Blueprint generating an error - expected dict for dictionary value
I’m using a blueprint, which is a slightly modified version of this blueprint
It’s generating the following error in my HASS log:
> 2021-03-04 16:56:01 ERROR (MainThread) [homeassistant.components.automation] Blueprint Z2M - Aqara Wireless Mini Switch generated invalid automation with inputs OrderedDict([('switch', 'sensor.bedroom_button1_action'), ('press_single', [OrderedDict([('service', 'light.toggle'), ('data', OrderedDict([('entity_id', 'light.nightlights')]))])]), ('press_double', [OrderedDict([('scene', 'scene.all_lights_off')]), OrderedDict([('service', 'media_player.media_stop'), ('data', 'media_player.bedroom')])])]): expected dict for dictionary value @ data['action'][1]['choose'][1]['sequence'][1]['data']. Got None
I can’t see any issues with it specifically. Here’s the blueprint code:
blueprint:
  name: Z2M - Aqara Wireless Mini Switch
  description: Automate your Xiaomi Aqara Wireless Mini Switch using ZHA events.
  domain: automation
  input:
    switch:
      name: Aqara Wireless Mini Switch
      description: Aqara Wireless Mini Switch to use
      selector:
        entity:
          domain: sensor
          integration: mqtt
    press_single:
      description: Action to run on single press
      default: []
      selector:
        action: {}
    press_double:
      description: Action to run on double press
      default: []
      selector:
        action: {}
    press_long:
      description: Action to run when button is long pressed (held down)
      default: []
      selector:
        action: {}
    press_release:
      description: Action to run when button is released after a long press
      default: []
      selector:
        action: {}
    press_shake:
      description: Action to run when shaken
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
- platform: state
  entity_id: !input switch
  attribute: click
  - variables:
      command: "{{ trigger.to_state.state }}"
  - choose:
      - conditions:
          - "{{ command == 'single' }}"
        sequence: !input press_single
      - conditions:
          - "{{ command == 'double' }}"
        sequence: !input press_double
      - conditions:
          - "{{ command == 'hold' }}"
        sequence: !input press_long
      - conditions:
          - "{{ command == 'release' }}"
        sequence: !input press_release
      - conditions:
          - "{{ command == 'shake' }}"
        sequence: !input press_shake
And here’s the generated automation from my automations.yaml file:
- id: '1612272860047'
  alias: Dereks Button
  description: ''
  use_blueprint:
    path: mine/z2m_xiaomi_button.yaml
    input:
      switch: sensor.bedroom_button1_action
      press_single:
      - service: light.turn_off
          entity_id: light.house_lights
      - service: media_player.play_media
          media_content_id: stop
          media_content_type: custom
          entity_id: media_player.bedroom
      press_double:
      - service: light.toggle
        data: {}
          entity_id: light.nightlights
      press_long:
      - service: light.turn_on
        data: {}
      press_release: []
      press_shake: []
Can anyone help me debug what’s wrong?
Same issue here, but with Hue Dimmer switch.
Hi Derek,
Did you get to the bottom of this error? My aqara switch blueprint has suddenly started generating similar errors over the last week.
I have the same issue with this blueprint. Everything is working OK but I want to get rid of this error. Cannot find the issue, anyone find the solution?
