Interesting. I just tried last night to upgrade my Home Assistant instance from 0.114.4 to the latest - and after a successful upgrade, I started to get some of the usual reboot messages through via Telegram - then the system froze and wasnāt accessible.
I was still able to dial in via SSH and restore a snapshot, but the system didnāt seem to be usable at all. The log was littered with browser_mod errors (tasks being destroyed etc).
I didnāt have time to study the log thoroughly but I will be doing tonight - I just presumed browser_mod and the latest version of HA are not compatible.
Anyone have any thoughts on this?
Hi, I already opened an issue on GitHub facing similar issues after the update
Pls enter your experiences there, so that the mods may have some more hints where to search for the bug
I am noticing the browser_mod component is not working anymore only on my mobile app while it is working as always when using it in the browser of my MAC.
Anyone else noticed it?
Define ānot workingā ā¦
Probably the device-id is reset after a frontend cache refresh in the app?
Which mobile app do you mean?
For me, browser_mod is not working with companion app.
Thatās why I had to install wallpaper.
I need that for my alarm clock dashboard.
Yes, i mean companion app for androidā¦ What you mean with wallpaper?
Wallpaper is an android app, especially developed for display mode on phones or tablets. Works really great but due to increasing functionality of the companion app and the available kiosk mode in HA not really nesessary,ā¦ if browser_mod would work.
On my mobiles it doesnāt. Wallpaper without issues, companion app not. I already tested it again on my S10.
And that is really interesting. Iām wondering why.
Same hereā¦ i hope it will be fixed asapā¦
You are speaking about WallPanel
app I guess.
BTW I have no problem with companion app with browser_mod
Ups, what did I write? Wallpaper
Youāre right, I mean wallpanel.
For research reasons I tested on my tablet yesterday and the companion app worked.
On my mobile phone only wallpanel does. Confusing
Did you try to clean cache, different browser, reload lovelaceUI on your mobile phone?
yes. more then once
I realized that on mobile every popup is being opened in fullscreen.
I have created a nice popup with rounded corners (border radius) which looks exactly as expected.
However it does look bad on mobile.
Is there any solution on having border radius as 0px only on mobile?
Hi fellas, finally I found what I needed, but there are few things remaining to do:
I have implemented alarm_control_panel and it works as popup now, thanks for browser_mod!
here is the code how to call it:
title: Popup example
card:
type: alarm-panel
states:
- arm_home
- arm_away
entity: alarm_control_panel.alarm
deviceID:
- desktop_pc
large: true
hide_header: false
auto_close: false
time: 1
That is good thing, the bad thing is I want it to stay ON till correct code is entered and so user canāt do anything till then.
Did anyone implemented this?
I have the following setup.
I am using Rhasspy which is using NanoTTS for TTS. I created a new command using Hassio config and when i use this endpoint I can trigger TTS announcements. The audio currently plays through RPiās audio jack. I want to use browser_mod to route the audio to a certain Chrome Browser.
rest_command:
rhasspy_speak:
url: '{{ ipnum }}/api/text-to-speech'
method: 'POST'
headers:
accept: 'text/plain'
content-type: 'text/plain'
payload: '{{ payload_data }}'
My browser_mod looks like
browser_mod:
device:
215f0914-e33255b3:
How can I route the voice announcements from the TTS to the Browser ?
I need help!!
Iām going around in circles trying to get the screensaver/screen off functionality working on my FireHD/LineageOS tablet. Itās running FKB Pro and I want the screen to blank (ideally turn off) when no one is nearby. I am using my alarm PIR/motion sensors as triggers.
Iāve tried two solutions:
Screen off - I have configured FKB to turn off the screen after 300 seconds (which it does), I then have an automation that does a service call to turn on the browser/tablet light based on the PIR triggers. The problem with this is the tablet/FKB stops responding to the service call. I believe there is an Android bug that is causing this and the workaround is to āforce_stay_awakeā, but that didnāt seem to work for me (I also have FKB configured to prevent sleeping while screen is off)
So I tried going down the screen saver route - I turned off the āscreen offā settings and enabled the screensaver in FKB. I then changed the automation from turning on the light to sending āno_blackoutā. But this doesnāt work
Does anyone use the screensaver/screen off functionality?
Thanks,
J.
same errors hereā¦may be the device that is starting up and still not ready during the boot of the raspy?
I try popup new windows when click the item.
In the Dev. Tool:
Service = browser_mode.command
Service Data =
command: popup
deviceID: ["this"]
card: {
type: picture-glance,
entities: [
"input_boolean.room_dining_room",
"input_boolean.room_living_room"
camera_image: camera.lila_livemap,
show_state: false
Good, the popup windows is appeared.
But when I create the script to call in the code as:
script:
popup_windows:
sequence:
- service: browser_mod.command
command: popup
deviceID:
- this
card:
entities:
- input_boolean.room_dining_room
- input_boolean.room_living_room
show_state: false
Bad, execute script.popup_windows nothing to show.
How I can do ?
Read this:
FKB has [Remote admin](https://www.fully-kiosk.com/en/#remoteadmin)
function
