Create your own custom logs. You can log as much or little as you like. See here: https://www.home-assistant.io/integrations/file/
Here are some excerpts from my configs:
In Notify:
- platform: file
filename: hvaclog.csv
timestamp: true
- platform: file
filename: eventlog.csv
timestamp: true
In an automation:
- service: notify.hvaclog
data_template:
message: "Automation - At {{now().strftime('%m/%d %H:%M:%S')}} <hvac_mode1_changed> triggered by {{ trigger.entity_id }}."
and in a script:
data_template:
message: >-
Set - T-Stat1 set point now at {{ states.input_number.t1_set_point.state | int }} degrees by {{ states('input_text.hvac_trigger') }}.
Its incredibly easy to set up, completely controlled by you and can be toggled on/off with a simple input_boolean (assuming you place the notify_xxx AFTER the relevant code block.
Finally, here is a small bit of the data logged today:
Home Assistant notifications (Log started: 2020-04-08T14:34:51.008347+00:00)
2020-04-12T04:00:05.016090+00:00 ================== 04/12/2020 ==================
2020-04-12T08:41:50.008183+00:00 Automation - At 04/12 04:41:50 <hvac_set_mode_2> triggered by sensor.tstat2_actual_temp to 77.
2020-04-12T08:41:50.026784+00:00 Automation - At 04/12 04:41:50 <hvac_mode2_changed> triggered by input_select.thermostat_mode_2.
2020-04-12T08:41:50.037949+00:00 Action - HVAC-2 Mode: Heat at 78.0℉
2020-04-12T08:41:50.047637+00:00 Script - At 04/12 04:41:50 <update_tstat_mode_2> started.
2020-04-12T08:41:51.230585+00:00 Automation - At 04/12 04:41:51 <hvac_set_mode_2> triggered by sensor.tstat2_currentsetpoint to 78.
2020-04-12T08:41:51.242928+00:00 Action - HVAC-2 Mode: Heat at 78.0℉
2020-04-12T08:41:56.006867+00:00 Set - T-Stat2 to heat mode by auto.hvac_set_mode_2.
2020-04-12T08:42:01.027156+00:00 Script - At 04/12 04:42:01 <update_tstat_temp_2> started.
2020-04-12T08:42:01.035220+00:00 Get - T2 set point was at 79.
For clarity I use a simple nomenclature scheme;
Automations are prefixed as Automation -
Triggered events in automations are prefixed as Action -
Script initiations are prefixed as Script -
and service actions are either Set - or Get -
Makes reading the log a bit easier to follow especially if there are built in Delays or Waits.
Each day it writes a new Day Header.
Hope this helps someone.
