Hi @10der , I wonder if you could help me to understand how calculations are made ?
I’m fetching the Internet Speed of my router and showing it every X minutes on the clock. This works fine. I want to use the progress bar to show the % of max speed to this.
The math should be “current speed” / “max speed” * “100”.
Can you explain how to do this in very basic steps ? Thanks
One question: Is there an option to change the color coding of the forecast line at the bottom of the weather app? It seems the range 15° to 25° is yellow, so my bar is mostly yellow only.
I am using the weather app via the blueprint as follows:
Just to follow on my attempt to improve the readibility of the weather forecast bar: I updated the following line in awtrix.py to “compress” the color scale for locations with smaller temperature ranges:
Example hue value for current / updated code:
-5°C: 170° / 341°
10°C: 110° / 176°
25°C: 50° / 11°
However, this only slightly improves the situation. When checking the live view of the clock via the awtrix webinterface I realized that the actual issue is a hardware limitation of the clock in terms of color resolution. In the live view a variety of colors between light green, yellow and light orange are shown, while on the real clock all forecast pixels are shown in the same yellow color.
Thanks so far, I’m a noob, so could you explain what kind of Action I should create to do the math ?
I got 2 Sensors with the values, so this should be possible
Thanks for taking the time to help me here. I still can’t get my head around this.
I installed your blueprints and everything.
I’m using notify, as I would rather not push the app each time the speed changes, so I run this every 2 Minutes, which is good enough for me. (trigger in the example below is empty)
description: ""
snipp
mode: single
So the progress bar is always showing 100%. So I do not understand how to do this properly. It’s rather confusing how HA works here
