Not sure why you would bother getting those from China, I buy dimmable 10W LED downlights with colour temperature selecting switch from a local supplier for $8.80 inc GST. In my hand straight away rather than waiting a month for the slow boat…
But, if you want to… The Hue dimmer would likely work, although I have no experience with them and haven’t read any info to confirm.
You could also use an Aeotec Z-Wave dimmer (would need a Z-Wave hub if you don’t already have one) which are about $90 and would be able to run 8 of those LED’s at once.
Could you give us a link to the ones you’re talking about?
What I meant originally is how can I integrate them through HA? Do I need to change the driver for each? Or is there a device (like a voltage limited) I can attach in line to dim them?
I’m confused about what can be done to make them smart
To make them integrate with HA you can use the dimmer I referred to above (the manual was linked but here is a seller). Like I said above though, stay away from DHS branded gear, it’s not great, hence it’s cheap. There are many online retailers, I think I linked to a bunch early in this thread.
Obviously I’m referring to z-wave a lot here which isn’t the only option, but it’s a good one. I found found my z-wave network to be rock solid and super fast to respond. Also nice that it’s a mesh network and doesn’t add load to your wifi.
So i bought the brilliant outdoor led lights with the pir from aldi this morning. Ive opened it up in hope of flashing tasmota. No dice. I appears the esp is in the pir and there is a blind screw holding the pir together. I dont have a bit small enough to fit. Ill try and fashion something during the week to see if i cant get in there for a look.
Sorry I cant help you with that Dave. This brilliantlighting mob seems to have quite a large range of smart products. It would be nice if someone more clever than I could build an integration. That said I guess we would be relying on a 3rd party to control them.
I could not get the ALDI Smart Downlight flashed through tuya-convert or through stock Tuya Integration of HA.
Managed to flash Tasmota through serial and is working with
After making a dodgy screwdriver (cut the tip off and soldered it to a piece of thin steel) I got the Aldi outdoor light open. Should be easy to flash once its open.
