How do I install and use the Lovelace area card created by @zsarnett that is mentioned in the details for version 2021.12?
From the notes for version 2021.12.
But that is not all, @zsarnett created a brand new area Lovelace card. This card will use the picture you’ve uploaded for your area, and it automatically populates with entities of devices you have assigned to that specific area.
But, it autopopupulates things like switches, that i wouldnt have on feks the kitchen card.
One accidental press on that switch, and all appliances are turned off…
Q: Is there a way to exlude certain items in the YAML for the card?
Also, lights are just grouped as ALL lights.
Q: Is there a way to get all lights to show next to each-other?
Basically, is there a guide or readme on how to customize the card? Or is it just all-auto?
@DarkWader agree with your assessment, what I wonder - I have plenty of integrations that dont have an actual device only an entity but you cannot assign them to areas …
I tried the area card with my office. I have 3 devices that are broadcasting temperature via an entity. 2 are zigbee sensors (bad quality) one is a hmip heating thermostat (good one). It seems, that the shown temperature value in the card is somehow a mix of all 3 values.
How can I choose one specific entity for the temperature? or how do I remove the area from the entity, but not from the device, as I need the motion detector.
Is there any more help/documentation available? The (?) goes to “404”…
Yes, that is all there is for now, plus the option show_camera: true to show a camera live feed instead of a static image.
Additional iterations will be required to offer more control and better entity selection. E.g. I don’t even get a temperature shown since climate entities apparently are not considered (I assume you have a dedicated temperature entity in your attic?).
The new Area card also lacks a documentation page like all other Lovelace cards have.
I also have the issue with the temperature that gets unexplainable value when there are multiple temperature sensors in one area.
The on/off switch works, but you have to be really careful with that. Before you know it you have turned off essential devices that are setup as a switch in that area.
In the end this card has potential but it should be much more configurable.
I thought the AREAS cards were gonna be useful but at the moment far from it unfortunately. I hope they will get some much needed attention for the next release. Just a few thoughts below.
lights should open popup to show which lights and not just shut down all of them
same for power switches (which is dangerous anyway, switch off fridge and kitchen light !)
the movement icon should be there all the time to indicate no movement for an area
lots of entities are not listed on the card although put in the area; humidity, lux, smoke
I would expect a least a shortcut to the ‘device’ page for an item listed in this area
Give @zsarnett a break, you should not “expect” anything as he made this out of his own time and kindness.
This is the reason it is Open Source, if you want or “expect” more functionality, you can add the changes yourself.
Learn how to work on the development version of HA, make the tweaks, create a Pull Request, if satisfactory it will be merged & then it will be in a future release where someone else can “expect” things. And you will also feel disheartened that your efforts are not appreciated.
You are not forced to use the card in its current state. Be kind.
Thanks for all the feedback everyone. When we release cards they aren’t always going to be the most configurable the first release. Remember. Features can be added. But its hard to remove features. (Breaking Changes)
So for the first release, its all automatically configured. This was decided so that it was an easy card to add. Hearing your feedback on what you want added is great but don’t expect every feature possible added on the first try or ever. Custom Cards can be cloned to have all features if wanted.
We are going to add more and more to coming releases. The area card is going to be a big focus in Q1 for me to update and add features.
Thanks @Mike_M Appreciate the kind words and you are 100% correct. Everything is done in free time for the most part. Try not to expect things and simply ask Next time that feature may be in there.
Thanks again. Keep feedback coming on what you want to see
Hello everyone,
I have now made a few attempts with the new area card. It would be very nice if these could be resized to better integrate them into the dashboard.
Unfortunately for me these are either too small or too big
