For those of you who are interested in Australian Certified Hardware where there is no changing to custom firmware, ie. really maintaining the rtm tick as well as the electrical certification.
The Power Plugs and Door/Window Sensors from Telstra Smart Home equipment is now supported by Conbee/Deconz for HA. Yes that’s right Zigbee
I have left all my switches stock standard and changed out all my lights to zigbee lights. Much happier, no custom firmware. No problems with no Neutral wire.
The only parts you should need to edit for your own setup are the substitutions and WiFi details, you will also need to calibrate each plug for accurate readings which involves changing the current_res and voltage_div numbers.
Thanks for the quick response and clarification. I’m sure that one of my attempts yesterday was just that, it’s what I assumed going in but the problems I faced had me second guessing everything. It’s frustrating but I gotta make it happen. Thanks again.
Unfortunately not. The unit worked fine when installed, then I flashed using TuyaConvert and so far I’ve not been able to get it working beyond just the remote. As I mentioned in the console it looks like it’s trying to send the heartbeat but not receiving anything back.
Not really sure where I would have gone wrong as I followed both tutorials online.
just thought id say that i picked these up yesterday to replace some old Venetian blinds in my office. really impressed so far for the price. easy to install and set up and the motor is surprisingly fast and quiet.
integrated into HA by learning the RF codes and broadlink pro. didn’t buy the additional arlec controller.
I’m really new to this, I don’t know anything for sure, it’s just my latest theory.
The router log is giving me this error repeatedly: A device failed to connect to SSID (D8:F1:5B:91:CA:F3) because it provided incorrect login information.
Even after connecting to the fallback ap and setting the log in details again it still won’t connect. Yesterday I believed it to be code related. After clarification from Brad and further attempts I don’t think that is the case anymore.
For some reason it’s refusing the log in. No idea why, never had any issues connecting to it before now.
Is it something silly like you’ve got the 5GHz credentials saved in the config, but the ESPHome devices are connecting to 2.4GHz?
Those Telstra modems also have band steering, where they combine the 2.4 and 5Gz networks into 1 SSID. making it look like only one network to you and your devices. Try and go into the router setup and disable band steering, such that you have a definitive 2.4 and 5GHz networks. Then make sure you’ve got the right credentials for the 2.4GHz netwrok in the ESPHome devices (They dont work with 5GHz)
I’ve got 5GHz disabled. So can’t be mix up on credentials. Hadn’t heard of band steering before, is it safe to assume with just 2.4GHz active this wouldn’t apply?
