Make sure you have cleared your cache: https://github.com/thomasloven/hass-config/wiki/Lovelace-Plugins#clearing-cache
lovelace-reload has been reintroduced.
out with the old…in with the new
browser-commander was ground breaking, but browser-mod is ground shaking
Thanks for all the time and effort!!!
Okay…this was the last piece of the puzzle to have a totally navigation free wall mount interface…a full screen clock popup that opens and auto-closes via motion detected in room. Thanks! (again) @thomasloven… clock screensaver code
I am sooo… lost. I have been trying to test by posting JSON to the browser_mod.command service with no luck… I just want to get something to happen prior to building out automations. Am I even close?
service_data:
command: popup
title: Popup example
card:
- entity: camera.front_door
show_state: false
title: Frontdoor
type: picture-entity
deviceID:
- 63677d42_8f462a81
- DeviceID should be just the deviceID of the browser, not the entity_id of the mediaPlayer.
- There’s a difference between
popupandclose-popup.
There is no need for service_data when you are calling a service from the dev panel.
"command": "popup",
"title": "Popup example",
"card": {
"entity": "camera.front_door",
"type": "picture-entity"
"deviceID": ["63677d42-8f462a81"]
Hi Thomas, cannot find in the installation instructions how to get the browser ID, can you please document it for us ?
As well can see a JS folder on GitHub, what we suppose to do with it?
Thanks a lot.
Is there any way to make it work on android chrome browser?
Thank You
Works fine here, everything I am currently running is Chrome based. @adas4190
Oh ok. Could you tell me how to check what id is my phone as i have uniqeids only without any description please? Thank You
The directions are very detailed and in the docs provided by Thomas. After installing, you need to add the player to a view and the I.D. will show.
Thank you.
Yep, I tried it that way as well and still no Joy…
Make sure you have cleared your cache, start with no deviceID, and start with a simpler command, like blackout or navigate. Does the media player for the browser show up in your entities list?
Yes, the media player shows up. That’s how i got the device_ID.
also nothing in the logs…
That works for me:
"command": "popup",
"card": {
"entity": "camera.front",
"type": "picture-entity",
"camera_view": "live"
"deviceID": [
"67e7aca5-59360939"
How and where can be found the device ID?
Ok, maybe itis catched ![]()
I tried this script without any result:
