If you size the water heater such that once a day heating cycle is ample to carry the hot water demand as well as cope with the occasional higher demand day, then a twin element is unnecessary. Water stratifies in a tank with hot sitting on top of cold and there is very little mixing.
If you really think you need a top element due to running out of hot water regularly, better to get a bigger tank than one with more complexity (and work on the demand side too by reducing hot water demand, e.g. use low flow shower heads).
If the largest tank that will fit is inadequate then sure, a second element can help extend its capacity a bit but it may turn out to be pretty expensive to operate given the heating may occur during times of peak electricity rates. In that case an alternative solution would be better, such as a heat pump water heater.
Choice on heating element power rating will depend on what is powering the water heater. If you are timing it to use cheapest grid electricity, then yes, provided the home wiring and supply/circuit board capacity is suitable.
But if you plan to use your own solar PV to heat water during the day then choice of heating element matters more and lower power elements may be a better choice.
Iâm not sure what the OP is thinking as they did not mention why they want to have smart control of the water heater.
If using solar PV is desired and you are planning on using smart switching to turn on/off power to a water heating element, then you will want to size the heating element to suit two things:
- the likely available solar PV capacity
- the hot water demand and how long it takes to heat water.
The problem can be explained by this image:
The yellow represents solar PV output (which will obviously vary depending on a whole host of factors) while the red blocks represent the same amount of energy (7.2 kWh as a token example), just consumed at different power levels. In this case 1.8 kW, 2.4 kW and 3.6 kW. The lower power element is the shorter, wider block. In this case the solar PV system is modestly sized.
We can see in this instance that the higher power heating element would require a portion of energy to be imported from the grid. A 4.8 kW heating element would be even worse for this use case. This is where choosing a lower power heating element is often a better choice. but not too low as the time required to reheat is extended, so if HW consumption is high then some compromise is required.
However you may have a larger PV system, in which case you will have this scenario:
And here it doesnât really matter as the water heating power demand will be covered. But then one needs to consider what happens on poor / variable solar PV days, like this:
You can time when a heating blocks starts/stops but fitting a high power heating element demand under the available solar PV output is much more difficult than with a lower power heating element. Inevitably more supplemental grid energy will be required with a higher power heating element.
This of course is only showing the water heater demand relative to PV output examples and not available excess PV. That is of course dependent on other household loads and there may be competing demands.
A relay can be programmed to track the available excess PV and switch relays on/off to match but too frequent switching under load is not a good idea.
So I think it will help to understand why the OP want smart control? Saving money is usually the answer but the methodology will vary depending on various factors. A standard resistive element water heater may not be the optimal choice.
We use a 315 litre resistive element tank but I have a variable power PV diverter which follows available excess PV. Over several days it looks like this:
The tank has ample capacity to ride through a few poor solar PV days.
