Australia - Electrically Certified Hardware
Definitely not legal.
Am I right that these Athomā€™s arenā€™t certified?
I just bought 4.
My Brilliantā€™s running ESPHOME are dying after a year or so.
Good question.
Unless something has changed since last time that question was asked, the answer is no, they are not certified for use in Australia.
Hi, I am looking to get some more Brilliant Smart Ceiling Fan Wall Controllers, I note the ones I had from a few years ago arenā€™t available anymore, plus i had a few issues with them failing (they looked like this Lighting Illusions Online ), can anyone advise if they can be added into home assistant (perhaps Tuya Local)? Brilliant Smart Ceiling Fan Wall Controller | JD Lighting
@oscill8ory @kanga_who
Just adding both my Brilliant plugs have now died. I thought they were going strong and then one day dead. They lasted just over two years though
Mine were about the same I think for the ones under constant use. Still got a few going.
I really liked the form of them. Oh well.
Yeah Iā€™m sick of wasting money on wifi smart plugs that only last a year or two. These are not consumable items!
You could resurrect the plugs by installing something like a Shelly or similar, if the case is large enough. I had three 433MHz plugs, two of which failed within weeks after about six years, I gutted and installed a 240V to 5V DC convertor and an ESP01S with Tasmota. That was about 12 months ago and all work and are in HA.
I find the TP-Link Kasa series are pretty reliable, Iā€™ve had a few for a few years with no failures (touch wood). I have some of the older style (HS100), and the new (KP115) Smart Power | TP-Link Australia. Local control too, just need to use the Kasa app to input your WiFi credentials, then HA picks them up.
I was contemplating the idea of doing something Sonoff basic-esk with a Shelly.
Looks like others have. Even with a dumb powerboard.
But Iā€™m keen on a compact solution. And would prefer something off the shelf + certified for smart plugs.
I have a few hs110 that I bought a few yrs ago but havenā€™t set them up yet.
I read that tp link (like tuya) stopped allowing the integration with new fw. Afraid to connect them to the app in case they get updated automatically.
Have you tried to set one up recently?
Hereā€™s what Iā€™ve come across README.md Ā· master Ā· madmachinations / HA TP-Link manual connection Ā· GitLab
yes, I bought a new WiFi router about 3 months ago, and had to re pair all of them to the new SSID. I noticed some had firmware updates which I perfomred. They still connected locally just fine.
If youā€™re not using them for fear of a firmware update, then you have nothing to lose by trying them! Re your link, that was written 2 years ago.
Great, thanks for the info mate.
Could you check one of your switches in the app to see if itā€™s on the latest firmware?
Just wanted to confirm that even the latest doesnā€™t break things
yep I just opened the Kasa app. I only have two of my 4 powered up at the moment. The firmware wonā€™t update unless you tell it to via the app. You have to go to the ā€œme / firmware updateā€ menu on the bottom of the screen. Mine is saying ā€œThe firmware of all connected devices is up to dateā€.
FYI if I go into each devices settings / Device info I see: HS100 firmware version 1.5.7 and KP115 firmware version 1.0.17.
Looks like youā€™ll be fine!
Good man, I went ahead and updated all mine. Theyā€™re still working fine
Thanks mate!
Has anyone flashed esphome on to an Arlec TW-092CHA downlight (warm and cool white)?
I managed to do a usb to serial flash using the configuration at Arlec Grid Connect Smart 9W CCT LED Downlight (ALD092CHA) | ESPHome-Devices which is for an earlier model - though the TYWE5P module seems to be the same in both models.
It works well in most respects but had a bad flicker at lower brightness settings (despite trying various power points). The flicker is much improved by setting a frequency of 200 Hz, which seems very low cf the suggestions at ESP32 LEDC Output ā€” ESPHome. But itā€™s still there right at the low end of the brightness setting. Lower frequencies make no difference or the bad flicker reappears (at 50 Hz). Perhaps relevant to note that there is no reference to frequency in the code linked above on the esphome site.
More problematically though, the lowest brightness setting is at 15%ā€¦ below that it cuts off warm and cool output. Not sure how I can use it with my adapative lighting integration unless I can modify that somehow - aside from creating an Adaptive Lighting integration just for that light (and any future similar lights I might flash).
Would be grateful for tips from someone who knows about these things.
here is my configuration
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "########"
    password: "########"
captive_portal:
logger:
api:
ota:
  - platform: uptime
    name: Bathroom Light Uptime
  - platform: wifi_signal
    name: Bathroom Light Signal Strength
output:
  - platform: esp8266_pwm
    pin: GPIO4
    frequency: 200Hz
    pin: GPIO5
    frequency: 200Hz
light:
  - platform: cwww
    cold_white: output_cw
    warm_white: output_ww
    cold_white_color_temperature: 5700 K
    warm_white_color_temperature: 3000 K
    constant_brightness: true
    restore_mode: RESTORE_DEFAULT_ON
Recently the skip login option vanished from my kasa app so I no longer had guest access to add new devices. Is yours working?
I donā€™t have a skip login or guest, Iā€™m continuously logged in with my email address.
Initial impressions of Athom plugs (havenā€™t actually used them yet). Feel free to silence me people given they are not certified and so outside scope of this thread:) Am considering a dedicated thread anyway;) ?
Like others have said, main shortfall in form is the button would be easier to access if it was on top or the front. Potentially constrained access if it is in the right dual plug slot.
You can just squeeze in two side by side.
The real test with AU smart plugs is whether they make it past the 1-2 year mark after the failures of Kogan and Brilliant to achieve this.
Athom is the square plug(s). A Brilliant also shown for comparison.
