Yep that is pretty much the standard way to flash an esp chip.
Jaycar have smart plugs that look like the Kogan ones
Just wanted to check in with the folks who have the Grid Connect ceiling fans. Have there been any updates to the Tuya component that makes them visible in HA yet?
Cheers,
Linton
Decent markup on the Kogan prices tho!
Thatâs what I thought when I saw them a while back. But if you need in a hurry you can the. from a bricks and mortar store
This looks interesting too if youâre into Zigbee:
https://www.jaycar.com.au/240v-wireless-controller-switch-to-suit-home-automotion/p/LA5575
First time post⌠Iâve been ramping up my Tasmota journey over the past 2 weeks. One of the devices Iâm trying to get working is the Brilliant Smart Fan device from Bunnings. Iâve followed the 2 tutorials and conversations from a few months ago in this forum. I can get the device to appear in HA, and can configure it so I see the toggle buttons in the WebUI - but have had no luck actually controlling the light/fan (even though the remote still works).
Looking in my console on the device - I donât seem to be getting any response from the MCU:
12:58:06 TYA: Send â55aa00000000ffâ
12:58:08 WIF: Checking connectionâŚ
12:58:17 TYA: Send â55aa00000000ffâ
12:58:28 WIF: Checking connectionâŚ
12:58:28 TYA: Send â55aa00000000ffâ
Has anyone had any success with this device recently? I also noticed that the template has dropped off the Tasmota devices library too - so should I assume it means it no longer works?
Appreciate your thoughtsâŚ
Great (long) thread! And great to finally see some more choices available - even if still a premium.
Does anyone know a AS/NZ certified version of these? (WiFi or Zigbee)
I have one setup so that unit would be in wall and controlled by glass touch switches reprogrammed in ESPhome to be momentary so also working as 2-way with dimming control. All working great and meets my âmust work with the wifi offâ rule, but would be more comfortable with a certified device in the wall.
I have many of these (1,2,3 gang) https://www.aliexpress.com/item/32911085563.html?spm=a2g0s.9042311.0.0.27424c4d7bQGzf which I got made with all white plastic which looks way better on the wall than the black ones around, so will look to replace them with local certified devices once I find the same. Not too keen on the Deta ones.
Wow, that thing is giant if these specs are correct
Width | 132mm |
Height | 27mm |
Depth | 67mm |
I purchased a 1 and 3 gang switch today. I have been unable to tuya-convert either of them. I was successful with the downlights last week, but Tuya-Convert just throws up the âDevice did not appear with the intermediate firmwareâ when trying to find either of these. What is the likelihood of them figuring out this new Tuya protocol and getting Tuya-convert working again? Should i just bite the bullet and get the USB and go the serial method?
I donât have a 1-gang to compare to, but publish the version number on the circuit board, and we can see if it has changed with others out there who have tuya-converted the 1-gang.
Iâm trying to 3D print a clamp to go over the tyua module to probe the pins to do the flash.
https://photos.google.com/photo/AF1QipPh_CP9XjDed0IdLZABbnzChhkIIf0jx-0Tg9U2
My first attempt failed, so Iâve ordered some pogo pins for my next try. https://www.aliexpress.com/item/1047974798.html?spm=a2g0s.9042311.0.0.65bb4c4dAaLyVY
No worries - iâve got it installed now and with it being night now, donât want to turn the lights off. Iâll take it off tomorrow and grab a photo. For now, iâll revert to the tuya integration i guess.
certifed but a million dollary doos.
the brilliant range ones are look nice
https://www.brilliantsmart.com.au/smart-products/electrical/smart-elite/
how do the brilliant ones denote power? red/green bulb symbol? red/blue? other? not a bulb symble?
Thanks. They look good. How much are the Stitchy units? I couldnât find anyone selling online.
I saw the Brilliant switches but have black plastic backing. I have asked them if available in white.
Now if only those switches has an input we could program for 2-way operation. And you could disable the led on the touch circles for bedroom use.
Blue led ring when on. No bulb symbol
I have heard the stitchy is $200 plus a unit. But yes they seem to only sell to trade so no pricing online. I think it was mentioned over in whirlpool
Trade price was around $100 when I got minemid last year
Iâm brand new to flashing and iâm having a lot of trouble getting this to work. I think I understand the process but I canât quite get my head around the configuration. Could someone please explain which areas of this I need to edit?
