I’ve tried doing some searching but I’m not sure what the best solution would be for controlling an automatic gate opener. I know I could do a wifi switch, but I’m just not sure the wifi signal will be all that reliable being that the opener is at the end of the driveway a good distance away from the house.
Is there some device that can learn and send the signal of the remote for the opener? I’m thinking that could work since it could just send the signal from my garage, which is close enough to wifi and power.
I would not use 433mhz Rf stuff here. Although I am generally not that concerned about security, using (generally not encrypted) RF to open a door or gate is the Smart Home equivalent of „typing“ your password pin using a voice assistant in public
Would be more straight forward to leave the gate open in the first place.
If you have already a system using a remote control you could shortcut the open/close button of this remote using a WiFi chip like esp8266 leaving the remote in the garage and „remote control the remote control“ with WiFi
I solved that challenge 5 years ago with a WEMO Maker. WiFi reaches all the way to my deck AP.
The Maker controls the gate and has a sensor to determine if Open or CLose. Works flawlessly.
Bad news is Belkin discontinued the Maker. I despise Belkin (the company) and as soon as I can find another WiFi solution with a temporary switch and sensor I will consider an alternative.
Thanks for the idea. This could work. I’m just not sure if the opener is close enough for the z-wave signal. It could be. My RbPi is only blocked by one wall until it’s open air to the gate opener, and I’m seeing online that zwave has a pretty far range when there is no obstructions.
Hijacking this thread for a similar question. I have a driveway gate that is solar powered and should have sufficient WiFi signal out there. Looking for a solution that can monitor the batteries of the gate opener as I’ve had some issues where the gate will not open and my assumption is the batteries are depleted.
I am using a Dahua doorbell which has dry contacts to open the gate. My gate controller is BFT. The doorbell can be configure on HA. I am however looking for a solution to open the gate on car approach
