience this? It only started happening a month or two ago.
Should I switch from using the raw configuration editor to switching to YAML mode and creating a separate config>/ui-lovelace.yaml file as mentioned at Dashboards - Home Assistant ?
Update: This is now seems to be fixed after upgrading HA to core-2021.9.6, supervisor-2021.09.0, and Home Assistant OS 6.4.
Is it possible to hide single series names from the legend?
I don’t need the 10th and 90th percentile labels in the legend:
Also is it possible to stack only two series in a graph?
That way I could generate and area for FF90-FF10 and stack it on top of a line FF10 (with 0 line weight) to achieve this sort of result:
Closest I can get for now:
It appears the stack option is applied to the chart level, not the yaxis level, so I don’t think this is possible.
hello
i want to plot a pie chart. i have 4 power monitor sensors. TV, nuc, LED. ENT is sum of these three sensors and some other devoces. i want to plot a pie chart with these three and rest of the devices. how can I wrote that in transform?
- type: custom:apexcharts-card
header:
show: false
show_states: false
apex_config:
plotOptions:
pie:
donut:
total:
show: true
showAlways: true
chart_type: pie
series:
- entity: sensor.yearly_energy_nuc
- entity: sensor.yearly_energy_led
- entity: sensor.yearly_energy_tv
- entity: sensor.yearly_energy_ent
transform: "return x - (hass.states['sensor.yearly_energy_nuc']+hass.states['sensor.yearly_energy_nuc']+hass.states['sensor.yearly_energy_nuc']);"
