šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
Hi again
Got this error today? Should I worry about it?
No, Home Assistant takes care of this stuff. It should work just fine, but please make an issue on GitHub or comment on an existing one.
I’ve got a recent issue under BM 1.1.5 and HA 0.113.3. If I add the following script to my doorbell actions automation, the rest of the automation does not fire until the BM script has finished. The other scripts do not do that. Is that normal? My Xiaomi gateway used to ring when the doorbell is pushed but now it does it 30s after the doorbell was pushed (when the BM script navigates my tablet back to the default tab).
P.S Love this Integration!
alias: 'Switch Kitchen Tablet to Camera TAB for 30s'
sequence:
  - service: browser_mod.navigate
      navigation_path: /lovelace-tablets/camera
      deviceID:
        - samsung10_fkb
  - delay: 00:00:30
      navigation_path: /lovelace-tablets/tablets
      deviceID:
        - samsung10_fkb
      - platform: event
        event_type: deconz_event
        event_data:
          event: 1000
      - service: camera.snapshot
          entity_id: camera.proxy_entry_720_2fps
          filename: '/config/www/images/doorbell_event.jpg'
      - service: rest_command.fully_kiosk_kitchen_playsound
          sound: 'doorbell_classic.mp3'
      - service: script.control_kitchen_tablet
      - service: xiaomi_aqara.play_ringtone
          gw_mac: !secret xiaomi_mac
          ringtone_id: 10
          ringtone_vol: 30
Seems the issue is not related to the BM script, sorry about that. Any script with a delay causes the same problem.
Is it possible to blur the background when I pop up a card?
You could use card-mod themes to apply styling to all more-info dialogs, not sure if that would apply to browser-mod dialogs…
auto_close: true
card:
  cards:
    - entity: sensor.time
      scale: 150px
      type: 'custom:bignumber-card'
    - details: true
      entity: weather.otthon
      type: 'custom:weather-card'
  column_num: 3
  column_width:
    - 1000
    - 1000
    - 1000
  type: 'custom:layout-card'
deviceID:
  - browser_ipad
hide_header: true
large: true
This is what my code looks like right now, I’m trying to make a screensaver, a black background or a blurred background would be perfectly fine.
I will checkout card-mod themes.
Here’s a bit of a start.
You’ll need to have card-mod installed and find the right place to apply a backdrop-filter.
Thanks Thomas.
The styling part is working fine now, the backdrop-filter part is what I do not get mainly, I do not know where and how to apply that, could you please show me an example?
auto_close: true
card:
  cards:
      scale: 150px
    - details: true
  column_num: 3
  column_width:
    - 1000
    - 1000
    - 1000
deviceID:
  - browser_ipad
hide_header: true
large: true
style: |
  :host {
    --mdc-theme-surface: rgba(0,0,0,0.8);
    --secondary-background-color: rgba(0,0,0,0.8);
    --ha-card-background: rgba(0,0,0,0.8);
    --backdrop-filter: blur(10px);
This is the modified config, but the backdrop part does not seem to do anything
That’s probably not one of the predefined variables used by that element, you’ll have to use the object inspector to find out.
Maybe this helps? šŸ”¹ Card-mod - Super-charge your themes!
@peterson1190 most likely it is bugged on iOS like I mentioned there. Backdrop works fine on Android and desktop browsers, but iPadOS and iOS doesn’t show it.
Understood, I think I’m missing more pieces from the puzzle.
I mean the whole theming story.
I only use ā€œstandardā€ hacs themes, with this code:
frontend:
  themes: !include_dir_merge_named themes
This is what the output looks like from the above code on PC with Chrome.
I will redo the theme part of my HA I think.
Nah, the style parameter of the popup command is pretty much exactly the same as specifying a popup style in a theme.
You won’t need the theme to make a blurred background.
Thanks to Thomas I now have backdrop filter working with iPadOS/iOS. Below code is for popup cards with a blurred backdrop. You can use that and change it how you see fit. Just paste below code in your active theme yaml file and reload themes. This is if you want to apply it to all popups. If you only want it for a specific popup, then just use it as styling parameters for that one popup.
  card-mod-theme: name-of-your-theme
  card-mod-more-info-yaml: |
      .mdc-dialog {
        backdrop-filter: blur(17px);
        -webkit-backdrop-filter: blur(17px);
        background: rgba(0,0,0,0.25);
      .mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
        background: none !important;
        box-shadow: none;
        border-radius: 0px;
    ha-header-bar:
        .mdc-top-app-bar {
The -webkit-backdrop-filter: blur(17px); is for iPadOS/iOS. I have that one and the one without prefix -webkit- so it works on all devices.
Holy Moly and it is working yesss!!
Thank you guys, you are awesome!
FYI for noobs like me:
You need to copy this code to the end of your actual theme.yaml file.
But, again, the same styles can just as well be placed in the service call itself if you don’t want to change the style of all dialogs.
style:
      .mdc-dialog {
        box-shadow: none;
        border-radius: 0px;
    ha-header-bar:
        .mdc-top-app-bar {
I have a problem some popup cards. It’s not show up.
HA112.4, Browser_mod 29:
HA113.2, Browser_mod 1.1.5:
legtisztito_page1_113.2 legtisztito_page2_113.2
ventilƔtorok_113.2
My purifier popup config:
                      tap_action:
                        action: call-service
                        service: browser_mod.popup
                        service_data:
                          card:
                            card_width: 90%
                            cards:
                              - card:
                                  cards:
                                    - elements:
                                        - entity: >-
                                            input_number.xiaomi_airpurifier_favorite_level
                                          hide_state: false
                                          style:
                                            left: 50%
                                            top: 96%
                                          type: 'custom:slider-entity-row'
                                        - entity: sensor.purifier_filter_hours_used
                                          prefix: 'Used: '
                                          style:
                                            background-color: 'rgba(0, 0, 0,.0)'
                                            border-color: 'rgb(34, 154, 210,.0)'
                                            border-left-style: solid
                                            color: dodgerblue
                                            font-size: 100%
                                            font-weight: bold
                                            left: 1.5%
                                            opacity: 1
                                            pointer-events: none
                                            top: 5%
                                            transform: 'translate(0%,-50%)'
                                          type: state-label
                                        - icon: 'mdi:water-percent'
                                          style:
                                            '--iron-icon-height': 20px
                                            '--iron-icon-width': 20px
                                            color: dodgerblue
                                            left: 8%
                                            position: absolute
                                            top: 12%
                                          tap_action: none
                                          type: icon
                                        - entity: sensor.purifier_humidity
                                          fill: 'rgba(0,0,0,0.3)'
                                          font_style:
                                            color: white
                                          gradient: true
                                          max: 100
                                          min: 0
                                          show_card: null
                                          stroke_width: 10
                                          style:
                                            height: 17%
                                            left: 15%
                                            top: 20%
                                            width: 13%
                                          type: 'custom:circle-sensor-card'
                                          units: '%'
                                        - icon: 'mdi:thermometer'
                                          style:
                                            color: dodgerblue
                                            left: 7.5%
                                            position: absolute
                                            top: 27%
                                          tap_action: none
                                          type: icon
                                        - entity: sensor.purifier_temperature
                                          font_style:
                                            color: white
                                          gradient: true
                                          max: 50
                                          min: 0
                                          show_card: false
                                          stroke_width: 10
                                          style:
                                            height: 17%
                                            left: 15%
                                            top: 35%
                                            width: 13%
                                          units: °C
                                        - icon: 'mdi:air-filter'
                                          style:
                                            '--iron-icon-height': 17px
                                            '--iron-icon-width': 17px
                                            color: dodgerblue
                                            left: 8%
                                            top: 42%
                                          tap_action: none
                                          type: icon
                                        - entity: sensor.purifier_filter_life_remaining
                                          font_style:
                                            color: white
                                          gradient: true
                                          max: 100
                                          min: 0
                                          show_card: false
                                          stroke_width: 10
                                          style:
                                            height: 17%
                                            left: 15%
                                            top: 50%
                                            width: 13%
                                          units: ''
                                        - entity: sensor.purifier_aqi
                                          font_style:
                                            color: white
                                          gradient: true
                                          max: 600
                                          min: 0
                                          show_card: false
                                          stroke_width: 10
                                          style:
                                            height: 13%
                                            left: 50%
                                            top: 18.5%
                                            width: 13%
                                          units: p
                                        - icon: 'mdi:speedometer'
                                          style:
                                            color: dodgerblue
                                            left: 8%
                                            top: 58%
                                          tap_action: none
                                          type: icon
                                        - entity: sensor.purifier_fan_speed
                                          font_style:
                                            color: white
                                          gradient: true
                                          max: 3000
                                          min: 0
                                          show_card: false
                                          stroke_width: 10
                                          style:
                                            height: 17%
                                            left: 15%
                                            top: 65%
                                            width: 13%
                                          units: ''
                                        - icon: 'mdi:speedometer-medium'
                                          style:
                                            color: dodgerblue
                                            left: 8%
                                            top: 73%
                                          tap_action: none
                                          type: icon
                                        - entity: sensor.purifier_fan2_speed
                                          font_style:
                                            color: white
                                          gradient: true
                                          max: 3000
                                          min: 0
                                          show_card: false
                                          stroke_width: 10
                                          style:
                                            height: 17%
                                            left: 15%
                                            top: 80%
                                            width: 13%
                                          units: ''
                                        - entity: sensor.purifier_fan_mode
                                          max: 2000
                                          min: 0
                                          prefix: 'Mode: '
                                          style:
                                            color: dodgerblue
                                            font-size: 100%
                                            font-weight: bold
                                            opacity: 1
                                            right: 1%
                                            top: 1%
                                            transform: none
                                          type: state-label
                                        - entity: fan.xiaomi_miio_device
                                          style:
                                            '--iron-icon-height': 22px
                                            '--iron-icon-width': 22px
                                            margin-right: '-10%'
                                            right: 19%
                                            top: 17%
                                          tap_action:
                                            service: fan.toggle
                                            service_data:
                                              entity_id: fan.xiaomi_miio_device
                                          type: state-icon
                                        - icon: 'mdi:brightness-auto'
                                          style:
                                            right: 4%
                                            top: 17%
                                          tap_action:
                                            service: fan.set_speed
                                            service_data:
                                              speed: Auto
                                          type: icon
                                        - icon: 'mdi:power-sleep'
                                          style:
                                            right: 22%
                                            top: 34%
                                          tap_action:
                                            service_data:
                                              speed: Silent
                                          type: icon
                                        - icon: 'mdi:account-heart'
                                          style:
                                            right: 4%
                                            top: 34%
                                          tap_action:
                                            service_data:
                                              speed: Favorite
                                          type: icon
                                        - icon: 'mdi:monitor'
                                          style:
                                            right: 22%
                                            top: 51%
                                          tap_action:
                                            service: xiaomi_miio.fan_set_led_on
                                            service_data:
                                          type: icon
                                        - icon: 'mdi:monitor-off'
                                          style:
                                            right: 3%
                                            top: 51%
                                          tap_action:
                                            service: xiaomi_miio.fan_set_led_off
                                            service_data:
                                          type: icon
                                        - icon: 'mdi:bell'
                                          style:
                                            right: 22%
                                            top: 68%
                                          tap_action:
                                            service: xiaomi_miio.fan_set_buzzer_on
                                            service_data:
                                          type: icon
                                        - icon: 'mdi:lock-alert'
                                          style:
                                            right: 22%
                                            top: 87%
                                          tap_action:
                                            service: xiaomi_miio.fan_set_child_lock_on
                                            service_data:
                                          type: icon
                                        - icon: 'mdi:bell-off-outline'
                                          style:
                                            right: 3%
                                            top: 68%
                                          tap_action:
                                            service: xiaomi_miio.fan_set_buzzer_off
                                            service_data:
                                              entity_id: fan.kxiaomi_miio_device
                                          type: icon
                                        - icon: 'mdi:lock-open-outline'
                                          style:
                                            right: 3%
                                            top: 87%
                                          tap_action:
                                            service: xiaomi_miio.fan_set_child_lock_off
                                            service_data:
                                          type: icon
                                      image: /local/house/purifier7.png
                                      type: picture-elements
                                  type: 'custom:vertical-stack-in-card'
                                style: |
                                  ha-card {
                                    border: 1px solid rgba(57,128,228);
                                    --ha-card-background: rgba(0,0,20,0.6);
                                    border-radius: 15px
                                type: 'custom:mod-card'
                              - entities:
                                  - cards:
                                      - entities:
                                          - entity: >-
                                              automation.legtisztito_bekapcsolasa_hazaerkezeskor
                                            automation.legtisztito_kikapcsolasa_tavozaskor
                                          - type: divider
                                            automation.legtisztito_bekapcsolasa_ebredeskor
                                            automation.legtisztito_kikapcsolasa_alvaskor
                                          - type: divider
                                            automation.legtisztito_bekapcsolasa_aqi_alapjan
                                          - entity: input_number.purifier_aqi_treshold
                                            hide_state: false
                                          - type: divider
                                            automation.legtisztito_kikapcsolasa_aqi_alatt_1_oran_at
                                          - entity: input_number.purifier_aqi_treshold_off
                                            hide_state: false
                                        style: >
                                          ha-card {
                                            border-radius: 15px
                                        type: entities
                                    popup: timeout
                                    type: 'custom:love-lock-card'
                                show_header_toggle: false
                                style: |
                                  ha-card {
                                    border-radius: 15px
                                title: Légtisztító beÔllítÔsok
                                type: entities
                            parameters:
                              allowTouchMove: false
                              centeredSlides: false
                              keyboard:
                                enabled: true
                                onlyInViewport: true
                              navigation: null
                              pagination:
                                type: progressbar
                              slidesPerView: auto
                              spaceBetween: 40
                            type: 'custom:swipe-card'
                          deviceID:
                            - this
                            - dashboard
                          large: false
                          style:
                            background-color: 'rgba(0,0,20,0.6)'
                            background-repeat: no-repeat
                            background-size: 100% 100%
                            border-radius: 15px
                            top: 0
                            width: 40%
                          title: Légtisztító
What is wrong in my code?
Thanks for help!
Should this also work for the replaced more-info dialogs and the (command) popups?
For me the style is only applied to the normal more-info popups.
Background: I’m experiencing a problem when using popups on android. The problem is consistent on Android using both a 10 inch tablet and pixel 3. I’ve tested both devices using the official android app, mobile chrome, and mobile firefox. The problem doesn’t occur on desktop chrome (I didn’t test other desktop browsers)
I use popups to display multiple cards at once (combined with vertical/horizontal stacks). They’re composed of some button-cards, some mini-graph-cards, and both mini-thermostat and simple-thermostat cards.
The problem: The thermostat cards (both simple-thermostat and mini-thermostat) don’t function on mobile devices when embedded in popups. I can toggle more-info, but can’t control the functions (changing hvac_mode or raising/lowering temperature).
Both thermostat cards work fine when used in regular lovelace (i.e. not popups). The cards also both work fine using desktop chrome in my popup. The problem is only when using either of those two cards (though potentially more), in popups, on a mobile device.
I’m having trouble pinpointing the problem and would greatly appreciate any help in isolating it!
Basic question incoming! Am on 0.113.3, have upgraded Browser mod to 1.1.5 and card-mod to 2.0.0, and now my basic ā€˜more-info’ popups have lost their styling. The rounded edges and transparency are gone. I am sure there is a simple code to fix this, but would appreciate some help to get it working.
Popup Before:
Capture
Popup After:
Capture
Any help to update my styles code would be appreciated :slight_smile:
Button code to trigger popup:
          - type: custom:decluttering-card
            template: climate_button_card
            variables:
              - entity:  climate.air_conditioner
              - name: Main AC
              - icon: circle
              - tap_action:
                  action: more-info
                  haptic: light
ā€˜more-info’ Popup code (example, not the exact popup shown in picture):
  sensor.dark_sky_summary:
    title: Weather
    style:
      border-radius: 12px
      background: var(--homekit-transparent)
    card:
      type: vertical-stack
      style: |
        ha-card {
          border-radius: 12px;
          background: var(--homekit-transparent);
      cards:
        - type: horizontal-stack
          cards:
            - type: 'custom:button-card'
              color_type: blank-card
              styles:
                card:
                  - width: 10px
            - type: weather-forecast
              style: |
                ha-card {
                  overflow: hidden;
                  box-shadow: none;
                  background-image: none;
                  background-color: transparent;
              entity: weather.dark_sky
              styles:
                card:
                  - width: 10px
        - type: iframe
          style: |
            ha-card {
              border-bottom-left-radius: 12px;
              border-bottom-right-radius: 12px;
              overflow: hidden;
              box-shadow: none;
          aspect_ratio: 60%
          url: https://embed.windy.com/?900h,rain,-33.941,150.974,8
