I went for the individual plugs for this reason.
Otherwise the strip would have been perfect for me.
yeah i agreeā¦ tho for $39 delivered - its not too bad as a smart power strip ! and gives at least a little info about how much power the āgroupā is consuming rather than nothing at all
Off topic but kind of still on topic:
Anyone in Melbourne (or east coast) willing to 3D print a CC2531 case for me, like this one? Happy to pay for time, material and postage.
Iād be happy to give you mine ā¦ i moved to a Conbee ā¦ but Iām in Adelaide. If you donāt get any takers, let me know ā¦
Do you think the controller / blinds can be made to work with Home Assistant?
Anyone flashed the DETA Smart downlights from bunnings using Tuya convert?
There is a template on blackadder, but flashing says serial?
Out of curiosity why did you move to Conbee? Iāve been Zigbee2mqtt for a while and every once in a while something bugs out and i have to set the whole thing up again. Starting to think about different options
I can certainly print one for you no charge, might be a couple of days as currently updating the printer, in Carrum/Bonbeach
Howdy - just āgeneralā performance and stability I think. Not that I truley gave it a chance as Iāve still got some senspors connected to Xiaomi gateways, but I did find it dropped connection to Xioami Temp sensors a bit too often. It could just have been a distance problem, so I bought the CC2530 to make a router, but then in the meantime the ConBee became available at a reasonable price on AmazonAU.
So in short - not a lot of science behind it
I just flashed the 7w one using Tuya-Convert. No problem flashing OTA at all. Used the same GPIO from blackadder to for ESPHome. Exactly the same as the Mirabella downlight.
Cheers mate.
On another note, im selling a heap of automation stuffs, inbox me if interested as not sure you can list on here
Not yet. Havenāt pick any up.
Thanks David! I will PM you.
Hi everyone,
I have been looking for smart blinds for a while now and I just noticed the Smart Home Products motorised roller blinds at Bunnings.
There is also a controller that allows them to be interfaced with the Grid Connect system.
These look great and the pricing appears very good as well. The respective products are:
Does anyone know if they (and in particular the controller) would be compatible with HA?
Thanks.
So I went and got one and it works with Tuya Convert!
Same template as the Zemismart too. Iāll submit template and info later
Awesome! Good to know!
What did you get?
Happy to do it for you.
PM me if you still need this
Sorry having a conversation within a thread is a bit wrong I suppose.
I purchased a Connect Smart 2 Gang Wall Switch from Harvey Norman and was able to flash it with Tuya Covert OTA. It is a rebadged Zemismart KS-811 2 Gang Switch and those are supposed to have been updated to block OTA flashing.
I have uploaded the template: https://templates.blakadder.com/connect_smarthome_CSH-SWTCH2.html
I wonder if they will be cheaper when Big-W get them in, since they are made by laser co.
