Ariela - Home Assistant Android Client - Updates Thread
Yes, it is added to my TODO list. Thank you very much for the support.
Hello all,
Version 1.2.7.3 is out.
What’s new:
  • faster icons loading after first install
  • UI / entities changes should be more stable now
  • other fixes
  • better shopping card stability
  • better UI functionality
Version 1.2.7.4 is out.
What’s new:
  • NEW: added vacuum entities support
  • fixed issue when display gauge card
  • fixed media player buttons UI display
  • fixed entity button card display & update issue
  • fixed light panel brightness update
  • fixed advanced dialog display issue for lights entities
  • fixed crash when clicking picture glance card
Please test it and let me know how it goes.
When supporting custom card-modder?
Its added to my TODO list, can’t tell you an exact date, sorry.
Hello all,
Version 1.2.7.5 is out:
What’s new:
  • added shopping list in the left menu
  • added notifications support
  • fixed picture glance tint icon issue
  • fixed crash when entering vacuum advanced dialog
Please test it and let me know how it goes. Thank you.
Hello all,
Version 1.2.7.6 is out.
What’s new:
  • added possibility to edit entity name & icon
  • add ability to edit name & icon for tabs (non lovelace mode)
  • do not show keyboard when entering shopping activity
  • shopping activity UI improvements
  • fixed light lovelace card issue (it was clickable outside its display)
  • allow sending empty alarm codes
Hello all,
Version 1.2.7.7 is out.
What’s new:
  • NEW: add support for water heater entities
  • add possibility to change number of columns on which cards can be shown
  • add possibility to edit entity picture
  • added instruction message when enabling debug mode
  • show advanced entity dialog when long pressing lovelace light card
  • toggle light entity when clicking on the light image from lovelace light card
  • add scroll view on server configuration in order to properly display all items on devices with lower resolution
Version 1.2.7.8 is out.
What’s new:
  • added support for lovelace horizontal cards
  • fix title display for lovelace Gauge card
  • make entity-button lovelace card smaller
  • change notification name from FCM notification to Push Notifications
  • change Ariela Notification channel to “On-Going Notification”
  • support for custom icons in glance cards
  • support for custom names in glance cards
  • support for hiding status of entities in glance cards
  • support for camera_image tag in picture entity card (lovelace)
Thank you.
Version 1.2.7.9 is out.
What’s new:
  • fixed invalid URL for connection
  • add support for binary sensor icons
Hi there. Thanks for making the app. I tried logging in but it seems the app doesn’t support 2 factor authentication if it’s setup in HA. If it is, I’m doing something wrong. Thanks!
Vaughn
Actually 2 factor auth its working too. Just use the weblogin and should work. Please let me know if you succeeded.
More details you can find here: Ariela - Home Assistant Android Client - #1029 by Ionut
Hello everybody,
Ariela is on facebook now: https://www.facebook.com/Ariela-Home-Assistant-Android-client-343298616397657
You can use the page to post issues, improvements, other ideas.
Best regards
Hi. Is there any way to mark apsence after person was disconnected x time??
Currently not from Ariela. Home Assistant will retain the last user state until new update comes from Ariela. What you can do is create an automation in Home Assistant like: if last update from user was x hours, then update the state manually.
Best regards,
Ionut
Hello all
Version 1.2.8 is out.
What’s new:
  • add posibility to create persistent notifications
  • small UI changes regarding RTL
  • updated polish translation
  • Dark Sky card UI change when using black theme
  • fixed crash when showing camera fullscreen in glance cards
Hello all,
Version 1.2.8.1 is out.
What’s new:
  • added sensors as badges in states UI
  • enable zoom controls in Lovelace IFrame cards
  • fix dark sky rendering issues when using dark themes
  • update romanian translation
  • support for weather lovelace card
Thank you.
Hello all,
Version 1.2.8.2 is out.
What’s new:
  • NEW: Developer Tools services
  • Horizontal-Stack lovelace card: show items at half width if multiple items
  • do not restart the app if orientation changed
Thank you.
Hello everybody,
https://github.com/MCrissDev/Ariela has been created. Here you can find english string file (you can use it to create translations for other languages). Also you can use this repository to create / watch issues.
Hello all,
Version 1.2.8.3 is out.
What’s new:
  • the setup process has been refactored (much easier setup)
  • fix display issue with entity-filter card
  • some refactoring of the code
  • revert zoom “fix” for IFrame lovelace cards
  • make horizontal-stack cards act as horizontal
