This guide has been migrated from our website and might be outdated. Feel free to edit this guide to update it, and to remove this message after that.
Home Assistant Python can run as a daemon within init.d with the script below.
1. Copy script
Copy either the daemon script or the Python environment script at the end of this page to /etc/init.d/hass-daemon depending on your installation.
After that, set the script to be executable:
sudo chmod +x /etc/init.d/hass-daemon
2. Select a user
Create or pick a user that the Home Assistant daemon will run under. Update script to set RUN_AS to the username that should be used to execute Home Assistant.
3. Change hass executable and other variables if required
Some installation environments may require a change in the Home Assistant executable hass. Update script to set HASS_BIN to the appropriate hass executable path. Please also check the other variables for the appropriate value. In general the defaults should work
4. Install this service
sudo service hass-daemon install
5. Create logrotate rule
This logrotate script at /etc/logrotate.d/homeassistant will create an outage of a few seconds every week at night. If you do not want this add --log-rotate-days 7 to the FLAGS variable in the init script.
File /var/log/homeassistant/home-assistant.log:
rotate 7
daily
missingok
notifempty
delaycompress
compress
postrotate
invoke-rc.d hass-daemon restart > /dev/null
endscript
6. Restart Machine
That’s it. Restart your machine and Home Assistant should start automatically.
If Home Assistant does not start, check the log file output for errors at /var/log/homeassistant/home-assistant.log
Extra: Running commands before Home Assistant executes
If any commands need to run before executing Home Assistant (like loading a virtual environment), put them in PRE_EXEC. This command must end with a semicolon.
Daemon script
#!/bin/sh
### BEGIN INIT INFO
# Provides: hass
# Required-Start: $local_fs $network $named $time $syslog
# Required-Stop: $local_fs $network $named $time $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Description: Home\ Assistant
### END INIT INFO
# /etc/init.d Service Script for Home Assistant
# Created with: https://gist.github.com/naholyr/4275302#file-new-service-sh
PRE_EXEC=""
# Typically /usr/bin/hass
HASS_BIN="hass"
RUN_AS="homeassistant"
PID_DIR="/var/run/hass"
PID_FILE="$PID_DIR/hass.pid"
CONFIG_DIR="/var/opt/homeassistant"
LOG_DIR="/var/log/homeassistant"
LOG_FILE="$LOG_DIR/home-assistant.log"
FLAGS="-v --config $CONFIG_DIR --pid-file $PID_FILE --log-file $LOG_FILE --daemon"
start() {
create_piddir
if [ -f $PID_FILE ] && kill -0 $(cat $PID_FILE) 2> /dev/null; then
echo 'Service already running' >&2
return 1
fi
echo -n 'Starting service… ' >&2
local CMD="$PRE_EXEC $HASS_BIN $FLAGS"
su -s /bin/bash -c "$CMD" $RUN_AS
if [ $? -ne 0 ]; then
echo "Failed" >&2
else
echo 'Done' >&2
fi
stop() {
if [ ! -f "$PID_FILE" ] || ! kill -0 $(cat "$PID_FILE") 2> /dev/null; then
echo 'Service not running' >&2
return 1
fi
echo -n 'Stopping service… ' >&2
kill $(cat "$PID_FILE")
while ps -p $(cat "$PID_FILE") > /dev/null 2>&1; do sleep 1;done;
rm -f $PID_FILE
echo 'Done' >&2
install() {
echo "Installing Home Assistant Daemon (hass-daemon)"
update-rc.d hass-daemon defaults
create_piddir
mkdir -p $CONFIG_DIR
chown $RUN_AS $CONFIG_DIR
mkdir -p $LOG_DIR
chown $RUN_AS $LOG_DIR
uninstall() {
echo "Are you really sure you want to uninstall this service? The INIT script will"
echo -n "also be deleted! That cannot be undone. [yes|No] "
local SURE
read SURE
if [ "$SURE" = "yes" ]; then
stop
remove_piddir
echo "Notice: The config directory has not been removed"
echo $CONFIG_DIR
echo "Notice: The log directory has not been removed"
echo $LOG_DIR
update-rc.d -f hass-daemon remove
rm -fv "$0"
echo "Home Assistant Daemon has been removed. Home Assistant is still installed."
fi
create_piddir() {
if [ ! -d "$PID_DIR" ]; then
mkdir -p $PID_DIR
chown $RUN_AS "$PID_DIR"
fi
remove_piddir() {
if [ -d "$PID_DIR" ]; then
if [ -e "$PID_FILE" ]; then
rm -fv "$PID_FILE"
fi
rmdir -v "$PID_DIR"
fi
case "$1" in
start)
start
stop)
stop
install)
install
uninstall)
uninstall
restart)
stop
start
echo "Usage: $0 {start|stop|restart|install|uninstall}"
esac
Python virtual environment
#!/bin/sh
### BEGIN INIT INFO
# Provides: hass
### END INIT INFO
PRE_EXEC="cd /srv/homeassistant; python3 -m venv .; source bin/activate;"
HASS_BIN="hass"
CONFIG_DIR="/home/$RUN_AS/.homeassistant"
start() {
create_piddir
return 1
fi
echo "Failed" >&2
else
echo 'Done' >&2
fi
stop() {
return 1
fi
rm -f $PID_FILE
echo 'Done' >&2
install() {
create_piddir
mkdir -p $LOG_DIR
uninstall() {
local SURE
read SURE
stop
remove_piddir
echo $CONFIG_DIR
echo $LOG_DIR
rm -fv "$0"
fi
create_piddir() {
mkdir -p $PID_DIR
fi
remove_piddir() {
rm -fv "$PID_FILE"
fi
rmdir -v "$PID_DIR"
fi
case "$1" in
start)
start
stop)
stop
install)
install
uninstall)
uninstall
restart)
stop
start
esac
