Broadlink IR Climate Component
wich thread, wheere??
the component no longer works in newes hassio :confused: need something else
oh found it, smartIR
Is there a way to update climate state without actually calling the climate component?
Can explain?
Use the rest API, I asked a question about this agrees ago you just need to find the thread.
However with the new component it supports a power state sensor, so maybe not needed.
Just an FYI. I updated smartIR recently, and it is working fine. so thank you.
Hey would love to know how did you captured these codes?
I have a slightly different remote and want to find out the codes.
Either use the learn service from the dev panel:
or this tool:
broadlink.learn doesn’t work for me, it always says cannot connect to device?
sorry wrong post
I want control my Toshiba airconditioner with brodlink , do i need both configurations .
climate:
  - platform: broadlink
climate:
  - platform: smartir
No. You can just use SmartIR
Thanks, How can i set Airconditioner according my room temperature sensor. I want Airconditioner “ON” when temperature is below 21° and “OFF” when temperatures is above 23°.
Thermostat card did not turn on heater when temperature goes lower then target temperature
I am also looking to sync my ESPHome IR climate component (which I am using to control my split ac) with my knx keypad climate control (schneider multitouch). Did you have anybluck with the same.
Right now I have two climate components… and not sure how making a change in knx would actually send ir commands to ac. And how any change to ac using hassio UI would change display on knx keypad.
Id not use 2 climate entities, but one - the one that holds the state. Then make an automation forwarding knx_events to it. If you need the state in Knx as well use expose.
Did you manage to find something ? Also looking for R09B remote codes.
Is this AC not compatible with the LG THINQ integration?
