I used the script that ReneTode made the other night actually but without success, I just did it again and got the following… baring in mind I only have 1 switch called switch1 in econtrol:
Why just AAA==? Are you determining ‘AAA==’ because of my output or just saying that because its a generic addition to the end. Sorry I’m just trying to understand, not intending to be rude.
One other question though and relating to what I previously asked… even if the code it’s sending is wrong, surely when I push the “on lighting bolt” in HA I should at least see the RM PRO flash orange as in it’s trying to send the signal, wrong or not?
Just checked my logs and this happens every time I push the switch… I think:
The ‘AAA==’ just makes sure the code has a definite finish and pads it out.
If it (the RMPRO) thinks the code is wrong it probably won’t send it.
That error looks like HA can’t find the code to send.
You need to format any yaml code with the </> when you paste it in here, so select it after pasting and press </> so that it is formatted so we can see the correct spacing (very important in yaml)
You need to format any yaml code with the when you paste it in here, so select it after pasting and press so that it is formatted so we can see the correct spacing (very important in yaml)
See here …
--------------------------------- V
What do you mean by the “--------------------------------- V” ?
It’s about how you use the forum to paste yaml code, see at the top of every forum message there is a blue box with a link in it explaining how to use the formatting tools i.e. < / > button at the top of the box you can see when you are typing a message.
into CMD keeps yielding the error " Could not find a version that satisfies the requirement pycrypto (from versions: )
No matching distribution found for pycrypto"
Maybe the bit about the two codes concatenated, or you could try multiplying it up by 6. Not sure either would work but you never know. You could also try re-learning the codes. Perhaps someone with more experience of the TC2 could chime in
Oh my word… I finally did it… I reinstalled Hassbian and started from fresh, it seems like my broadlink “package” was buggered, thanks for all your help Keith!!
Well I’m one step closer now, I managed to use the learn command to get the following 2 codes for my TC1 Gang switch:
