Ariela - Home Assistant Android Client - Updates Thread
Hello all,
Version 1.2.9.3 is out:
What’s new:
  • NEW: added build in MQTT client
  • added german localization
  • optimise the auto-reconnect option
  • change MQTT battery sensor icon according to charging status
  • apply app theme to server configuration screens
Please test it and let me know how it works. Thank you.
Hello all,
Version 1.2.9.4 is out.
What’s new:
  • CAMERA permission introduced (only used when enabled MQTT camera)
  • NEW: MQTT Front camera (send image from front camera to Home Assistant)
  • NEW: MQTT Back camera (send image from back camera to Home Assistant)
  • gray out picture entity card image when entity state is off
  • fix tap action issue with picture entity cards
MQTT Camera documentation: http://ariela.surodev.com/2019/02/24/front-back-camera-streaming/
I know it says the picture glance card is supported, but I can’t get Ariela Pro to actually display any picture, it’s just empty, am I missing something?
Please send me your card configuration so i can check.
Hello all,
Version 1.2.9.5 is out.
What’s new:
  • fixed picture glance image display issue
  • do not show tabs when having just one item view
  • do not show shopping list if not enabled in Home Assistant
  • reset step counter value after 24h
  • update German localization
Hi.
The 1.2.9.5 version on Note 9 is repporting wrong step counter.
On the phone it´s 3382 and in hass -240.
It increases in -.
Before the app update I had 3090 on the phone but 439 in hass.
Thank you for reporting. I will investigate the issue.
Hello all,
Version 1.2.9.6 is out.
What’s new:
  • redesign Settings screen
  • improve thermostat card slider touch behaviour
  • improve light card slider touch behaviour
  • fixed negative step counter sensor value
  • small UI changes
  • change wear app name to “Ariela”
  • added option (forced) to send credentials to wear app
Please test it and let me know how it goes.
Thank you.
Hello all,
Version 1.2.9.7 is out.
What’s new:
  • fixed MQTT front camera retrieve issue
  • fixed MQTT back camera retrieve issue
  • fixed light card brightness set issue
  • NEW: support for person entities
  • fixed picture entity camera image retrieval
  • NEW: stream camera support
  • do not gray out picture entity image if having camera
Please test it and let me know how it goes. Thank you.
Hello all,
Version 1.2.9.8 is out.
What’s new:
  • NEW: MQTT Text to Speech (TTS) support
  • fixed picture glance background issue when camera is set
  • show entity names on one line only
  • fixed crash when entering settings
  • fixed firebase registration issue
  • webview mode back button improvements
TTS MQTT Documentation: http://ariela.surodev.com/2019/02/28/mqtt-text-to-speech/
Hello all,
Version 1.2.9.9 is out.
What’s new:
  • fixed Battery sensor invalid icon issue
  • NEW: conditional lovelace card support
  • fixed MQTT camera rotation issue
  • fixed light lovelace card slider max value
  • updated german localization
Hello all,
Version 1.3.0.0 is out.
What’s new:
  • NEW: add possibility to change server read / connect timeout
  • NEW: next alarm MQTT sensor
  • fixed payload MQTT retrive issue
  • fixed MQTT apps run kodi example issue
  • support for payload_template on MQTT calls
  • fixed settings crash while changing orientation
  • fixed build in MQTT client while disconnecting
  • fixed crash of conditional card
Hi Ionut,
I switched on BT sensor and added the code to my HA config.
But I continue to see the paired devices as “objects”:
BLUETOOTH SENSOR NAME
bonded devices
[object Object], [object Object], [object Object], [object Object], [object Object], [object Object]
mac
02:00:00:00:00:00
discovered devices
so no device name or mac adress or rssi
A discovered device object its actually a JSON object.
Such JSON object have fallowing items:
  • name : String representing device name
  • mac : String BluetoothDevice mac address
  • rssi: integer representing signal level
Example getting device name of the first discovered item:
discovered_devices[0].name
More details you can find here: http://ariela.surodev.com/2019/01/08/bluetooth/
Please let me know if its working.
Hello all,
Version 1.3.0.1 is out.
What’s new:
  • added Swedish localization
  • fixed front mqtt camera orientation issue
  • NEW: support for switching on / off lovelace entities card
  • hide VR menu button if Google Voice Recognition not available
Also, do not forget these links:
Ariela documentation: http://ariela.surodev.com/
Ariela localization files & bug report: https://github.com/MCrissDev/Ariela
Hello all,
Version 1.3.0.2 is out.
What’s new:
  • NEW: added Ariela last seen sensor
  • NEW: added option to start Ariela at boot
  • small ui changes
  • fixed sending negative steps counter
This new version introduce a new sensor called “Ariela Availability”. If you enable this sensor, Ariela will update the sensor value with the last time Ariela communicated with Home Assistant. This means you can use this sensor in order to create automation like “turn off Lights if Ariela wasn’t communicating with Home Assistant server for 10 minutes”. This can be useful if for example Ariela is not able to connect and send updates like geolocation, other sensors values etc.
Sensor documentation and example: http://ariela.surodev.com/2019/03/06/last-seen-sensor/
Hello all,
Version 1.3.0.3 is out.
What’s new:
  • NEW: ability to show and control entities in notification bar
  • small UI changes
For adding items to notification go to Ariela -> Settings -> Notifications -> Notification Entities.
Hello all,
Version 1.3.0.4 is out.
What’s new:
  • fixed displaying picture-glance cards when no entities are set
  • add ability to change local HA IP address
  • move the configure external option to Settings -> Server connection
  • small update in availability MQTT sensor
hi, in a galaxy s10+ in the settings if I choose to show the webui instead of the android views then there is no way of going back to modify the app settings
From the left part of the screen do a swipe right. Please let me know if works.
