ahhh, no you can’t.
sound and rtttl not supported in app by AWTRIX firmware!
use notification instead on application!
I came up with this:
alias: Awtrix - garage - audible notification
description: ""
triggers:
- trigger: state
entity_id:
- cover.garage_door
to: open
conditions: []
actions:
- action: awtrix.awtrix_rtttl
rtttl: two_short:d=4,o=5,b=100:16e6,16e6
- repeat:
sequence:
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
metadata: {}
while:
- condition: state
entity_id: cover.garage_door
state: open
mode: single
It seems to be ok(?). What’s a difference between
awtrix.awtrix_sound
and
awtrix.awtrix_rtttl
“Sound” requires mp3 file?
can you read RTFM instead of asking me.
thank you!
Hi Oleg, awesome work! Is there by any chance an option to use toggle helpers to enable / disable the apps?
HI,
I started playing but I see an error that I cannot identify.
Below my automation config:
alias: Awtrix Previsioni
description: ''
use_blueprint:
path: 10der/awtrix-simple.yaml
input:
awtrix_device:
- 3b368916b6bc5254d0cc97e577806f44
app_name: awtrix_app_forecast
app_icon: a2282
entity: weather.pirateweather
pre_actions:
- target:
entity_id:
- weather.pirateweather
type: hourly
response_variable: forecast
action: weather.get_forecasts
value_template:
text: >-
{{forecast['weather.pirateweather'].forecast | selectattr('datetime',
'gt', now().timestamp() | timestamp_custom('%Y-%m-%dT%H:00:00+00:00',
false)) | map(attribute='temperature') | first | round}}
icon: >-
{{user_data.icons[forecast['weather.pirateweather'].forecast |
selectattr('datetime', 'gt', now().timestamp() |
timestamp_custom('%Y-%m-%dT%H:00:00+00:00', false)) |
map(attribute='condition') | first]}}
additional_options:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: '17056'
hail: a2441
lightning: a630
lightning-rainy: a49299
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
windy-variant: a15618
full_moon: '2314'
waning_gibbous: '2315'
last_quarter: '2316'
waning_crescent: '2317'
new_moon: '2318'
waxing_crescent: '2320'
first_quarter: '2320'
waxing_gibbous: '36234'
home: '96'
sunrise: '485'
sunset: '486'
unavailable: '52176'
colors:
'0': '#00ff7f'
'5': '#00ff2a'
'10': '#2aff00'
'15': '#7fff00'
'20': '#d4ff00'
'25': '#ffd400'
'30': '#ff7f00'
'-15': '#007fff'
'-10': '#00d4ff'
'-5': '#00ffd4'
suffix_text: °C
user_options:
duration: 5
color: |-
{{user_data.colors[(user_data.colors.items() |
map(attribute='0') |
map('int') |
sort | select('>=', value_template.text) |
first) | string]}}
error is
Errore: UndefinedError: 'str object' has no attribute 'text'
use case please…
yes. no text. probably old example.
here is the last one
alias: AWTRIX - OUTDOORS TEMPERATURE (EXT)
description: ""
use_blueprint:
input:
entity: sensor.easyweatherv1_6_4_outdoor_temperature
awtrix_device:
- 3135904cc76cc8342758e395c7c19c10
- cba036557ec6a93c46e1772448fac471
app_icon: "2355"
additional_action:
- variables:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
unavailable: "52176"
user_options:
duration: 5
pos: 0
text: ""
icon: "{{icons[states('weather.forecast_home')]}}"
draw: |
{%- macro draw_forecast_lines() %}
{%- set hours = 24 %}
{%- for hour in range(hours) %}
{"dp": [{{8 + hour}}, 7, "{{colors[(colors.items() | map(attribute='0') |
map('int') | sort | select('>=', forcast_temp[hour]) | first) | string]}}"]}
{%- if hour+1 != hours %},{%endif%}
{%- endfor %}
{%- endmacro %} [
{{draw_forecast_lines()}},
{"dt": ["{{13 if value_template > 9 else 15}}", 1, "{{'+' if value_template > 0}}{{value_template}}°", "{{color}}"]}
additional_options:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
full_moon: "2314"
waning_gibbous: "2315"
last_quarter: "2316"
waning_crescent: "2317"
new_moon: "2318"
waxing_crescent: "2320"
first_quarter: "2320"
waxing_gibbous: "36234"
home: "96"
sunrise: "485"
sunset: "486"
colors:
"0": "#00ff7f"
"5": "#00ff2a"
"10": "#2aff00"
"15": "#7fff00"
"20": "#d4ff00"
"25": "#ffd400"
"30": "#ff7f00"
"35": "#ff5000"
"40": "#ff2000"
"-15": "#007fff"
"-10": "#00d4ff"
"-5": "#00ffd4"
value_template: "{{states(entity_id) | round}}"
color: |-
map('int') | sort | select('>=', value_template) | first) | string]}}
forcast_temp: |-
{{(forecast[forecast.keys() | first]).forecast |
map(attribute="temperature") |
map('round') |
list}}
pre_actions:
- target:
entity_id:
- weather.forecast_home
type: hourly
prefix_text: "{{ '+' if value_template > 0 }}"
suffix_text: °
Thank you, works like a charm. May I ask if you could also share the other weather blueprints from the beginning of the thread? I can’t get it to work properly e.g. with night temperature and moon status. Seems I am too stupid to adapt all the changes & when playing around one little mistake and all the code is gone would be much appreciated. (I used to use the old weather component from you for simple reasons, but stopped working a time ago)
alias: AWTRIX - NIGHT_TEMERATURE
description: ""
use_blueprint:
input:
awtrix_device:
app_name: awtrix_app_night
entity: weather.forecast_home
pre_actions:
- target:
entity_id:
type: daily
user_options:
duration: 5
icon: "{{user_data.icons[states('sensor.moon_phase')]}}"
text: "{{ '+' if value > 0 }}{{value}}°"
pos: 1
color: |-
map('int') |
sort | select('>=', value) |
first) | string]}}
additional_options:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
full_moon: "2314"
new_moon: "2318"
home: "96"
sunrise: "485"
sunset: "486"
colors:
"0": "#00ff7f"
"5": "#00ff2a"
"10": "#2aff00"
"15": "#7fff00"
"20": "#d4ff00"
"25": "#ffd400"
"30": "#ff7f00"
"-15": "#007fff"
"-10": "#00d4ff"
"-5": "#00ffd4"
value: >-
{{forecast['weather.forecast_home'].forecast | map(attribute='templow')
| first | round}}
prefix_text: {}
I’ve installed the HACS component from GitHub, I’ve added awtrix:
to my configuration.yml
, and I’ve imported the blueprint - but it can’t find any device
I added it through the devices menu but nothing is available:
Did I miss a step?
the same here!
hey! @10der what the heck?
that’s OK cuz now this version of custom_components based on exists (sic!) MQTT devices.
so, feel free to check here:
developer-tools/action
NB to ALL. About plans.
the next version of custom_components will:
- named as awtrix3
- Integrated in HASS (you shouldn’t install anything)
- not use MQTT at all!
- not binding to device names
Ah! Didn’t realize you had to setup MQTT, thanks! working now
Hello, please help. I use the standard weather supplier, before everything worked for me, but after the updates it broke.
This is my old config:
alias: Weather
description: ""
use_blueprint:
input:
awtrix_device:
- 67e1441ba82d754a19ee1855ec04c124
- b9d47ac236b6ca5ba2f85536e42ec71d
app_icon: a2282
entity: weather.forecast_home_assistant
pre_actions:
- data:
type: hourly
entity_id: weather.forecast_home_assistant
value_template:
text: >-
{{forecast['weather.forecast_home_assistant'].forecast |
icon: >-
{{user_data.icons[forecast['weather.forecast_home_assistant'].forecast
additional_options:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
full_moon: "2314"
new_moon: "2318"
home: "96"
sunrise: "485"
sunset: "486"
colors:
"0": "#00ff7f"
"5": "#00ff2a"
"10": "#2aff00"
"15": "#7fff00"
"20": "#d4ff00"
"25": "#ffd400"
"30": "#ff7f00"
"-15": "#007fff"
"-10": "#00d4ff"
"-5": "#00ffd4"
suffix_text: °C
user_options:
duration: 5
color: |-
map('int') |
first) | string]}}
Tell me how to fix it. The error is also as a pair of posts higher: “Errore: undefinederror: ‘Str Object’ Has No Attribute ‘Text’”.
I do not want to remain in debt if there is where to transfer funds, I will do it.
value_template: "{{ state_attr('weather.forecast_home_assistant', 'temperature') | round }}"
Weather forecast WITHOUT external temperature sensor
as main entity, please use Home Assistant weather entity!
alias: AWTRIX - OUTDOORS TEMPERATURE (DEL ME)
description: ""
use_blueprint:
input:
awtrix_device: []
app_icon: "2355"
additional_action:
- variables:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
user_options:
duration: 5
pos: 0
text: ""
icon: "{{icons[states(entity_id)]}}"
draw: |
{%- endfor %}
{%- endmacro %} [
additional_options:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
full_moon: "2314"
new_moon: "2318"
home: "96"
sunrise: "485"
sunset: "486"
colors:
"0": "#00ff7f"
"5": "#00ff2a"
"10": "#2aff00"
"15": "#7fff00"
"20": "#d4ff00"
"25": "#ffd400"
"30": "#ff7f00"
"35": "#ff5000"
"40": "#ff2000"
"-15": "#007fff"
"-10": "#00d4ff"
"-5": "#00ffd4"
value_template: "{{ state_attr(entity_id, 'temperature') | round }}"
color: |-
forcast_temp: |-
map('round') |
list}}
pre_actions:
- target:
entity_id: "{{entity_id}}"
type: hourly
suffix_text: °
Thanks, with this config it works with the built-in weather provider:
description: ""
use_blueprint:
input:
awtrix_device:
app_icon: "2355"
additional_action:
- variables:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
user_options:
duration: 5
pos: 0
text: ""
draw: |
{%- endfor %}
{%- endmacro %} [
additional_options:
icons:
clear-night: a12181
cloudy: a2283
exceptional: a2364
fog: "17056"
hail: a2441
lightning: a630
partlycloudy: a2286
pouring: a49300
rainy: a2284
snowy: a2289
snowy-rainy: a49301
sunny: a2282
windy: a15618
full_moon: "2314"
new_moon: "2318"
home: "96"
sunrise: "485"
sunset: "486"
colors:
"0": "#00ff7f"
"5": "#00ff2a"
"10": "#2aff00"
"15": "#7fff00"
"20": "#d4ff00"
"25": "#ffd400"
"30": "#ff7f00"
"35": "#ff5000"
"40": "#ff2000"
"-15": "#007fff"
"-10": "#00d4ff"
"-5": "#00ffd4"
color: |-
forcast_temp: |-
map('round') |
list}}
pre_actions:
- target:
type: hourly
suffix_text: °C
app_name: awtrix_app_temperature
