According to https://github.com/home-assistant/hassio/blob/dev/hassio/utils/tar.py
HomeAssistant’s snapshot is tar archive that consists of SecureTar archives.
SecureTar is a HomeAssistant abstraction.
It looks like normal tar.gz archive but it isn’t - that’s why you can’t just uncompress it.
First 16 bytes - is a salt
Then goes AES 128 CBC encrypted data. (the data is a tar.gz archive)
Key = your password.
IV calcultaed based on salt and key by following code:
def _generate_iv(key: bytes, salt: bytes) -> bytes:
"""Generate an iv from data."""
temp_iv = key + salt
for _ in range(100):
temp_iv = hashlib.sha256(temp_iv).digest()
return temp_iv[:16]
I can’t decrypt it via command line tools because of too complex iv calculation function. Maybe we can just use python to decrypt it.
