why not just shorten the cord? no one will know when you move out if it’s slightly shorter
Maybe just make a small loop in the cord halfway up so it won’t tangle.
I dunno if looking over some of my recent findings for an air purifier over here might somehow help you.
Darren I guess you are thinking of a different type of blind mechanism.
Dave, I may be mistaken, but i don’t think it is quite that simple.
I have not found a join in the beaded cord where i can simply remove a few links. I can certainly cut and shorten the cord, but since the cord is (slightly) shorter than the blind I will have to research how to join it back up so that the join will flow through one of the sprockets without jamming.
And when I move out I will have to fill and paint over the existing loop mounting hole. I know, not a big deal for a tradie, but I am a retired programmer who never got into DIY.
Anyway, I have instead changed the power plug to a right-angle plug. It only just fits and doesn’t allow easy access to the setting button or the tab which hods the wall mounting. Hopefully it will be good enough for here and now. Thank you for your assistance.
I bet you could find the right adapter if you dug around carefully on Ali Express and didn’t mind waiting.
AU $3.23 | 1pcs DC 7.4mm x 5.0mm Female To Male Right Angled Power Connector Adapter for DELL HP Laptop Tablet PC
Edit: Sorry, just saw you’re latest post above… You’ve solved it. Nice one…
I don’t think they would fit through the driver. Maybe it could be positioned to not have to though.
I doubt the metal joint will fit through either of the drive sprockets (top attached to the blind or bottom at the drive motor).
Starting with the joint touching the blind drive motor, then opening the blind, the blind will go up to about 10cm short of fully raised before hitting the top sprocket. I could live with this.
Instead i have replaced the blind motor’s power plug (I forgot to mention I bought the mains-powered model, so the power plug will be permanently connected) with a right-angle plug. It comes right down to touch the bottom window sill … but it does the job while leaving the blind unmodified.
Thanks guys !
Do you reckon we could convince Phil Hawthorne to campaign on air for Nabu Casa charging in $AUD?
On a side note, Phil for PM! - does such an awesome job on the podcast. So well spoken.
Well, I spoke to soon!
All 6 of my Telstra/Sercomm SZ-ESW01-AU plugs have started turning off at random intervals but all within 30 seconds of each other.
They can go several days without a problem then turn off repeatedly for several hours.
Some have devices plugged in and others do not.
I’m currently saving the debug logs for zigbee2mqtt and mqtt to see if I can find if the command is coming from HA, zigbee2mqtt or the plugs themselves.
It might be time to build a ZigBee network sniffer as I have a couple of the old Atmel Raven development kits lying around.
EDIT:
running with zigbee2mqtt hass addon v1.23.0-1
Thanks for the reply - I was already thinking mine were possessed somehow. I haven’t found any pattern yet or any external trigger that would cause this issue. My plugs sometimes turn on/off within seconds of each other, but sometimes it’s minutes or hours.
I upgraded to the latest deCONZ version, upgrade to the latest Conbee firmware, but without luck.
anyone could do better than Scomo !!!
go Phil
Nothing suspicious in the logs yet, of course it stopped failing when i setup debugging…
no visible mqtt commands being sent from hass so moving on to the zigbee logs
maybe there is some group command being sent? I’m not even sure where to look for that.
I’ve used all of my luck so far with a mix of Ikea, Hue, Mercator, Xiaomi, Tuya and Yale.
Finally got something in the zigbee2mqtt debug logs but not sure what I’m seeing
debug 2022-02-27 16:55:36: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":202574}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:36: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":78,"power":202.57,"state":"ON"}'
debug 2022-02-27 16:55:37: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":430}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:37: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":63,"power":0.43,"state":"ON"}'
debug 2022-02-27 16:55:38: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":4383}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:38: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":42,"power":4.38,"state":"ON"}'
debug 2022-02-27 16:55:40: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":66112}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:40: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":72,"power":66.11,"state":"ON"}'
debug 2022-02-27 16:55:43: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":4354}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:43: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":42,"power":4.35,"state":"ON"}'
debug 2022-02-27 16:55:45: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":67286}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:45: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":75,"power":67.29,"state":"ON"}'
debug 2022-02-27 16:55:47: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":67286}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:47: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":72,"power":67.29,"state":"ON"}'
debug 2022-02-27 16:55:50: Device 'zb_plug_06' announced itself
info 2022-02-27 16:55:50: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"zb_plug_06","ieee_address":"0x000d6f000f8e6f9b"},"type":"device_announce"}'
info 2022-02-27 16:55:50: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"zb_plug_06"},"type":"device_announced"}'
debug 2022-02-27 16:55:51: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":67286}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:51: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":75,"power":67.29,"state":"ON"}'
debug 2022-02-27 16:55:51: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":67572}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:51: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":75,"power":67.57,"state":"ON"}'
debug 2022-02-27 16:55:52: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":67572}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:52: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":78,"power":67.57,"state":"ON"}'
debug 2022-02-27 16:55:52: Retrieving state of 'zb_plug_06' after reconnect
debug 2022-02-27 16:55:55: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":65539}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:55: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":75,"power":65.54,"state":"ON"}'
debug 2022-02-27 16:55:56: Received Zigbee message from 'zb_plug_06', type 'readResponse', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID 0
info 2022-02-27 16:55:56: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":72,"power":65.54,"state":"ON"}'
debug 2022-02-27 16:56:00: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":68117}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:00: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":75,"power":68.12,"state":"ON"}'
debug 2022-02-27 16:56:03: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":188767}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:03: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":81,"power":188.77,"state":"ON"}'
debug 2022-02-27 16:56:05: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":66083}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:05: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":78,"power":66.08,"state":"ON"}'
debug 2022-02-27 16:56:06: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":191947}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:06: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":84,"power":191.95,"state":"ON"}'
debug 2022-02-27 16:56:06: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":197590}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:06: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":81,"power":197.59,"state":"ON"}'
debug 2022-02-27 16:56:14: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":65281}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:14: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":81,"power":65.28,"state":"ON"}'
debug 2022-02-27 16:56:16: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":64651}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:16: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":81,"power":64.65,"state":"ON"}'
debug 2022-02-27 16:56:21: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":65940}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:21: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":81,"power":65.94,"state":"ON"}'
debug 2022-02-27 16:56:21: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":198449}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:21: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":84,"power":198.45,"state":"ON"}'
debug 2022-02-27 16:56:37: Received Zigbee message from 'leak_sensor_05', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3005,"10":0,"100":0,"3":38,"4":5032,"5":11,"6":[0,1],"8":518}}' from endpoint 1 with groupID 0
debug 2022-02-27 16:56:53: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":487}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:53: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":81,"power":0.49,"state":"ON"}'
debug 2022-02-27 16:56:53: Device 'zb_plug_06' announced itself
info 2022-02-27 16:56:53: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"zb_plug_06","ieee_address":"0x000d6f000f8e6f9b"},"type":"device_announce"}'
info 2022-02-27 16:56:53: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"zb_plug_06"},"type":"device_announced"}'
debug 2022-02-27 16:56:54: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":179544}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:54: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":54,"power":179.54,"state":"ON"}'
debug 2022-02-27 16:56:54: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":4411}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:54: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":81,"power":4.41,"state":"ON"}'
debug 2022-02-27 16:56:55: Retrieving state of 'zb_plug_06' after reconnect
debug 2022-02-27 16:56:55: Received Zigbee message from 'zb_plug_06', type 'readResponse', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:55: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":81,"power":65.94,"state":"ON"}'
debug 2022-02-27 16:56:56: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":68374}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:56: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":81,"power":68.37,"state":"ON"}'
debug 2022-02-27 16:56:56: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":194439}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:56: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":51,"power":194.44,"state":"ON"}'
debug 2022-02-27 16:56:57: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":401}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:57: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":54,"power":0.4,"state":"ON"}'
debug 2022-02-27 16:56:59: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":4354}' from endpoint 1 with groupID 0
info 2022-02-27 16:56:59: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":81,"power":4.35,"state":"ON"}'
debug 2022-02-27 16:57:01: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":70179}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:01: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":60,"power":70.18,"state":"ON"}'
debug 2022-02-27 16:57:01: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":204637}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:01: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":51,"power":204.64,"state":"ON"}'
debug 2022-02-27 16:57:02: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":458}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:02: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":51,"power":0.46,"state":"ON"}'
debug 2022-02-27 16:57:04: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":4383}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:04: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":60,"power":4.38,"state":"ON"}'
debug 2022-02-27 16:57:06: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":67773}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:06: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":63,"power":67.77,"state":"ON"}'
debug 2022-02-27 16:57:06: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":196158}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:06: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":54,"power":196.16,"state":"ON"}'
debug 2022-02-27 16:57:07: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":573}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:07: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":54,"power":0.57,"state":"ON"}'
debug 2022-02-27 16:57:09: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":4325}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:09: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":63,"power":4.33,"state":"ON"}'
debug 2022-02-27 16:57:11: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":68661}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:11: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":60,"power":68.66,"state":"ON"}'
debug 2022-02-27 16:57:11: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":198363}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:11: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":51,"power":198.36,"state":"ON"}'
debug 2022-02-27 16:57:12: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":544}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:12: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":54,"power":0.54,"state":"ON"}'
debug 2022-02-27 16:57:14: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:14: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":63,"power":4.33,"state":"OFF"}'
debug 2022-02-27 16:57:14: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:14: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":51,"power":0.54,"state":"OFF"}'
debug 2022-02-27 16:57:14: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:14: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":63,"power":68.66,"state":"OFF"}'
debug 2022-02-27 16:57:15: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":4440}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:15: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":60,"power":4.44,"state":"OFF"}'
debug 2022-02-27 16:57:15: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:15: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":51,"power":198.36,"state":"OFF"}'
debug 2022-02-27 16:57:16: Received Zigbee message from 'zb_plug_06', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:16: MQTT publish: topic 'zigbee2mqtt/zb_plug_06', payload '{"linkquality":60,"power":0,"state":"OFF"}'
debug 2022-02-27 16:57:16: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":197533}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:16: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":54,"power":197.53,"state":"OFF"}'
debug 2022-02-27 16:57:17: Received Zigbee message from 'zb_plug_03', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:17: MQTT publish: topic 'zigbee2mqtt/zb_plug_03', payload '{"linkquality":54,"power":0,"state":"OFF"}'
debug 2022-02-27 16:57:20: Received Zigbee message from 'zb_plug_04', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:20: MQTT publish: topic 'zigbee2mqtt/zb_plug_04', payload '{"linkquality":63,"power":0,"state":"OFF"}'
debug 2022-02-27 16:57:21: Received Zigbee message from 'zb_plug_05', type 'attributeReport', cluster 'seMetering', data '{"instantaneousDemand":0}' from endpoint 1 with groupID 0
info 2022-02-27 16:57:21: MQTT publish: topic 'zigbee2mqtt/zb_plug_05', payload '{"linkquality":54,"power":0,"state":"OFF"}'
debug 2022-02-27 16:58:48: Saving state to file /config/zigbee2mqtt/state.json
I’m using 9 of the Telstra/Sercomm plugs now, after trialling 3 without issues for a period, and I’ve had the occasional switch just turn itself off. One happened a day after I added it to the fridge of all things, and my backup automation (“keep this thing on”) failed - the missus was not impressed. Luckily we were home and could manually turn it back on.
Only 2 of the 9 have hiccupped at all. The rest have been solid. I’ve tried to set availability to 1 minute in z2m, so that I can catch them going offline and automate turning them back on again. However, after a power outage, some of them remained “offline” for hours.
I don’t suppose there’s a way to set them to default to On after a power outage, is there?
I’m mainly using them for power monitoring, being the first decent affordable reliable Zigbee smart-plug with power monitoring I’ve found.
Not sure, but it works perfect with ZHA. One thing I’ve noticed in the few days of using it, I haven’t seen any End devices connect to it yet, but my router devices don’t mind it.
I’m trying to find the time to go through the zigbee documentation to find out if there is some sort of group command being sent, but at the moment I’m overloaded at work.
I’m fairly certain its not home assistant causing the problem and some of us are using zha and others zigbee2mqtt.
Just a quick warning for people that may purchase without reading the reviews…I was browsing the Bunnings site and saw this:
Now I’ve previously mentioned on here that Deta electrical equipment is terrible and that I don’t touch it (non-smart gear included) but this just gives more reason to stay clear. There are multiple reports of these smart tubes melting / catching fire.
Good call. The only Deta stuff I buy is strictly hardware, such as https://www.bunnings.co.nz/deta-corrugated-conduit-gland-20mm-2740b_p4330875
Unfortunately the previous owner of my house had a heap of Deta outlets installed which I have replaced all of, they are absolute rubbish.
