I have hydroponics system that where I am growing some herbs. Systems has pump that pump that circulates water in system Pump is plugged in normal Hue smart plug. I have tried to make automation that runs pump between 8 am to 10 pm and pump runs for example 15 min on and 45 min off or 30 min on 45 min off. How do I do that with Automations. I have only figured out how to run pumpu 30 min on and 30 off but that way herbs get too much water.
Also is there way to make card on dashboard to easy way to change times when pump is running and not running?
Here’s a skeleton for a timer-based asymmetric cycle… you’ll need to decide if you want additional ways to manually initiate and terminate the cycle as well as any fail-safe control mechanisms.
