Broadlink Integration - add support for RM4 Mini
Hmm…same same here with 2029.12.2
Thinking aloud, i think it is possible to:
-clone the official broadlink repository,
-add the missing line for RM4C mini
-add this repository (manually or using HACS) to custom_components
Will try this when i have time (and share the github url)
Hmm…sorry…can’t find the init.py file, so no go for now
For those who cannot find the __init__.py file, especially on HassOS, I managed to solve the issue by following the advice found at https://github.com/home-assistant/core/issues/42983:
  1. Open Home Assistant and install the “SSH & Web Terminal” add-on (NOT the original SSH add-on).
  2. Disable Protection mode
  3. Open the Terminal web UI
  4. Enter: docker exec -it homeassistant /bin/bash
  5. Enter: pip3 install --upgrade git+https://github.com/mjg59/python-broadlink.git --no-deps
  6. Restart Home Assistant.
Your newer device should now be recognized by the Broadlink integration. It works for 0x6539.
Esto funciono perfecto para mi!
Muchas gracias Motik68
Method of editing the init.py also worked for me with a RM4C thanks.
If Motik68’s solution doesn’t work for you after updating to the 2021.3.4 version, try the solution from here: https://github.com/home-assistant/core/pull/47779#issuecomment-798806047
It installs the broadlink library from another repo:
  1. Open Home Assistant and install “SSH & Web Terminal” add-on
  3. Click “Terminal” on the sidebar and install the patch.
pip3 install git+https://github.com/felipediel/python-broadlink.git --force-reinstall --no-deps
  1. Restart the server.
Thanks! Works for me. But as mentioned before, this will not survive core updates. Just repeat the steps after updating the core.
Is this still a problem? Should I buy the mini 3 instead of 4? I just want that it works out of the box. Any advice?
It looks like it has made it in to the master repository (line 90)
0x6539: (rm4mini, "RM4C mini", "Broadlink"),
So it should not be an issue anymore (but i haven’t actually checked it, as i am currently not using it)
it was the PR which added it on Jan 8th
My problem is when trying to integrate my RM4 mini it says unable to conect… just took the IP from the router… any clue ?
Connect to the device
Failed to connect
Can this integration start automation when a signal comes over RF 433, for example, from a leak sensor?
To my knowledge, broadlink is used to send IR/RF433 signals, it only receives them when in learning mode.
Looks like you eed a sonoff rf bridge (tasmota) or something
Integration will never be able to keep the learning mode for a long time?
