Ariela - Home Assistant Android Client - Updates Thread
  • make horizontal-stack cards act as horizontal
I have some button-card on a horizontal-stack, but act like vertical stack yet…
Wanted to say act as vertical. :stuck_out_tongue: There are some rendering issues for now on the horizontal stack card, so this alternative was put instead.
Hello all,
Version 1.2.8.4 is out.
What’s new:
  • added norvegian localization
  • fix issue with duplicate badges in states UI mode
Please test it and let me know how it goes.
Great!
Do you plan to add floorplan? And fullscreen cam?
Floorplan: YES its added to my TODO list but it will take some time until this feature will be available.
Fullscreen cam: this feature is already available. You just click on camera entity and it will be displayed fullscreen.
Hello all,
Version 1.2.8.5 is out.
What’s new:
  • fixed crash when using web ui mode
  • new Android Wear of displaying the entities
Is there any way to use the Ariela device tracker to replace google_maps in the as a tracker? Google location sharing is horrendously slow, some times as much as 15 minutes. I want to use something that updates more frequently and thought the Ariela device tracker would do the trick. I haven’t figured out a way for it to show up on the map within HA. I also don’t want multiple device trackers running that suck my battery dry.
Version 1.2.8.6 is out.
What’s new
  • fixed crash when enabling firebase notification
  • fixed shopping list display when using dark UI
  • fixed clear button display on shopping list
  • fixed UI display issue when showing HA notifications
  • support for lovelace view background
  • fixed inconsistent text size for climate / badges views
  • show sensor value instead of icon in badges
  • lovelace show conditional cards(it will always show the card from conditional)
Please let me know how it works.
Version 1.2.8.7 is out.
What’s new:
  • NEW: NFC MQTT reader (read and send NFC tags to Home Assistant)
  • fixed crash when icon / picture / camera images are GIF
Please let me know if you find any issues.
Hello all,
If anyone want to check what lovelace cards are currently supported by Ariela, the list can be found here: http://ariela.surodev.com/2019/02/15/lovelace-cards/
Thank you.
Reporting a lovelace camera issue:
  - name: Weather Radar
    platform: generic
    still_image_url: https://radblast.wunderground.com/cgi-bin/radar/WUNIDS_map?station=WHK&brand=wui&num=10&delay=15&type=C0R&frame=0&scale=1.000&noclutter=0&showstorms=99&mapx=400&mapy=240&centerx=400&centery=240&transx=0&transy=0&showlabels=1&severe=0&rainsnow=1&lightning=1&smooth=1&rand=25549519&lat=0&lon=0&label=you
      - type: vertical-stack
        cards:
          - type: picture-entity
            entity: camera.weather_radar
            show_info: false
Shows an empty card but tapping on the card to get its details, I can see the weather radar displayed in a small icon next to the information.
Also, can there be an option (didn’t see one) where I can manually send GPS coords rather than waiting for motion to happen? I tried setting it to 1m and walked around my home but it didn’t send anything and I may not be going outside today to test otherwise :slight_smile:
EDIT: Sorry, I think I posted this into the wrong thread, I think it should be over in the Ariela thread, sorry.
No worries,
Please use the contact option from Ariela, and also it would be nice if you can include a screenshot of the issue / screenshot of how its showing in HA server.
Just sent it, hopefully it makes it to you.
Thanks, got the info.
Hello everybody,
Do not forget that you can also use https://github.com/MCrissDev/Ariela/issues in order to report issues / ideas for improvement.
Also, at http://ariela.surodev.com/ you can find useful documentation, change log etc.
Thank you very much.
Hello everybody,
Version 1.2.8.9 is out.
What’s new:
  • NEW: Lovelace sensor card support
  • NEW: added ability to switch on / off groups (states ui only)
  • fixed issue while setup when entering spaces after IP address
  • change button text from “OK” to “Continue” while setup
  • fixed shopping list rendering glitch
  • update lovelace light UI card
  • WEAR: force updating the credentials on the watch
Hello all,
Version 1.2.9 is out.
What’s new
  • Picture entity card: hide header if show_name && show_state are false
  • NEW: Lovelace thermostat card support
Please test it and let me know how it goes. Thank you.
Version 1.2.9.1 is out.
What’s new:
  • do not show measurement in badges status
  • states UI: do not show hidden entities as badges
  • minor UI changes to MQTT sensors activity
  • glance card: handle show name attribute
  • glance card: handle columns attribute
  • glance card: handle show_status attribute
  • entity filter card: fix display issue
  • fixed invalid icon display in lovelace button cards
  • fixed crash in firebase notification when invalid color was set
Little spoiler: new theme for tomorrow’s update: Dark Green
Hello all,
Version 1.2.9.2 is out.
What’s new
  • NEW: Dark Green theme
  • apply progress theme color for thermostat / light lovelace cards
  • apply chart color based on the theme selected (sensor lovelace card)
  • small UI updates in thermostat advanced controls
  • ui updates in the MQTT sensors screen
  • fixed device tracker issue when device name ended with “_”
Please test it and let me know how it work.
Thank you.
