Has anyone found a good ceiling fan controller solution for use with Iconic switches?
I’ve got a couple of the manual rotary switches and while they are ok the movement isn’t great and I’d like to move to something that can be controlled by HA.
I’m thinking it would be great to have a momentary switch connected to something like a Shelley to toggle through the options?
You could use an Iconic momentary if you move the capacitors/ speed control to the fan end (instead of @ the switch) using a “Brilliant Smart Wifi Ceiling Fan Controller 99333”.
Then program a Shelly with esphome on the Iconic to act as an independent multi click toggle.
You would have to be pretty keen on Iconic switches though
A LOT easier with a ‘Deta Grid Connect Smart Fan Speed Controller with Touch Light Switch’ instead.
Or buy a new fan (DC maybe) with tuya module included
Doesn’t seem like anyone else has these, but just in case you do, there are some errors in the manual and a bug in the firmware for scene activation.
The manual includes a reference to two additional configuration parameters - parameter options 4 and 5 don’t actually exist in the firmware, so you can only set 0-3.
The bug with scene activation has been worked around in zwavejs, and the device will now properly activate scenes.
This means that you can now intercept the notifcation in HomeAssistant and use it to trigger automations… You will need to set an association group (group 2) for the device back to the controller in zwavejs before scenes will be notified, but that’s pretty simple.
Price is factor but so is product category. I have a lot of experience in this field you should be 100% covered. Things failing in general is not ok and multiple/ if you find other people online with same problem only strengthens the argument. (for reference I taken apple to VCAT and won $650 for an 8 year old Mac that died. Wether the company chooses to do it out of “good will” or otherwise I’ would be persistent for a replacement or refund
Cheapest? I don’t think so but I am seriously interested why you think they are a fire hazard. I have many of them installed in my house for over 3 years now and I have not had any issues with them! Is there a rating or a benchmark that you are using?
I bought a couple of the Sercomm (Telstra) smart plugs mentioned further up this topic.
I have been using one for about six months and I have noticed it has become very chatty with mqtt. The zigbee2mqtt log shows it is reporting every two seconds, which makes for a massive log file. This has only started happening in the last few weeks.
I have tried changing the reporting settings for the plug in zigbee2mqtt, but that didn’t seem to help - mind you the settings are a bit of a mystery to me, so maybe I just made it worse.
They do send data, but other devices only update every 10 or 60 seconds. I set this one to a 30 second update on everything (or so I thought) and it still sends something every 2 seconds.
If I am reading the reporting setting correctly, it should report on/off immediately but things like current should only report every 10 seconds and even then, only if the reading has changed by “x”.
Voltage - I thought - was set to only report every 360 seconds and then only if it varied by more than 3 volts.
I might just be reading the z2m configuration wrong.
I’ve got six of them and they will run perfectly for months then every few days turn off randomly usually within a few seconds of each other…
if you then turn them back on they switch off again, you have to wait ten minutes before switching them on again.
At one point I thought it was overheating but even ones with no load shut down.
I’ve tried removing them from the network (I had a crash and lost all my configuration so the adapter was unplugged for several days) and they still did the same thing even when not connected to the router
I planned on building a ZigBee sniffer but it turns out my old Atmel Raven sniffer doesn’t work and I haven’t had time to get a new one.
Tks - It’s a pity there are some issues with these because I was hoping to move to Zigbee and away from my Tuya Local switches. These looked like a great alternative.
The other downside is their physical size. You can’t place two together on a double outlet, while the little Grid Connect (Tuya) plugs from Bunnings fit nicely.
YMMV as I am using two and no problems at all. The only thing I think is they aren’t great as routers for devices that report infrequently (eg. my door sensors) as they were dropping them from my network.
