2021-08-12 18:18:47 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547483271424] The BMW Connected Drive portal returned an error: UNKNOWN_ERROR (received status code 400 and expected 200).
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1491, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 856, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/lock/__init__.py", line 141, in async_lock
await self.hass.async_add_executor_job(ft.partial(self.lock, **kwargs))
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/lock.py", line 47, in lock
self._vehicle.remote_services.trigger_remote_door_lock()
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/remote_services.py", line 162, in trigger_remote_door_lock
self._trigger_remote_service(_Services.REMOTE_DOOR_LOCK, post=True)
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/remote_services.py", line 209, in _trigger_remote_service
return self._account.send_request(url, post=post, data=data)
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/account.py", line 213, in send_request
raise IOError(msg)
OSError: The BMW Connected Drive portal returned an error: UNKNOWN_ERROR (received status code 400 and expected 200).
Newbie here, my Home Assistant is 2021.8.6. On mine I can “read” all statuses OK on my car, but cannot Lock / Unlock. I get the error:
BMW made changes here as well so for a lot of cars, including my car, the parking light info is not available from the API anymore. That gave a lot of error messages in the log, so we made a PR that fixed that and only updates if parking light info is available. If your parking light entity has state Unavailable you can delete the entity. When BMW makes the information available again the entity will be added again on the next restart of HA. More info here → lights_parking sensor no longer available · Issue #296 · bimmerconnected/bimmer_connected · GitHub
I can confirm update status/lock/unlock/flash lights works now but not the horn:
File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 943, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: https://cocoapi.bmwgroup.com/eadrax-vrccs/v2/presentation/remote-commands/WBAXXXXXXXXX/horn-blow
Maybe the car doesn’t support it?
And this guy is not back either
Not in the UK but in Ireland and yeah not seeing horn under the app, trying to think if it was there before the myBMW app went live
The parking lights are there and work from the app (flash lights the same thing?) but as you mentioned maybe it’s not in the api anymore.
i recently / this morning ugpraded tot 8.8 as i wanted connected drive to work again as well but im receiving an error with login:
Logger: bimmer_connected.account
Source: /usr/local/lib/python3.9/site-packages/bimmer_connected/account.py:168
First occurred: 9:15:18 AM (2 occurrences)
Last logged: 9:15:52 AM
Authentication failed (invalid_client): Client authentication failed (e.g., login failure, unknown client, no client authentication included or unsupported authentication method)
Is this due to not everything beeing migrated yet ? (im sure the password is correct)
Good Afternoon, I have been following the conversation regarding the transformation to the new bmw system. Thanks to everyone who has been contributing to getting the bmw connected drive integration back up and running. It has also been working on my installation without any problems. The only thing that has terminated working after the change at BMW to the My BMW App is sending notifications to my bmw via the notify.bmw_connected_drive_330e_xdrive. It will always return the following error: The My BMW API does not support sending messages without location. Maybe someone else has encoutered the same problem or maybe someone has a hint towards the solution. Thanks again for all your great work !
I’m getting this in my log over and over again, not sure when it started though, im on 2021.11.1
2021-11-08 10:05:26 ERROR (MainThread) [homeassistant.components.sensor] bmw_connected_drive: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 431, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 651, in async_device_update
await task
File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/sensor.py", line 535, in update
value_converted = self.hass.config.units.length(value, LENGTH_KILOMETERS)
File "/usr/src/homeassistant/homeassistant/util/unit_system.py", line 116, in length
raise TypeError(f"{length!s} is not a numeric value.")
TypeError: None is not a numeric value.
Same here not working for about 2 days, can’t get the fuel levels the tracker, and the lock status. Tested on 2021.11.1/2/3. Sensors returning “Unknown / Not numeric”
I’ve just installed the beta as a custom component from that repo and it’s working again. My parking lights still aren’t showing, but I think that’s an older issue and won’t ever be coming back.
