Australia - Electrically Certified Hardware
Definitely go with a Fronius.
Before you commit to a solar company make sure that the inverter they sell you can provide its data without needing any cloud service. I have a Fronius (Austrian) and it is brilliant in that I can grab the data locally, directly into HA using this custom component (there is an official component but it isn’t as good as the custom one). There are other brands out which require your inverter to upload data to a Chinese server from which you then try to grab it back… stay away from these at all costs
I don’t think is already listed in here, so I’m adding. Have recently bought and put tasmota on Arlec 10m extension cord. (https://www.bunnings.com.au/arlec-10m-smart-extension-lead-with-grid-connect_p0098824)
The OTA method worked with no glitches, and the template I ended up with after going through the steps as at https://tasmota.github.io/docs/Configuration-Procedure-for-New-Devices/ is below
is: {“NAME”:“Arlec Ext Cord”,“GPIO”:[255,17,255,255,255,255,255,255,255,56,21,255,255],“FLAG”:15,“BASE”:18}
I hope this is usable for others, best wishes…
I bought 2 of these today May 2020 model MD93225 / 63645 built 07/2019 and flashed them with tasmota via tuya convert today successfully using this video https://youtu.be/dt5-iZc4_qU
https://cdn.productreview.com.au/resize/listing-picture/1b73d80f-793a-404b-9dad-ed8d3896aba9?width=1200&height=630
I have hooked the switches into home assistant and also accessing the power monitoring.
I finally have my special ordered 4 gang deta switch, (at the same time there are about 3 on the shelves at Alexandria NSW.
Bad news, it does not tuya-convert.
Good news, it should be simple enough to manually flash it;
This the underside of the low voltage board with the touch switches.
The mains voltage board is the exactly the same a the non-smart version of this device.
Has anyone got any insight into the Brilliant smart escort light https://www.brilliantsmart.com.au/smart-products/security/smart-escort/ ?
Was thinking it would be great to have PIR info coming into HA and light control. Could use it to trigger camera recording and turn other lights on ect. But I have no idea if it runs on an ESP or if it would even be easy to build a template for.
EDIT- I have heard from Brilliant smart that it does run on an ESP8266
I couldn’t get it to flash using this USB to serial. I constantly got stuck on
Connecting…
A fatal error occurred: Failed to connect to Espressif device: Timed out waiting for packet header
I wired it like this:
3.3v to VCC (top left in the picture)
Ground to GND (bottom left)
TXD to TXD (bottom right)
RXD to RXD (2nd from bottom right)
CTS to GPIO0 (3rd from bottom left).
I think I stuffed that last one up… my switch still works though. Actually, the LED on the board didn’t even come on while I plugged it into the serial adapter.
I’ll have a crack again on the weekend if someone has any ideas?
Note: My board looks more like this and this one, without the holes on the right hand side where the VCC/GND/TX/RX stuff is.
boc,
I can also recommend the Fronius system for integration into HA. But I think it also needs to have the Smart Meter. It looks like an entire meter, but is only the size of a breaker switch, so like the size of a matchbox really. I am using the integration to trigger my AC to turn on and heat/cool if there is enough sustained export - leveraging the system.
https://www.fronius.com/en/photovoltaics/products/all-products/system-monitoring/hardware/fronius-smart-meter/fronius-smart-meter-50ka-3
Thanks mate, will keep an eye out for it.
Struggling to find installers at the minute, so it’s possible this won’t be as short term as I’d hoped for!
Normally you would need to connect RX to TX and TX to RX between the FTDI adapter and the ESP.
You dont need the Fronius smart meter. The inverter will provide generation figures and you can use any of many methods to determine grid import / export. eg: I use IotaWatt
I have the iSwitchOz dimmer working.
It can be flashed successfully using tuya-convert.
The one I have definitely does power monitoring.
It works in both Tasmota and esphome (although I haven’t looked at getting the power monitoring working in esphome yet).
tasmota template:
{"NAME":"iSwitchOZ Dimmer","GPIO":[255,255,255,255,255,255,0,0,255,255,54,255,255],"FLAG":0,"BASE":54}
Tasmota additional console commands :
TuyaMCU 21,2 ; TuyaMCU 33,6 ; TuyaMCU 31,5 ; TuyaMCU 32,4 ; DimmerRange 1,24
esphome yaml:
substitutions:
  plug_id: eh_iswitch_dimmer_101
  plug_name: rumpus
esphome:
  platform: ESP8266
  board: esp8285
  #board: esp01_1m
# Make sure logging is not using the serial port
logger:
  baud_rate: 0
wifi:
  blah blah blah
ota:
api:
uart:
  baud_rate: 9600
  tx_pin: GPIO1
  rx_pin: GPIO3
# Register the Tuya MCU connection
tuya:
# Create a light using the dimmer
light:
  - platform: "tuya"
    dimmer_datapoint: 2
    switch_datapoint: 1
    min_value: 1
    max_value: 24
Thanks BradAU,
I have completed my first tuya-convert. The Gen 2 Kogan Smart Plugs with USB are up and running in ESPhome now with power monitoring. Great plug for the price.
I had some difficulty with errors while compiling in ESPhome I had to remove web_server and captive_portal, as these threw errors that I could not resolve.
Thanks Again
You’ve completely thrown me off now. (Too many acronyms)
So all I did wrong (apart from the GPIO0 wire, doh!) was not hook the RX to the TX and the TX to the RX?
What is FTDI?
That’s really odd, I use the same base config for all my ESPHome units.
Just to confirm, are you using the ESPHome add-on in Hassio?
Well, that’s just one bit that I noticed.
One more thing to double-check is that the voltage of your USB to serial adapter is indeed set to 3.3V.
Sorry, didn’t want to confuse you. FTDI adapter is just a usual synonym for the USB to serial adapter that you have.
You are a gem and a half! Thanks, I managed to get it to work first time with your guidance.
Here are a few photos:
This is the serial setup. https://newadventuresinwi-fi.blogspot.com/2019/10/brilliant-smart-elite-glass-wall.html has really good information on it. I found using the ground from the headers which connect to the 240v board worked great. The loosey goosey purple one was connected to the RST for 3 seconds while I plugged the usb cable in and then removed it let it float about.
And this is what my 3 gang board looks like.
I used Tasmotizer to flash it. Backed up the flash using esptool.py (sudo esptool.py read_flash 0 0x100000 firmware.bin) before I attempted it.
And here is a (mostly) working Tasmota template. I couldn’t find the ledlink but that doesn’t bother me.
 {"NAME":"DETA 3G Switch","GPIO":[0,0,0,92,91,21,0,0,23,157,22,0,90],"FLAG":0,"BASE":18}
Just did one this evening. I wish the relays were a little quieter and that it had tactile buttons. I guess I can pretend that the relay click is audio feedback :stuck_out_tongue:
I think you mean GPIO0 rather than RST?
You got ahead of me, I didn’t find time this weekend to flash my 4-gang.
But I rung out the pins, my best guess for the control
relay1 : gpio16
relay2: gpoi4
relay3: gpio2
relay4: gpoi13
led: !gpio15
Completely untested. Does that match your 3-gang?
But I’m a bit concerned, that the 1 & 2 Gangs may no longer tuya-convert.
I just realised, I forgot about the buttons. So all my relays above could be buttons.
Chcking…, Someone has already added this device https://templates.blakadder.com/deta_6904HA.html
I’ve got it completely wrong.
The purple wire which is floating around in my picture was touching the top right hand leg of the TYWE3S chip when I powered it on. If I removed the GPIO0 wire then it would stop reading/flashing the device.
@diramu - thanks for that link. GPIO0 works for my LEDLink too. I’ve submitted it to the repo, lets see if it gets approved.
The only way I could get it to work was to short GPIO0 to GND and then connect my FTDI to USB.
