I found it too annoying to update the flows one so I just keep a MUCH more feature-full one on github
Hello, first of all BIG thank you for this awesome AWTRIX firmware and BIG thank you for your blueprints @jeeftor ! Love it!
I am a noob and would like to kindly ask for some basic assistance. I am trying to publish my energy meters data to Ulanzi clock but i am not a coder and not very technical so struggling to find the right format. I checked the forums and tried many things. This is the automation i’m trying to create:
alias: awtrix_notify_power_consumption
description: “”
- platform: state
entity_id: sensor.power_usage
action: - service: mqtt.publish
metadata: {}
qos: “0”
retain: true
topic: awtrix_06cab4/custom/power
payload: states.sensor.power_usage.state
The trigger works but the action doesnt. I dont see mqtt publishing the energy meter data on the Ulanzi clock. What am i doing wrong?
when i test a push notification to my phone from this power sensor, that works well:
service: notify.mobile_app_sm_s926b_ee
message: ‘Energy is: {{ states(“sensor.power_usage”) }}’
But i just cant figure out how to send the same data to the Ulanzi clock…
Thanks so much! ![]()
i have same issue
did you solved it?
Payload has to be in JSON and you have to tell AWTRIX that it should display a text containing your sensor data. Try the following as payload:
payload: "{ text: \"{{ states.sensor.power_usage.state }}\" }"
Example payloads and options are available in the AWTRIX API manual.
Thank you so much JC-23! It works! ![]()
For days I have been struggling with setting up the blueprint. The problem seems to be the correct configuration in the config.yaml. The entry is:
- platform: rest
resource: https://api.ipgeolocation.io/astronomy?lat=48,XXX&long=-9,XXX&apiKey=XXXXXXXXXXXXXXXXXXXXX
scan_interval: 300
value_template: OK
json_attributes: null
- moonrise
- moonset
- moon_altitude
I geht the Error:
Message malformed: Missing input moon_rise_set
And I can’t select the setting for the moon rise/set sensor in the blueprint configuration: "No matching entities found".
I have already asked in the support channel on Discord, but unfortunately I have not received a reply. What can I do, what is my mistake?
Thank you in advance,
T.
Maybe a dumb question, but I’m just playing around with some of your blueprints @jeeftor but how do I have to set up them to change on the awtrix automatically? I have the calender, mega weather and HAVC running but only the mega one is shown on the display…
nop… i am biggner and i think i cant do this for now as i even dont know where to paste this command ![]()
Do you know how to use MQTT explorer?
Best way is to pull up AWTRIX/custom/xxxx and see if it has an entry
So this means I only have jeef_weather running right now since the other two items are “empty”
are you able to share whole code for this sensor? cause i can handle it.
This is what I have in my configuration.yaml file:
- platform: rest
resource: https://api.ipgeolocation.io/astronomy?lat=49.10xxxx&long=-122.82xxxx&apiKey=9344465698614xxxxxxxxxxxxx
scan_interval: 300
value_template: “OK”
json_attributes:
- moonrise
- moonset
- moon_altitude
I am no expert, and I have been struggling to get the Icons to show. But I believe the issue you are having is a formatting issue.
You have:
- platform: rest
scan_interval: 300
value_template: OK
- moonrise
- moonset
- moon_altitude
Should be:
- platform: rest
resource: https://api.ipgeolocation.io/astronomy?lat=<>&long=<>&apiKey=<>
scan_interval: 300
value_template: "OK"
json_attributes:
- moonrise
- moonset
- moon_altitude
The indent after the json attributes.
Hello friends, how do I get this blueprint running? I provided all the imput… but when trying to add the “OpenWeatherMap” integration from the addon store it keeps telling me “already_in_progress”. Any ideas? I am not able to see any forecasts on my clock, but I dont know how to debug…
Solved: I needed to activate a paid OpenWeather plan to make it work in combination with the 3.0 API calls.
Really? Should work with any weather provider that has a forecast object
Has anyone used any provider other than OpenWeather for this? I am not keen on giving them my credit card details for security reasons.
Exactly same question on my side ![]()
If you pull it down from my Github a it should just read a forecast object and so it should probably work with anything that has forecast with the right fields
Since they standardized the weather entity: Weather entity | Home Assistant Developer Docs
I’m just parsing: Weather entity | Home Assistant Developer Docs
Perfect, thanks it’s working fine with another weather provider ![]()
Its probably long overdue a “rewrite” of the description ![]()
I’ve set it up yesterday, it seems to be working, awesome stuff! But today in the morning I got message that ipgeolocation API limit was reached (1000 req/day). I was wondering, how is it possible if I’ve set it rest sensor to scan_interval: 300. Any ideas? ![]()
