🔹 Auto-entities - Automatically fill cards with entities
You may calculate count of filtered entities inside a “template” option.
nice answer but it does not help me much - for normal entities I put name:… but here I am not sure how to
thx anway
@homonto
Consider this:
type: vertical-stack
cards:
  - type: entities
    entities:
      - type: section
        label: w/o secondary_info
      - entity: sun.sun
      - entity: sun.sun
      - entity: sun.sun
      - type: section
        label: with secondary_info
      - entity: sun.sun
        secondary_info: last-changed
      - entity: sun.sun
      - entity: sun.sun
  - type: custom:auto-entities
    card:
      type: entities
    filter:
      include:
        - entity_id: sun.sun
          options:
    card:
      type: entities
    filter:
      include:
          options:
As I said - same way as for a conventional Entities card.
that is what template-entity-row was made for :wink:
Oh yes.
Same output, different efforts:
Surely in some cases template-entity-row is the simplest solution, it depends.
Not to mention a fact that “last-changed” label is NOT periodically updated for template-entity-row (only when a state changes or a page refreshed) as it is for a conventional entity row (periodically).
tbh I always use the last-changed on states in the config.entity, so they are always correctly updated. you might be right for other situations, I confess I bever watched that. Should be an important aspect in choosing the right card.
See this rather complex composite of card_mod_theme, card_mod and template-entity-row. whish I could be simpler…
luckily, we can just completely throw it inside an anchor and repeat for the another entity::
type: entities
title: Luchtreinigers
card_mod:
 class: class-header-margin
entities:
  - type: custom:template-entity-row
# https://community.home-assistant.io/t/card-mod-add-css-styles-to-any-lovelace-card/120744/2182
    entity: fan.luchtreiniger_hall
    <<: &fan
#       color: >
#         {{iif(states[config.entity].state == 'on','red','black')}}
        {% if states[config.entity] is not none %}
          {{state_attr(config.entity,'friendly_name').split(' ')[1]}}:
          {% set id = states[config.entity].object_id %}
          Air quality:
          {% if states('sensor.' ~ id ~ '_air_quality') in ['unknown','unavailable'] %}
            {% if states[config.entity].state == 'on' %} Initializing
            {% else %} Off {# Device not ready #}
            {% endif %}
          {% else %} {{states('sensor.' ~ id ~ '_air_quality')}} µg/m³
          {% endif %}
        {% else %} Not yet set
        {% endif %}
      secondary: >
            On: {{states[config.entity].attributes.percentage}} -
          {% else %} Off since {{relative_time(states[config.entity].last_changed)}} -
          {% endif %}
        {% else %} Not yet set -
        {% endif %}
        Power: {{states('sensor.' + id + '_device_power')}} W
      card_mod:
        style:
          div#wrapper: |
            state-badge {
              {% if is_state(config.entity,'on') %}
                animation: rotation 2s linear infinite, colorize 5s linear forwards 1;
              {% endif %}
            @keyframes rotation {
              0% {
                transform: rotate(0deg);
              100% {
                transform: rotate(360deg);
            @keyframes colorize {
              0% {
                background: steelblue;
              100% {
                background: aquamarine;
#      state: >
#        {{iif(is_state(config.entity,'on'),'Aan','Uit')}}
      icon: >
        {{is_state(config.entity,'on')|iif('mdi:fan','mdi:fan-off')}}
#      icon: >
#        {{'mdi:record-circle-outline' if is_state(config.entity,'on') else 'mdi:fan-off'}}
      toggle: true
    entity: fan.luchtreiniger_woonkamer
    <<: *fan
btw, that animated fan is still off-center…
This template only updates when the state is changed, or when the page is refreshed.
Sorry for an off-topic.
yes, I understood that, np.
btw, not so off topic, as its a very easy mod to use in the options for an auto-entities card. using that myself
Thanks, I thought it was possible with som sort of template. I just didn’t know i could use the filter when i created the template. I will have to look into that since i’m quite new to the coding part of HA (where you can do all the cool stuff)
Kind of:
    card:
      type: entities
    filter:
      template: |-
        {% set DEVICES = states.device_tracker |
                          selectattr("attributes.ip","defined") | list -%}
        {%- set COUNT = DEVICES | count -%}
              'type': 'section',
              'label': 'Count: ' + COUNT|string
        {%- for DEVICE in DEVICES  -%}
                'entity': DEVICE.entity_id,
                'secondary_info': 'last-changed'
        {%- endfor %}
Should show_empty work when using a filter template?
It’s working fine with include filters. But when using a template filte it’s not. Here is some example that doesn’t seem to work:
- type: custom:auto-entities # Offene Fenster und Türen
  show_empty: false
  card:
    type: entities
    title: Offene Fenster/Türen
  filter:
    template: |-
      {% set DEVICES = states.binary_sensor
        |rejectattr('attributes.device_class', 'undefined')
        |selectattr('attributes.device_class', 'eq', 'door')
        |selectattr('state', 'eq', 'on')
        |list
        {% if DEVICES|length > 0 %}
          {% for DEVICE in DEVICES  -%}
                'name': area_name(DEVICE.entity_id),
                'secondary_info': 'last-updated'
          {% endfor %}
        {% endif %}
Seems to work:
seems to have been some caching issue or so. Didn’t change anything. Works now. Sorry for the confusion. Thanks for investigating.
thank you @Ildar_Gabdullin
Anyone know how to filter out entities/devices not assigned to an area? I know how to filter by devices assigned to an area but am looking for the opposite. Overall, I am trying to only show a list of switches assigned to an area ie if a switch has not been assigned an area it won’t show in the auto entities list.
I know a work around could be to include switch domain and include every area but this just feels like a lot of work when there should be exclude: null
Have two lists? One with all entities and one with those in areas … and remove the items from the later list from the former list.
show_empty: false
card:
  type: entities
filter:
  template: >-
    {% set ns = namespace(entity_and_area=[]) -%}
    {%- for entity in states.device_tracker -%}
      {%- set entity_id = entity.entity_id -%}
      {%- set area = area_name(entity.entity_id) -%}
      {%- set entity_and_area = ({'entity_id':entity_id,'area':area}) -%}
      {%- set ns.entity_and_area = ns.entity_and_area + [entity_and_area] -%}
    {%- endfor -%}
    {%- set sorted_list = (ns.entity_and_area) | rejectattr('area','eq',none) | sort(attribute='area') -%}
    {{ sorted_list | map(attribute='entity_id') | list }}
Here we have a list of “device_tracker” entities (except not assigned to any area) sorted by area.
Will post a list of useful posts (just in case):
list an entity’s attributes
passing options into a conventional entity row:
hide a name
show an attribute
how to manage a sorting
mass-rename entities
list of batteries
select entities dependently on their attributes
using AND, OR, NOT
card-mod:
general schema
conditional card_mod
glance + card_mod
– card-mod in a template: one, two, three
button-card in a grid
graphs in a stack:
history-graph
mini-graph-card
mini-graph-card + template
many graphs in one card
multiple-entity-row
dividers between lists
rows separated by dividers
defining a number of found elements
how to list entities in 2 columns
how to define Markdown cards in auto-entities
areas:
sort entities by area
a card with entities filtered by some area
list of “area” cards
show an Area card for one area_name
list of entities except ones not assigned to any area
templated Gauge card
a possible way to easily define templates for cards
how auto-entities work
how to show an alternative card if a filter gives an empty list
@Ildar_Gabdullin thank you, I will give that a go, and thank you for the other links. Interesting reading :grinning:
is it somehow possible to output an attribute as the value instead of the state?
show_empty: false
card:
  type: entities
  state_color: true
  show_header_toggle: false
Read 2 posts above.
